Question about Sansui Audio Players & Recorders
My sansui integrated amplifier model AU-207 power output transistors 2SB545A & 2SD188A were no longer available at the electronic spareparts store in the philippines. i would like to know the replacement transistors for the transistors 2SB545A & 2SD188A so that my amplifier could work again. thank you.
    Genius:
  • 1,148 Answers
Check ebay,,and sansui website
Posted on Nov 03, 2010
Determine if an analog receiver has blown a channel
When you need to replace the output transistors, do them both at the same time with a matched pair. That way you won't unbalance the power supply and will be assured of the same power out is available on both channels.
Feb 18, 2016 | Sansui Audio Players & Recorders
I have a 1990 Technics SA-GX300 receiver that powers on, can be controlled with the remote, but produces no output from any of the input sources. I have been using it as an amplifier for a Zone 2 Bose
27+ is really quite old for electronics, a number of things could have gone but from your description i'm tempted to say the output chips have overheated or blown.... other things to consider with aged audio is the electrolytic capacitors drying out and also causing problems in the audio chain.
Nov 16, 2017 | Technics Audio Players & Recorders
Looking for an owner's manual for the Sansui Integrated Amplipier AU-D9.
Hi info851163...
Go to the following website and register to download your Owners/User Manual for your Sansui Intergrated Amplipier AU-D9.
Please take time to rate me thumbs up
http://www.hifiengine.com/manuals/sansui/au-d9.shtml
Also at this website...for $6.92 Canadian Dollar:
http://www.ioffer.com/i/Sansui-AU-D9-amplifier-Service-manual-79410631
Sep 15, 2011 | Audio Players & Recorders
Proper procedure for hook up to Au 719 sansui amp
This is an integrated amplifier so you connect both of your speakers to the speaker outputs making sure that you keep them in phase. Red or plus terminal on speaker to red or plus terminal on Amp and the same with the other channel. Then connect your input devices as they are marked on the rear of the amp. You didn't mention what devices you are trying to connect to it so give additional info if you need more help.
Mar 24, 2011 | Audio Players & Recorders
Pioneer SA100 integrated - low, distorted output
At this point, I would be looking at the main power suply for the final output stage. You may be attempting to drive the output with the driver section rather than the final amp stage. The center pin of the output transistors should have B+/B- on them. Measure that to ground and report the value here.
Dan
Jul 12, 2010 | Pioneer A35R 2-Channel Amplifier
Marantz SR19 no sound?
When replacing output transistors on amplifiers it is generally a good practice to replace the output capacitors as well as the biasing resistors. Just because one transistor is bad does not mean that that is the whole problem. Look for what caused the problem. Bad speakers,bad wires,defective traces on circuit board,poor soldering. Also when mounting the transistor make sure it is insulated and grease it with a dab of silicone heat sink compound. Whenever I service a board I examine all components for tolerance as well. A resistor marked at 1% tolerance,example 1k ohm + or - 1% should read no less than 990 ohms and no more than 1010 ohms. Anything else your asking for trouble. Another point is that some amplifiers use matching pairs. Pairs complement each other in an output stage and must be replaced in pairs. I repaired a Sansui Amplifier a while back and it looked as if a power output resistor was burned. Comparing the two channels I figured the matching value from the other side and replaced all of them and the system has worked flawlessly for years now. I am a retired electrical engineer and have worked in a few areas of electronics for over 35 years. Hope this information helps you.
May 06, 2009 | Teac A-1D 2-Channel Amplifier
SANSUI AMP AU-D11-II
It is possible, but nlikely that the protection circuit is bad. More common are shorted output transistors or defective driver stage transistors. This should not be a difficult repair for anyone familiar with audio amps. Unsolder/remove Q22 and Q23 and measure the voltages at each of the 3 pads per transistor and post them here.
Thanks,
Dan
Nov 04, 2008 | Audio Players & Recorders
Lightning strike to powered console.
On a generic level, without knowing the specifics of your equipment, I.E. amp & mixer make/model, you start at the mixers input stage. If an amplifiers output transistors die, they usually cause the amp to trip or blow a fuse, the weakest point in the system. If the amp is not doing this then the chances are, it's an line level problem, mixer related.  Again, you have to list the equipment you have in order for me to be more specific.
Nov 02, 2008 | Peavey AMPLIFIER, 1000 WPC, DDT, 8/4/2...
Spares
Bass Treble,bal controls can be clened with contact cleaner.
Drive belts audio heads may be available at the sansui web site or mcm electronics.com.
GOOD LUCK
BIGRED
Apr 01, 2008 | Audio Players & Recorders
488 people viewed this question
Top Sansui Audio Players & Recorders Experts
Jaime Hernandez
Colin Stickland
Colin Stickland
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
