Question about Ericsson Cell Phones
My sony erisson W580i is being realy weird. When I try to press the menu button it says, "Configuration error. Please contact your service provider or service center". The only way I can read my messages is if somebody texts me first so that i can access my inbox, and the only way I can access my phonebook is if I hold down a number on the keypad. Earlier today it said I had no access to network, whatever that means. So, I restarted my phone and this problem occurred. Could you tell me what I need to do in order to fix this?
    Guru:
  • 458 Answers
Your phone software (firmware is messed up). try to reset your phone, if that doesnt work, then take it to a service center and have it flashed
Posted on Jun 13, 2008
840,01 scanner disable error. how to solve it
This message indicates that the scanner has been disabled cannot be used. The MFP must be powered off and then press and hold the check and the right button and turn on the printer to access the configuration menu
1. In the configuration menu, use the arrow keys to scroll to the Disable Scanner menu item.
2. Press check button.
3. Use the arrow key to scroll to the desired setting. The options are Enable ADF/FB, Disable ADF/FB, Disable ADF only, Auto Disabled. (Please select Enable ADF/FB)
4. Press check button.
5. Press BACK button.
6. Scroll to Exit Config Menu.
7. Press check button. The device restarts.
8. Try running a copy from the ADF and flatbed.
For further assistance, please contact Lexmark Technical Support.
Jul 30, 2011 | Lexmark X364dn All-In-One Laser Printer
Dynamic menu error. I cant open my phone menu. What would I do?? It says 'configuration error. please contact your network operator or service centre.
To get the phone working again, you need to download a W200i EUROPE_2 custpack (depends on your phone's package). You have to create folders that go tpa then inside the tpa folder, a folder named preset then inside that folder, a folder named custom. So, it goes tpa/preset/custom with the customize.xml ..., in the custom folder now zip it up so you have tpa.zip, put it in the MISC box and press flash.
Jan 21, 2010 | Sony Ericsson W200i Cellular Phone
My sony erisson mobile ringing volume low how can increase
go to menu,ringtone settings,then go to ringtone volume and adjust it according to ur need,u can use side buttons for this also.
Dec 05, 2009 | Sony Ericsson w580i Cellular Phone
Display not working and the screen is all black...
You need to replace the LCD as you've already taken it apart you should be able to replace the lcd yourself
May 08, 2009 | Sony Ericsson w580i Cellular Phone
I have a Lexmark E352dn printer. The screen showed that the Photoconductor needed replacing which I have done. However the screen still shows " 84 Replace Photoconductor " I have removed and...
the problem is that you need to reset the counter of the photoconductor unit. From the official site of lexmark, i find this solution.
Step Action 1 Enter the printer's Configuration menu:
  1. Power off the printer.
  2. On the printer's operator panel, press and hold the select button (pattlnk_11202006_2142-select_button.jpg) and the back button (pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif).
  3. Power the printer back on while keeping both these buttons held down.
  4. When you see the messages Performing Self Test or Busy on the printer screen, you can release both buttons.
  5. If the printer has successfully entered configuration mode, you will see a new menu with the heading CONFIG MENU at the top of the screen.
2 Press the right arrow button (pattlnk_4122007_1837-right_arrow.jpg) until you see Reset PC Cnt. Press pattlnk_11202006_2142-select_button.jpg once. You will see Reset. Press pattlnk_11202006_2142-select_button.jpg again.
The printer will display a Resetting PC Count Value message and go back to the previous screen.
3 Press pattlnk_4122007_1833-back%20button%20e350_e352_e450.gif once. 4 Press pattlnk_4122007_191-left_arrow.jpg or pattlnk_4122007_1837-right_arrow.jpg on the operator panel until you see Exit Config Menu. Press pattlnk_11202006_2142-select_button.jpg once. Selecting this will cause the printer to reboot.
If the counter has been reset correctly, the printer should return to a Ready prompt.
5 If this does not clear the PC Life Warning or Replace Photoconductor message, power off the printer and attempt this entire procedure again. If the error remains after two attempts, confirm that:
  • The correct photoconductor unit is installed. The part number on the photoconductor unit should be E250X22G. If it is not, install the correct photoconductor unit into the printer.
  • The photoconductor unit has not been refurbished by a third party or is not damaged in any way. If the photoconductor unit was refurbished by a third party or appears to be damaged, try replacing it again before seeking service on the printer.
If the error persists, the printer may require service to correct the issue. Contact Lexmark Technical Support for more information.
Dec 02, 2008 | Lexmark Office Equipment & Supplies
Please help me...
you need to reflash the firmware on the phone.
Apr 01, 2008 | Sony Ericsson K800i Cellular Phone
Configuration error
You need to flash the phones firmware. You can try the Sony Ericsson Update Service, Wotanserver or take it a place that specializes in flashing or service point. There is no other solution...sorry...
Dec 20, 2007 | Sony Ericsson W550i Cellular Phone
Configuration error
i got sony ericsson w580i. i can't operate my mobile as on screen shows "configuration error. pls. contact your network operator or service centre" i did contact my network operator but confirmed that my sim is in usual working state. i can only listen to call but i cant go to main menu,neither i can listen to song. even i cant able to make call. pleasehelp me
Aug 01, 2007 | Sony Ericsson W550i Cellular Phone
Cell Phones Logo
53 people viewed this question
Top Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you an Ericsson Cell Phone Expert? Answer questions, earn points and help others
