Question about SanDisk Sansa m230 MP3 Player
M230 my player says not enough space please free 8 mb.... not able to delete or formate
  • 8,596 Answers
Get the firmware upgrade from Sandisk website
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Jul 05, 2008
" Not enough space for music DB. Please free 8 MB." Huh??
wire it up to a windows pc, treat it like a harddisk, search through the folders for the mp3's you won't to get rid off,delete the files you want from it, like you would from a computer.then copy some mp3's
to it, unplug, finished.
formatting it might erase some of the software the player needs to run, so you better don't. enjoy your favorite music :-)
Jul 22, 2009 | SanDisk Sansa E280 MP3 Player
Sandisk m230 MTP DB mismatch...
Here is a link to get the manual:
http://www.sandisk.com/Retail/Default.aspx?CatID=1304
On page 30-31 it explains how to RESET the unit to the factory defaults. If nothing else, I believe that will clear your DB Error.
Jun 07, 2009 | SanDisk Sansa m230 MP3 Player
Sansa m230
When connected to your computer, go to your My Computer folder, and right click on your Mp3 player. You should see "Format Device". This wipes the entire thing. All music will be gone, but it might reset it.
Jun 02, 2009 | SanDisk Sansa m230 MP3 Player
Sansa m230
so your mp3 player is full of songs. you dont have enough free space to run the mp3 player or put anymore songs on it. so delete a few.
Apr 19, 2009 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230
I would recommend that you update the firmware on your device..that usually solve the problem you are having..To update the firmware, follow the link below..
http://www.sandisk.com/DriverDownload/download.asp
I hope that helps
Please rate accordingly
Thank You
Computerrep
Mar 25, 2008 | SanDisk Sansa m240 MP3 Player
Problem with My SanDisk Sansa m230
try formatting your device then try to put mp3 files on it. check if it works. on your my computer right click you mp3 device ( it is usually a removable storage) then select format.
Feb 21, 2008 | SanDisk Sansa m230 MP3 Player
Not enough space message, etc.
if you want to delete just click on TCNAND0 icon right click then choose "format" then it will be fully free
Jan 18, 2008 | SanDisk Sansa c150 MP3 Player
Everything is wiped out and so is the radio! Please help !!
The Music DB refers to the information (i.e. - Artist, Album, etc.).
The device need you to free up 6MB so it can create this.
Connect the device to the PC and delete several songs until you have at least 6MB free.
Disconnect it, restart, and youre all set.
Best of Luck.
Nov 03, 2007 | SanDisk Sansa m230 MP3 Player
a small amount of space is used up by the players operating system. a 512mb player will only actually have about 490 mb of usable space. try upgrading the firmware on your player by going to the sandsik website and looking under product support for instructions. Use windows media player to access your device and delete any any duplicate files to free up some more space.
Jul 30, 2007 | SanDisk Sansa m230 MP3 Player
SanDisk Sansa m230 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
