Question about NAD C370 2-Channel Amplifier
Nad c370 problem....
Was listening to my nad pretty loud the other night, driving my old pair of kef q35.2s... but not as hard as i've driven them before. i was by the amp, about to change tracks when i heard a pop, which seemed to come from the amp, not the speakers, and i lost all bass... turned off and unplugged the amp, tried again, but to no avail...
trying to sort out what the problem is... usually i would have said the bass woofers are gone, but i've burned a few of them in my time and there was no smell this time and when i touch the woofers gently, they don't feel blown. also, the pop sound came (or i think came) from the amp...
i tried with headphones, it works fine..
i tried the "B" speaker outputs with the same speakers, there is nothing coming out of them... not even the treble. with the speakers plugged to "A" at least i am getting treble. which seemed weird and made me think the problem is amp related..
any suggestions on diagnosis and perhaps a fix would be appreciated..
thanks!
arda
  • 1,512 Answers
Hi arda5
Did you try swapping speaker connections left for right on the back of the amp to isolate the problem. If the fault stays with the speaker, then that is where your problem is. Try this and get back to me here with the results.
regards
robotek
Posted on Jun 22, 2008
NAD C370 distortion
Check first if you got +68/-68V on amp module left and right on contact CZ302 and CZ402 pin 2 & 7. Often the -68V is missing. This is caused by faulty transistor Q713 in +68/-68V power supply. It's a 2SA872.
Oct 31, 2013 | NAD C370 2-Channel Amplifier
C370 faint crackling sound left channel
have you tried looking at your phono leads,turn volume down until it is low enough that you can still hear the music playing,give the phono leads a turn to see if its a loose connection.if not,try the right channel phono in the left channel to see if this fixes your problem.also you could do the same with your speaker leads and see if that solves the issue.maybe a bad connection is the cause?.it may also help to try and move your cd player away from your amplifier.it could also have been overdriven (played too loud for too long) on the night of the party,only you will know if this was the case or not.
Jan 07, 2013 | NAD C370 2-Channel Amplifier
Nad c370 keeps switching off
Check the speaker wiring for shorts, a common problem. If everything checks out there may be bad solder joints on the main board especially in the output stage, or there is a fault in one or more driver transistors.
Jun 02, 2012 | NAD C370 2-Channel Amplifier
Blown kef q55.2 tweeter, is replacement possible?
The tweater on my Q55.2 blew as well. I went into a shop in NYC and they tried to charge me $225 for a new tweater, so I took it home and called up Kef. They sent me out a new tweater for $35 and instructions on how to solder it in.
It took all of 10 mins to replace and they are working fine. I've never soldered anything before and it was simple.
Cheers
Martin
Mar 24, 2009 | KEF Audio Q55 Speaker
No power at all on NAD C370
User manual here
http://nadelectronics.com/img/manual/NAD-C370.pdf
Read page nine for some simple troubleshooting tips and see if that helps.
It *could* be a fuse but given you've owned it for a while and NAD amps often have capacitor issues in the power supply, chances are it needs some serious work by a good tech. Contact NAD directly and see what they recommend.
Dec 29, 2008 | NAD C370 2-Channel Amplifier
Nad C370
Since the problem seems to be sensitive to the volume level, I would be looking at the output wave form for any DC current. Although the protection circuit should detect any DC present, it is possible that some is leaking through. Also, verify that the speaker impedence is correct. If the amp is seeing too low an impedence load, it will work too hard causing excessive heat which will shutdown the unit as well.
Keep me posted.
Dan
Nov 04, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Amplifier
This sounds like a problem with the protection circuit, and/or the speaker relays. More specifically, a capacitor within those circuits that is not behaving properly. I strongly suggest having it looked at ASAP.
Sep 15, 2008 | NAD C370 2-Channel Amplifier
NAD C370 Right channel distortion
Sounds like you have lost the power amp transistor(s) or IC for this channel.
Aug 29, 2008 | NAD C370 2-Channel Amplifier
Blown Mains Fuse
You should repleace the old transformer with the new one
Jun 13, 2008 | NAD C370 2-Channel Amplifier
NAD C370 2-Channel Amplifier Logo
224 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
