Hello, there may be a glass fuse on the power board inside the washer . but make sure you use the same rated fuse, the value will be on the end of the fuse or on the fuse holder on the power board.
regards
shaun
You have an easy job to just trace the power cord to the unit, with the line disconnected and using a multimeter it is easy to trace the continuity of the wire to the unit where you can locate iff the line is cut off or the reason the circuit is open.
most often this can be due to the link fuse at this end or a possible break in the line. If these test fine then the power switch/controller unit is faulty.
