Question about HP Compaq Evo Notebook N600c
My compaq evo stopped working. For about two weeks I had a buzzing where I place the power cord. At that time periodically the whole thing would shut down. Also now it will not start at all and the battery stopped charging.
    Scholar:
  • 50 Answers
Allen -
It sounds as though you may have either blown the power supply, or burned the power circuit on the motherboard. That buzzing sound usually indicates an electric arc, where electricity passes through open air from one contact to another; In this case, it was probably caused by a loose or broken solder connection on the laptop's power jack.
If you can get your hands on an identical or equivalent power supply, test it with your laptop. If it works, then the power supply just needs to be replaced.
If not, try taking the battery out of your laptop, and plugging it in again. Sometimes, when a power supply burns up, the battery will discharge, rendering it inoperable.
Hope this helps!
-thinstatic
Posted on Jun 13, 2008
I have compaq evo N610c laptop, it works when plug power cable. battery also charging. but when i remove power cable computer shut down
Hi this may be due to your laptop battery problem. It may the time now to replace the battery of your laptop as it may go week now with time.
So very simple just go to any compaq service center and ask them for a new battery.
Nov 24, 2010 | Compaq Computers & Internet
Hello my compaq evo n610c don't start with power cord & battery
1>NEEDS TO TRY RESEATING OF THE RAM(SWAP THE RAM WHILE PLACING THEM BACK IN) AND THEN TRY TURNING ON THE COMPUTER
2> IF THIS DOES NOT WORK THEN NEEDS TO REPLACE THE MOTHERBOARD
BEST OF LUCK
Feb 08, 2010 | HP Compaq Evo n610c Notebook
Compaq evo N610c working fine until a few months ago when Wlan w200 started having problems. I was getting blue screen of death when ever I had internet connection for a small period of time (about 40...
dear sir good day this problem used to appear when a bad driver is installed or a damaged windows in near so reinstall your system as Microsoft says in this article http://technet.microsoft.com/en-us/library/cc957609.aspx thank you
Dec 27, 2009 | Compaq Evo N610C Notebook
Compaq Evo D510 errors
the RAM may be corrupted or not properly installed into the slot. also check if the processor fan is working properly.
Nov 19, 2009 | Compaq Evo D510 PC Desktop
Clock on my Compaq Evo N600c Stop running when shutdown, standby, and runs slow , I've tryed solutions from thier support site but still same thing I've even Changed CMOS battery
ok sometime cause you system been online sometime the sytem update your time online to a deferent rigion now disable internet time then set it manualy
Aug 28, 2009 | Compaq Evo N600c Notebook
POWER SUPPLIER PROBLEM OF COMPAQ EVO D500
look on ebay for used compaq power supplies.
Mar 02, 2009 | Compaq Evo D500 PC Desktop
Evo n400c
Did you charge it for up to 8 hours?
Caring for your Compaq Evo N400c Laptop Battery You can improve the life of your Compaq Evo N400c Laptop Battery by doing the following:
When you first receive your laptop battery charge it fully for at least 6-8 hours and then discharge the battery fully by using your laptop unplugged from the mains until it runs down completely.
Repeat this 3 times to ensure your Compaq Evo N400c Laptop Battery will give you the maximum performance.
If you regularly use your Compaq Evo N400c Laptop on mains power for extended periods, removing the battery from your Laptop during these periods will extend the usable life of your laptop battery.
Apr 05, 2008 | Compaq Evo N400C Notebook
EVO N600C 'S POWER SUPPLY
Sounds like the power adapter connector on the motherboard needs to be replaced. or soldered in tighter.
Mar 23, 2008 | HP Compaq Evo n610c Notebook
Powered off.
Any beeps when you turn it on? unplug everything and then plug it back in. Make sure the monitor connections are good and that you have it turned on. Again make sure it's turned on. Sometimes it's the simple stuff. Was the monitor working well before it failed? Do you have a video card?
Remove the battery, AC, count to ten and try one last time?
Jan 01, 2008 | Compaq Evo N610C Notebook
No power (Compaq EVO D310DT)
The problem could be almost anything pertaining to the motherboard. The battery just helps the system keep time when it is powered off. One easy thing to test is memory. If you have spare memory ofthe EXACT SAME memory type for the computer, try putting it in and see if the computer boots. It could also be the power supply. If you have a spare one lying around then you could try replacing it. Other wise, you will need to replace the entire motherboard. If it comes down to replacing the motherboard, make sure that you get the exact same type as a replacement so that all your other components and peripherals will work.
Sep 20, 2006 | Compaq Evo D300s (269124-051) PC Desktop
HP Compaq Evo Notebook N600c Logo
80 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
