Question about Canon LV-S3 Multimedia Projector
No power light, won't turn on
I loaned my LV-S3 to a friend and when he returned it it doesn't work. Before I make him buy me a new one, I need some help. The power light does not come on at all. Is there an internal fuse that could have blown? If the bulb is out, will this projector not work at all? I do not want to buy a bulb if that won't fix the problem. Please help.
  • korale Jul 08, 2008
    hi! did you solve the problem? cause i have the same? i guess there is a fuse which you can change easily inside the lv-s3. i you already have a solution, please share. thanx. korale
  • Richard81 Jan 04, 2009
    After sending the projector back to Canon, they charged me $250 to reset the button. I wish I would have received this response sooner, but thank you very much. I will know what to do next time. Thanks again.
    Richard
>>> SOLUTION 1
THANK YOU sooooo SO MUCH,
i woke upthis morning and tried to turnonthe projector(i usually useit for gaming) and found that it wont trun on, i followedYOURadvice though because i knew it was a heating problem and lo and behold i heard the fatefulPOP as i pressed down on the switch and it now works!!!! thank you soo so much!!!!! you SAVED ME
Posted on Jan 03, 2009
Based on Best Solution posted Sept. 3rd 2008, I was able to resolve the problem I had with my projector. I was beginning to think that I needed to junk it or just bang it around as a last resort, but just at that moment I discovered a the posting that lead me to a quick positive answer.
Thanks A Million I was beginning to miss it.
AJ
Posted on Jul 08, 2009
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}Okay Ifound the problem.
My LV-S3 suddenlystop working, with the power cable plugged in and everything
There is nolights what so ever, Just completely dead and wont turn on at all.
I spoke toa person that fixes canon projectors.
He saidthat the LV-S3 is a very compact projector (and it is in deed) It builds upheat and has a protection system inside.
It’s a heatactivated thermal switch that needs to be reset.
So this ishow you go about it.
The LV-S3has 2 thin silver plastic sides that you need to lift out with a smallish flat screwdriver,it just lifts up and slides out.
Very easyto take out , underneath the to plastic slides there is 2 screws on each side,remove them, there is also another screw on the back of the PJ that
You need toremove.
Carefullylift the cover off, Note there is a cable connected to button control panel onthe cover to the rest of the PJ.
You don’t needto remove any screws that holds the board and everything else, about in themiddle there is a black switch hiding underneath the
PC board,close the where light bulp sits, mine was coverd by a black spacer sponge that Ineeded to remove, just pull it its glued.
The switchis black with a pin in the middle with a white dot in the middle, press it witha screw drivers tip, If you press it and it goes down.
Then youknow that it popped out and did over heat and you are in luck, close everythingand switch on.
Hope thishelps.
Posted on Sep 03, 2008
  • admk69 Jun 07, 2011
    Fixed my problem of it not starting - THANKYOU. symptoms were turning on then off in warming countdown at about 25sec. the button that has the white dot is not on the green board it's to the side of that. The button is about the size of a tictac pointing upward on top of another barrel shape about five times it's size. it was under clear plastic in my Canon LV-S3 projector, to the left of the green board looking at it from the back. hope that helps as I had trouble finding it.
Meant to say cant find any fuses sorry for the confusion
Posted on Sep 02, 2008
Hi. I also have a LVS-3 and its not turning on at all.
Ive opened it up and can find fuses, I'm not amaized because the power supply is not based on a transormer but more like a PC Powersupply, using a bunch of components to get voltages to the correct amount.
Any way
I spoke to someone that repairs canon projectors apparantly if you take out the bulp there is a termal reset switch that pops out or something if it over heats.
I cant confirm as i'm going to try this tonigh.
I'm the third with the same problem! An older projector of  mine had the same symptoms when a filter was ajar, and another time (and projector) this happened with a fuse.
This is happening to me now with the LV-S3, and I cant figure it out!
Is there a fuse inside somewhere deep?
please share any solution! -yum
Posted on Aug 05, 2008
3 Suggested Answers
SOURCE: Canon LCD Projector LV-S3
i want cheap projector
Posted on May 04, 2008
  • 144 Answers
SOURCE: Canon LV-S3 casts a purplish cloud.
yes this happens all the time with lcd projectors, after a while lcd becomes distorted and bad,unfortunately you cant fix that (well thats what i know of anyway).
Posted on Jan 31, 2010
Purchase Canon LV S3 bulb
the Original lamp for LV S3
USD100
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Apr 02, 2014 | Canon LV S3 Lamp
Galaxy s3 won't turn on fully
Hello Sarah,
You can try these solutions:
Solution 1: Soft Reset(no data loss)
  1. Take out the battery and leave it there for 5 minutes.
  2. Reinsert the battery.
  3. Press and hold the power button for 10 seconds.
Solution 2: Replace Battery
  1. Take out your battery
  2. Insert new battery that you found from a friend or family with same model.
  3. Power on
  4. If it works,buy a new battery
Solution 3: Hard Reset(you will loose your data)
  1. Switch off the device.
  2. Press and hold Volume Up + Home Button + Power Key.After 2-3 seconds, release the Power Key.
  3. You will enter boot screen,use volume buttons to navigate and select Select Wipe Data / Factory Reset and then press power key.
  4. Select Yes.
  5. Reboot your device and wait to power on.
If nothing works you have to take it to your supplier.
Nov 28, 2013 | Samsung Galaxy S3
Green light on. computer wont turn on
Unfortunately, if the light is on, but the computer won't power on, it means one of two things. Either the power cord is broken in some way and no long sufficient to power the computer, OR the motherboard is dead. You can try to purchase a universal cable from Best Buy for instance, and then return it if it doesn't solve your problem. A motherboard repair would be best done through Acer themselves, although, it can cost over $300.
Aug 23, 2011 | Acer Aspire 5735 Notebook
Jan 15, 2010 | Canon LV-S3 Multimedia Projector
Optoma h 27 will not power on at all. New lamp still not working.
Never heard of a heat reset. If the unit is completely dead. investigate lamp, and or lamp door interlock switch.
May 18, 2009 | Canon LV-S3 Multimedia Projector
Warning light
Thanks for help .. I'm looking for Drivers & software Canon LV-S3
Nov 07, 2008 | Canon LV-S3 Multimedia Projector
Warning light stays solid on
The same problem as mine, is there a Canon technical support to help us fix this problem.
Dec 28, 2007 | Canon LV-S3 Multimedia Projector
Canon LV-S3 Multimedia Projector Logo
871 people viewed this question
old marine
old marine
