Error 162 there is not actulization of the bios
Hi my name is daniel ceron .
I have an ibm pentiun 3 processor 600mhz and
that it doesn't have an upgrade of the bios
you could send me the solution to the problem
    Problem Solver:
  • 4 Answers
To find your BIOS upgrade you can do one of the following options:
1.Identify your Intel motherboard model via our Award BIOS or AMI BIOS id's tabs
2.Find a(n) Intel BIOS upgrade via the Links tab on the official site.
3.Run the BIOS Agent scan browser plugin
Posted on Jun 13, 2008
Hi there. I have a mercury motherboard pi945gcm with intel core2duo processor. The problem is whenever i switch on my pc only name of the motherboard and the processor name appears(the first thing that...
Yes, the motherboard has failed : the BIOS was corrupted. All you can do is to remove the battery for 1 hour than try again. If that doesn't fixes it then the board is dead, replace it.
Jul 24, 2011 | Mercury Computers & Internet
Manyal
EP-8K3A
Introduction
KT333 with VT8233A AGPset/266MHz FSB/3 DIMM with DDR333/1 AGP-4X/6 PCI/USB1.1/ATA-133/6CH Audio/ATX
Specification
PROCESSOR:
The Socket A compatible AMD AthlonTM XP processor 1500+ to 2700+, 600MHz to 1.4GHz AMD AthlonTM and AMD DuronTM processor up to 1.3GHz
CHIPSET:
VIA KT333 AGPset (KT333+ VT8233A)
DRAM MODULE:
184pin DDR DIMM x 3 for PC2700 Memory
DRAM Size: 64MB to 3GB
EXPANSION SLOT:
PCI x 6!A4X AGP x 1
ONBOARD I/O:
Winbond W83697HF LPC I/O integrated with FDD, Parallel, Game, Serial and IrDA v1.0 and Power-On Controllers
ONBOARD PCI / IDE:
PCI Bus IDE Port with PIO / Ultra DMA-133 x 2 (Up to 4 Devices)
I/O CONNECTOR:
PS/2 Mouse and PS/2 style Keyboard
COM1, COM2, Printer, Audio-in/out, MIC & Game Port connectors
USB:
USB connector x 4 (2 for Opt.)
BIOS:
Award Plug & Play BIOS
Built-in AC97 Digital Audio (by Realtek ALC650):
Compliant with AC97 2.2 specification
6 channel slot selectable DAC output for multi-channel applications
Supports digital SPDIF Out Function
EXTENDED FUNCTION:
Supports Hardware Monitoring Function by W83697HF
Supports exclusive KBPO (KeyBoard Power On)
Supports CPU Vcore , Clock and Multiplier setting via BIOS
Supports Memory Voltage setting via BIOS
Supports STR (Suspend To RAM) power saving Function
Supports Wake-On-LAN Function
FORM FACTOR:
305mm x 245mm x 34mm ATX Size
OS Supported:
Windows 98SE/ME/2K/XP/Server2003
Jun 05, 2011 | EPoX EP-8K3A+ Motherboard
Hola estimados colegas mi problema es el siguiente.Necesito comfigurar los microdips de mi placa IBM y extravie el manual de la misma . el procesador actual es intel pentium III 600mhz /256mhz/133mz ...
Hola. En primer lugar no s? el idioma espa?ol. Esto es se traduce a trav?s de Google Translate. ¿Hay alg?n error les pido disculpas ...Si el sistema es de IBM que se puede descargar el manual desdeel sitio de soporte de IBM.
Feb 16, 2011 | IBM (61H2578) Motherboard
What is the specification for my GA-K8N Pro motherboard?
CPU
  • Socket 939 AMD Athlon™ 64 X2 / Athlon™ 64 FX / Athlon™ 64
Chipset
  • NVIDIA nForce4 SLI MCPs (media and communication processors)
  • Super I/O: ITE IT8712
  • CICADA VSC 8201 Gigabit LAN PHY
  • T.I. IEEE1394b
  • AC'97 Realtek ALC850
Memory
  • Dual channel DDR 400 / 333 / 266 184pin
  • 4 x DIMM slots up to 4GB
Expansion Slots
  • 2 x PCI Express x1
  • 2 x PCI Express x16, supports two PCI Express interface Graphics cards with SLI mode
  • 2 x PCI slot (PCI 2.3 compliant)
Internal I/O Connectors
  • 1 x CD in
  • 1 x FDD
  • 2 x IEEE 1394b (supports 3 ports)
  • 2 x UDMA ATA 133/100/66 Bus Master IDE
  • 3 x cooling fan pin headers
  • 3 x USB 2.0/1.1 (support 6 ports)
  • 4 x SATA II 3Gb/s
Back Panel Connectors
  • 1 x COM
  • 1 x LPT
  • 1 x RJ45 LAN
  • 2 x USB 2.0/1.1
  • 6 x audio ports (Line In / Line Out / MIC In / Surround Speaker Out(Rear Speaker Out) / Center/Subwoofer Speaker Out / Side Speaker Out)
  • Coaxial SPDIF input/output function
  • PS/2 (Keyboard/Mouse)
H/W Monitoring
  • H/W detecting and reporting for case open, CPU voltage and fan speed
  • System health status auto-detect and report by BIOS
BIOS
  • 2 x 4 Mbit flash ROM
  • Award BIOS
CPU/AGP/DIMM setting
  • CPU HT / Multiplier / Vcore Voltage adjustable via BIOS
  • DIMM Voltage / Clock adjustable via BIOS
  • PCI-ExpessX16 Voltage / Clock adjustable via BIOS
Unique Features
  • @BIOS™
  • Download Center
  • NVIDIA Firewall
  • NVIDIA SLI multi-GPU support
  • Q-Flash™
  • Xpress™ Install
  • Xpress™ Recovery
Bundle Software
  • Norton Internet Security™
Power
  • ATX power connector and ATX 12V connector
  • Power-off by Windows 98/Me/2000/XP shut down and switch
Form Factor
  • ATX
  • 305mm x 244mm
Remark
  • Due to different Linux support condition provided by chipset vendors, please download Linux driver from chipset vendors' website or 3rd party website
  • This product does not support Win9X/ME, due to most hardware/software vendors no longer offer support for Win9X/ME. However we still offer available related drivers to serve our customers.
