Question about Braun Health & Beauty
How do I get my toothbrush charger repaired - Braun Health & Beauty
  • 17,130 Answers
Some of them are sealed units and can be repaired only by breaking it open. If this is a cordless type then the transformer can be faulty. It is also possible that the winding of the inducction coil on the hand held is also faulty. If corded type then a replcement adapter can be suited with the saem volt/amp specifications.
Other option is to get the replacement from the dealer.
Posted on Nov 03, 2010
My pursonic S450 sonic toothbrush has a UV sanitizer. After about 6 months, the light quit coming on every time. Now it comes on very infrequently. I cannot find a web site for them. Can someone help?
Alas, I can provide a manual:
http://www.qvc.com/footers/fth/pdf/V32069_Manual.pdf
And I can let you know if you contact customer service for the product, you well may end up sending $10, a form, and a request for a repair if within warranty. The alternative may be $40 to Amazon:
Pursonic S450 Deluxe Plus Rechargeable Sonic Electric Toothbrush with...
A wild guess is that the charger is failing or there is a loose solder connection, neither of which is easily fixed via DIY (although there is a video related to soldering repair on a competing brush) and the cost of having a tech fix it outside of warranty is prohibitive considering what you can can pay for one.
Feb 07, 2018 | Sonic Health & Beauty
Philips sonicare essence 5500 doesn't stop blinking
Turn it on and put it on the charger while still on. This should turn off toothbrush. And it stopped the blinking!
Dec 11, 2011 | Sonicare Philips Essence 5500 Toothbrush
My sonicare toothbrush won't charge
The best tutorial for repairing Sonicare toothbrushes is here:
Repairing your Sonicare
The problem is either a corroded circuit board or worn-out Ni-Cad batteries. Both repair solutions require soldering, but full repair is possible.
Sep 30, 2011 | Sonicare Philips Essence 5500 Toothbrush
The toothbrush no longer holds a charge. The light on the toothbrush doesn't light up.
Hi!kindly check the battery of your toothbrush if it is good.And check also the charger of your toothbrush.
Sep 11, 2011 | Home
Our Philips Sonicare 5500 toothbrush recently stopped working completely. It will not charge no matter how long it sits in the charger. It is completely dead. Since it doesn't work at all I don't know...
Could be either. If you make a coil out of single insulated copper wire that sits over the charger post, you should detect an AC voltage across it if the charger is working, assuming it is the wire free type charging system.
Try about 20 turns for a volt or so.
Nov 27, 2017 | Health & Beauty
When i plug my phone into the charger it says "unable to charge", but it still can use it if it's pluged in ,but when i unplug it it powers off please help me!
hi nusscourteny take the battery out of the phone. Feel the battery and see if the batery is swollen in the middle. I want you to plug the charger into your phone and see if the charger is charging the phone. Ok now you can take a toothbrush and clean all the contacts and see if their is any corrision inside the charging port. Hope this helps. Cleaning the phone with a new toothbrush and a can air.
I’m happy to help further over the phone at https://www.6ya.com/expert/ronald_e152e07e272e4f27
Jan 03, 2011 | Motorola Mobility W385 Cellular Phone
My motorola l6 was not functioning the charging port....so right now i used a desktop charger? plz help
Have you tried carefully cleaning out the charging port with a soft toothbrush? If you attempt this please be very careful because the contacts in the charging port are easily damaged. Sometimes fluff and gunk can build up inside the charging port and the charger cannot make a good connection. If you do not want to attempt this you should take your phone to a reputable phone engineer or Nokia service point for repair.
May 20, 2010 | Motorola Mobility L6 Cellular Phone
MY PHONE DOES NOT CHARGE ON THE WALL CHARGER ONLY VIA USB ON THE PC. WHATS WRONG
If it uses a separate connection for the charger, try cleaning the contacts (a toothbrush works well for this) on the phone and the charger plug. If the charger plugs into the USB port on the phone, I's suspect a bad charger.
Nov 26, 2009 | Sony Ericsson XPERIA X1 Smartphone
Health & Beauty Logo
160 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
