Question about Ricoh Aficio MP 1600L Black and White Copier
Procedure for executing new toner - Ricoh Aficio MP 1600L Black and White Copier
  • 165 Answers
Just put a new 1 in and close the door
Posted on Nov 04, 2010
Pls show me how to reset Triumph-Adler DC2018 error code c6400
Thanks alot. It really worked for me, i mean the reseting procedure of menu>service sett>press #+start button+enter same time>enter 163>enter>go down to Execute>click start button. Then Restart machine. Wait a little so it adds toner then say 'ready to copy'. Hope somebody finds it helpful too
Apr 17, 2018 | Office Equipment & Supplies
My printer will not load the toner. Its said the toner was low, so I replaced it with new toner and now it will not load. HELP!!!
you had to go into sp mode....then go to drum function.....tap the
execute .....the pcu will automatic mix the new toner and will reset the teh copier/printer sensor.....now dear Jocelyn,do you know how to enter the sp mode........
Sep 12, 2013 | Ricoh Aficio AP3800C Laser Printer
Ar 5618
The blinking CH means that the Developing cartridge not installed.
Here is how to correct the issue:
1)Turn OFF the power of the machine.
2)Open the front cover.
3)Install the developer unit and toner cartridge.
4)Turn ON the power of the machine with the cover opened.
5)Enter Sim25-02. (Entered value display section: "CH" is displayed. Start LED: OFF)
6)Close the front cover. (Entered value display section: "--" is displayed. Start LED: ON)
7)Press [START] key to execute Sim25-02.When [START] key is pressed, the main motor rotates for 3 minutes to determine the toner sensor reference value and clear the developer rotation time as well as to clear the developer counter.When the operation is completed normally, the ATC sensor reference value is displayed on the entered value display section. If an error occurs, one of the following indicators is lighted. LED Misfeed indicator Paper required indicator This simulation must be executed only immediately after installing developer, Do not execute this simulation for any developer which has been used. If the machine goes into the warm-up state before completion of this simulation, there is a possibility that toner may be supplied to the developer during warm-up. In such a case, therefore, the developer must be replaced with new one.
Jun 14, 2013 | Office Equipment & Supplies
Hp laserjet printer one side too light printing.....just like a wide line up to down.....
Check if the toner is low.
1. Pull the toner cartridge out and move it gently (up/down - left/right)
to spread the toner in the cartridge.
2. Execute the Cleaning procedure (Menu).
3. If the problem persists, exchange the toner cartridge.
Aug 16, 2011 | HP LaserJet 1320 Printer
Call for service u2-40 sharp ar 275
CRUM chip communication trouble = the chip on the toner cartridge is faulty.
1, Try to clear the code press P, *, C, *, to enter the service simulation, on the key pad press 1,6, then the copy start, press execute on the screen.
2, Change the toner cartridge.
If it is a brand new one return to supplier as faulty, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 16, 2010 | Sharp AR-275 Copier
I have a sharp ar-235 what does call service code U2-40 mean
If it is a brand new one return to supplier as fault, if it is a refilled new one take back to supplier (the CRUM chip serves as a genuine supplies protection for sharp and 'blows' when the toner is empty the re-filler will have to put a new chip on it)
Nov 04, 2010 | Sharp AR-235 Copier
New toner loaded but shows load toner mssage Toner execution failed
here are some tips for you to check on:
1/ check your copy counter,if it is already 120,000 copies and you have not yet replace the OPC unit then you should.........
2/ the toner holder bottle unit is not working properly,need to be checked and cleaned...some time the safety cap is not open for toner to be feeded to the OPC unit.........
3/be sure that you follow the instruction of how to install the toner bottle,
4/if the problem is still there??? your toner motor needs to be replaced......
enjoy the experence!!!!!!!!!!
Nov 03, 2010 | Ricoh Aficio MP 1600L Black and White...
Have a fresh K toner cartridge and had to change the K drum. Now the printer displays the message that the toner is empty, and it is not. How do I reset or correct this?
try this reset procedure - it works on a C5250.
1.Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100%.
Oct 20, 2009 | OKI C5200n Laser Printer
Needs maintenance
Maintenance doesn't necessarily mean developer replacement, if its working well, ignore developer and continue if it requires, pullout the developer unit and remove the toner hopper. Then empty the used developer and put new one. To empty, turn the dev unit upside down while rotating the magnet roller clockwise the return it in normal position and pour the new developer while turning the magnet roller clockwise until evenly distributed. Put back the toner hopper and screw back and install inside the copier then set it with 'P, Interrupt, C, Interrupt keys enter 25 press Start 2 then Execute key and allow to run till it stops then press Interrupt twice and Press 24 Start 3 Execute . Finally Switch OFF and ON.
May 07, 2009 | Sharp AR-407 Copier
Error message says toner cartridge empty, but it is not empty
I am not certain this procedure will work with your model, but it's worth a try:
1. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100\%.
Jan 03, 2018 | OKIDATA - 91615001 Printer
Ricoh Aficio MP 1600L Black and White Copier Logo
19 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
aaron douglas
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