Jan 08, 2011 | Gigabyte GA-K8N Pro-SLI Motherboard
Ibm motherboard pro300a_afp bios update
Go to the Bios's Manufacturer's website, they will have it, get the update, and instructions to update.
there is a Specific procedure to follow.
Hope this helps
Regards.
Apr 16, 2009 | Computers & Internet
I have IBM p6 motherboard with processor Intel 1.8ghz/256/400/1.75v Processor had demaged. I replaced with Intel 1.8ghz/512/400/1.525v When I starts the system it gave error "0167 no processor bios...
I suggest this is not going to work.
1.Your motherboard is supplying 1.75 DC volts of electricity to the processor socket.
You have installed either a SSpec number SL68Q, or SL62P,
Intel Pentium 4 processor. (The sSpec number is on the top of the processor case)
These Intel Pentium 4 processors use 1.425 to 1.525 DC volts of electricity. If you haven't already, you are going to burn this processor up.
Also, the Intel Pentium 4 that you had before, is based on the Willamette Core. (180nm) These earlier Pentium 4's did not have HT.
Hyperthreading Technology.
The Intel Pentium 4 you have in it now, is based on the Northwood Core. (130nm) These Pentium 4's come with HT.
Even if you could go into your BIOS Setup utility, and change the CPU voltage, and lower it, the HT in the processor you have now, wouldn't work on this motherboard.
(CPU stands for Central Processing Unit. Another name is Microprocessor, or simply -> Processor)
You won't be able to lower the voltage in BIOS Setup, for this processor. IF you did, then you would change the Front Bus Speed, and the ram memory wouldn't work.
Solution?
Obtain an Intel Pentium 4 processor, that uses the Socket 478 processor socket, has a 400MHz FSB, and is based on the Willamette Core.
Here is a list of Willamette Core, Intel Pentium 4 Microprocessors, that will work,
http://en.wikipedia.org/wiki/List_of_Intel_Pentium_4_microprocessors#.22Willamette.22_.28180_nm.29
Apr 13, 2009 | IBM (25P3294) Motherboard
I HAVE CHANGED MY PROCESSOR 600MHz TO 933MHz. NOW I HAVE A PROBLEM THAT MY COMPUTER IS HANGED AFTER 3 OR 5 SECONDS. MY CPU MANFUCTURED BY GATEWAY INTEL CHIPSET 810.
Is your motherboard support that kind of processor?
Do you run it with the previous installation with the old processor, which is in the harddrive? Its best for clear installed so that all settings are configured to your new setup. Your new setup remembers the old processor.
Sometimes setting the bios to default and reconfiguring it once again solve the problems.
Apr 13, 2009 | Gateway INTEL i810 P3 SOCKET 370 BRYANT...
No processor bios update
Sounds like you need to flash the BIOS (UPDATE the BIOS).
Do you know how to do this? The way I do it is by setting up a USB key as a boot device and have the FLASH utility on there....
HERE IS A LINK
which contains files to create the FLASH utility either on:
FLOPPY
CD (via ISO IMAGE)
... as well as some guides on what to do and other helpful stuff.
Its worth noting that if you have made any changes to BIOS, they will be restored to the 'factory' settings when you FLASH in the updated BIOS.
This should work, let me know if it doesn't.
Mar 27, 2009 | IBM (09N5424) Motherboard
JetwayV266b (REV: 3.00) - Max processor speed??
Design ATX form factor 4 layers PCB size: 30.5x24.4cm Chipset VIA KT266A/VT8233A Chipset CPU Socket Support AMD Athlon 700MHz∼1.4GHz processor Support AMD Athlon XP 1500+ 2600+ processor Support AMD Duron 600MHz 1.3GHz processor Support 200MHz/266MHz (Double Data Rate) Front Side Bus frequency processors Reserves support for future AMD processors 2600+ is the highest it will go. http://www.machspeed.com/manuals/VIPER/V266B.pdf page 3
Sep 17, 2007 | Jetway V266B Motherboard
Computers & Internet Logo
382 people viewed this question
Brian Sullivan
Brian Sullivan
David Payne
David Payne
