Question about Sony DVP-NS300 DVD Player
My problem is this the player works ok and plays the first two or three chapters ok thats about 10 min. of play back time then it powers down and C 13 00 appears on the display screen. Can you tell me the problem. thank you
    Sergeant:
  • 202 Answers
There is problem with optical block assy you need to replaced it.After that problem it will fine.
Posted on Nov 03, 2010
Require a Unlock Code for region free
DVP 3618 - how to unlock region codes?
1. Power ON the DVD player with no disc inside
2. Go to the SETUP icon and press OK; next, go to
Preferences and press OK
3. With preferences highlighted,
3a. Press NEXT CHAPTER (button above AUDIO, it looks like
this: >'),
3b. Press PREVIOUS CHAPTER (button above SUBTITLE, it looks
like this: '<)
3c. NEXT CHAPTER >'
3d. PREVIOUS CHAPTER '<
4. The OSD will show the current Region Code
5. Press the Navigation Up or Navigation Down buttons to
select your desired region, or 0 for region free
6. Press OK to confirm your region selection
It works for DVP 3618 model.
Dec 04, 2013 | Panasonic DMR-EZ47V DVD Recorder/VCR
Hi, I am seeking the region free code for a Samsung DVD-D530? Thanks!
I tried the above steps, but each time when restarting the DVD player, it said 'reset' and asked for the language to be selected again. Pressing the "Fast Forward Fast Rewind Fast Forward Up Down" sequence caused the player to lock up and require powering off at the wall.
I found on another web site that there are different initial sequences. Once I use the one for Region 2, it worked fine.
I found the instructions below on another web site, but it worked for me...
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player). FF = fast forward, FR = fast rewind.
    • Region 2 players: FF, FR, FF, UP, DOWN
    • Region 3 players: FF, PLAY, FR, UP, LEFT
    • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
    • Region 5 players: FF, UP, DOWN, STOP, RIGHT
    • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen. The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Apr 30, 2011 | Samsung Televison & Video
After 10 min. of play time the dvd stops working
This is most likely a problem with the power supply to the drive motor. A component is breaking down and the supply voltage is dropping below operational levels after warming up.This is a problem that needs service in a service center or someone who is a experienced electronic technician to take apart the unit and test it for bad components.Hope this help you with your problems.
Mar 18, 2009 | Polaroid PDM-0742 Portable DVD Player
Wii's quantum of solace errors goeeting online and single player
This is what I had to do:
After it froze up, I turned off the wii by holding the power button for approx. 10 seconds. Then, I powered it back up and started Quantome of Solace. After loading my profile, instead of selecting 'continue', I selected 'chapter select' and it let me start from the chapter it was freezing on. It did not freeze this time during the intro movie. Hope that helps!!!
Jan 17, 2009 | Nintendo James Bond 007 in Quantum of...
My sony Mp3 is not working
I tried something and it seemed to work ( though how long it will lst I don't know ).
1. Let the battery go dead
2. Put the player in the USB port
3. Update with latest Flash Driver ( check the format option )
4. When finished, remove from the USB port WITHOUT disabling the port through Windows ( just pull it out )
5. Hold down the play button and keep it held down.
6. Navigate to Settings.
7. Go to Restart option and click ok. You have to be quick here since you have to release the Play button. Once you get to the next level , keep the play button pressed or else it will shut off
8. Once it says restart is complete, press power button to shut it off.
9. If you have enough power, give it a try otherwise plug it back in USB port for about 5 to 10 min to get a charge.
10. Remove from USB port the same way as before.
Nov 29, 2008 | Sony Walkman NWZ-B105F MP3 Player
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Code for dvd player dvd252
    Pioneer DVD player (DV-505, DV-525, DV-606, etc.) Note: Some codes work on LD/DVD combo players only, such as "Disc side A/B".
    Note: The LD/DVD 0525 code will work too, but the arrow keys (among other things) won't work without being keymoved to the correct codes.
    000 Chapter prev
    002 Pause
    003 Scan reverse
    012 Disc side A/B
    014 Random
    028 Power on/off
    029 Step/slow reverse
    030 Audio
    031 Exit?
    033 Menu
    034 +10
    035 Power off
    061 Power on
    062 Power on
    063 Demo (when player is off)
    064 Power on
    067 Reset (when player is off)
    076 Program
    077 Repeat A-B
    078 Disc side B
    080 Disc side A
    082 Enter
    084/086/088/090 Shuttle reverse
    085/087/089/091 Shuttle forward
    092 A/D/CX
    093 8
    097 9
    140 Return
    142 Last memory
    143 Up arrow
    147 Down arrow
    150 Subtitle
    156 Title
    157 Mode (set-up)
    158 Open/close
    160 Angle
    161 Condition
    162 Step/slow forward
    163 Chapter/time/frame search
    191 Chapter next?
    195 Chapter prev?
    196 Right arrow
    203 Left arrow
    204 Repeat
    205 Time search
    208 Clear
    209 Chapter search
    211 Display
    212/214/216/218 Jog reverse (w/still)
    213/215/217/219 Jog forward (w/still)
    220 4
    221 0
    222 6
    223 2
    224 5
    225 1
    226 7
    227 3
    252 Chapter next
    253 Stop
    254 Play (will turn on player and resume if player powered off)
    255 Scan forward
    Jul 11, 2008 | Televison & Video
    Annoying Resorting of files
    Not fixable - edit the id3 tags in a way that the alphabetical ordering will play in the order that you want them
    Dec 24, 2007 | iLO (2 GB) MP3 Player
    Region codes
    Philips DVP 3015K / DVP 3020 / DVP 3040 / DVP 3040K / DVP 5140 / DVP 5960
    1. Method 1:
    2. Open the disc tray
    3. Press SETUP
    4. Navigate to the preferences page
    5. Enter 138931
    6. Select the region using UP/DOWN
    7. Press PLAY
    1. Method 2:
    2. Open tray
    3. Press 9, 9, 9, 9, 0
    Dec 19, 2007 | Televison & Video
    Sony DVP-NS300 DVD Player Logo
    61 people viewed this question
    Top Sony Televison & Video Experts
    Jerry Greenberg
    Jerry Greenberg
    Steve Allison
    Steve Allison
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
