Question about Sony Ericsson K550i Cellular Phone
Restart?? my cellphone is K550i... My problem is, when i scroll down some of my phonebook entries, it will restart... i mean it will turn off and on again.... dnt know whats the cause... is this virus? or some inappropriate programs... tanx for the help
  • AliGD Jun 23, 2008
    inappropriate programs... tanx for the help - exact same problem as Want2die
  • 23 Answers
Below are some helpful tips on what to do if you cannot turn your phone on. If, after trying the solutions below, your phone still does not switch on, please take it to your nearest service center.
  • Press the on/off key for a minimum of 10 seconds to switch the phone on.
  • Make sure that the battery is charged.
  • Sometimes the battery must be removed to allow dust, dirt and corrosion to be cleaned from the connectors on the phone and battery. You can clean the connectors with a soft brush, cloth or q-tip moistened with any type of unflavored, colorless alcohol. Make sure the battery is totally dry before you put it back.
  • Also, check for damage to the phone connectors. If you have an original Sony Ericsson battery and your phone says "alien battery", the cleaning procedure may help you correct the problem.
  • If your phone has a Memory Stick™, remove the Memory Stick and try to switch the phone on. If it works, please take your phone and Memory Stick to the nearest service center.
  • If your phone vibrates continuously when you try to switch it on, please try to do an update using the Sony Ericsson Update Service.
if it keeps doing that i would take it to the store and get it looked at and see if there is a problem with the software
Posted on Jun 26, 2008
How do you put numbers into phonebook inan aspera f36.
To delete a number from the Phonebook
1. Press the Phonebook button to open the list.
2. Use the Up and Down arrow buttons to scroll thru the list to find the wanted number.
3. You now have 2 choices:
a) Edit the entry so that you create a new entry - Press the Menu/Select button then select Edit and enter the new information.
b) Delete the entry - Press the Menu/Select button then select Delete, wait for the phone to ask for confirmation, then select Yes
To create a new entry in the Phonebook - Press the Phonebook button to open the list, press the Menu/Select button then select Create New then enter the information.
Here is a link to the User Guide for your phone.
https://www.uniden.com/File%20Library/FooterNav/Product%20Information/Owners%20Manuals/D1760om.pdf
Aug 15, 2017 | Cell Phones
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
How do i delete numbers from my BT XENON 1500 phone
Delete an entry in the phonebook
1. Press Names.
2. Scroll to the entry you want.
3. Press Options and scroll to Delete Entry and press OK.
Display shows Delete?
Press Yes to confirm or No to cancel.
4. Press Back to return to the standby screen.
Jul 13, 2014 | Computers & Internet
How do i operate speed dial on razr
The user manual for the Moto Razr V3 is at: "V3 GSM Motomanual" Motorola http://www.motorola.com/mdirect/manuals/V3c_9496A74O.pdf
Pages 68-69 of the manual (which correspond to pages 70-71 of the PDF file) state: "Calling With 1-Touch Dial To call phonebook entries 1 through 9, press and hold the single-digit speed dial number for one second. You can set 1-touch dial to call the entries in your phone memory phonebook or the SIM card phonebook: Find the Feature M> Settings > Initial Setup > 1-Touch Dial Press To 1 S scroll to the location you want 2 SELECT (+) select the location" Page 8 (page 10 of the PDF file) indicates that the symbols (represented by "M>", "S", and "SELECT (+)") mean the menu key, 4-way navigation key, and SELECT. Page 51 (pages 53 of the PDF file) explains how to store phone numbers in the phonebook -- which you can then call with 1-touch dial.
Aug 24, 2011 | Motorola Mobility RAZR V3
How do I delete a name and number on the BTHudson 1500.
Delete an entry
1. Press Nam es. Scroll to the entry you want and
press Select.
2. Press MENU and scroll to Delete entry and press
SELE CT, then OK to confirm.
3. Press Bac k to return to standby.
Delete Phonebook
1. Press Menu. Phonebook is displayed. Press Select.
2. Scroll to Delete all and press select.
3. Delete All? is displayed press OK to confirm or bac k
to cancel.
4. Press Bac k to return to the previous menu.
for full manual please follow the link below :
http://www.shop.bt.com/content/uni2/documentation/693m/bt_hudson_1500_user_guide.pdf
May 17, 2011 | Computers & Internet
Need to delete phone entries in the Phonebook
Hi. Not sure if this will help but on my Panasonic cordless phone (different model to yours), there's a button labeled "mute/clear" which is used to clear text when entering text for phone entries. Well, if you scroll through you phone book to the the entry you want to delete and then rather than pressing "Edit", press "clear" and, if it's like mine, it will ask you if you want to erase the entry, and you press "yes". Hope it works for you.
Jun 24, 2010 | Panasonic KX-TG5621 Phone
How do you set the speed dial phone numbers on the Clarity D613 amplified cordless DECT
Clarity D613 Cordless Telephone
SPEED DIAL INSTRUCTIONS
To set, replace, or delete one of the nine Speed Dial numbers:
1. If you want to set or replace one of the Speed Dial numbers, and the new number is not already an entry in the phonebook, add the new phonebook entry before continuing here.
2. Press the PHONEBOOK button. The first entry in the phonebook displays.
3. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
4. Press the UP/DOWN buttons (right side of the handset) to scroll to SPEED DIAL.
5. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
6. The SPEED DIAL menu is displayed. If you do not want to make any (more) Speed Dial changes, press the BACK button until the HANDSET number displays, and stop following these instructions.
7. Press the UP/DOWN buttons to scroll to the KEY number that you want to set, replace, or delete; for example, KEY 4.
8. Press the MENU button. A phonebook entry appears. It is either the entry, if any, that is currently associated with the selected key or it is the first entry in the phonebook.
9. Press the UP/DOWN buttons to try to scroll to a different entry in the phonebook.
10. If you are able to scroll through the phonebook, the selected key is not currently associated with any phonebook entry and you have two options:
a. To leave the selected key without an association, press the BACK button and return to step 6.
b. To associate the selected key with a phonebook entry, go to step 16.
11. The displayed phonebook entry is currently associated with the selected key. If you want to leave it that way, press the BACK button and return to step 6.
12. Press the MENU button. A menu displays with two items (ADD and DELETE). By default, the ADD item is initially selected.
13. If you want to associate a different phonebook entry with the selected key, press the MENU button (to choose ADD). The first entry in the phonebook displays. Go to step 16.
14. Press the UP/DOWN buttons to scroll to DELETE.
15. Press the MENU button. DELETED displays. The selected key is now not associated with any phonebook entry. Return to step 6.
16. Press the UP/DOWN buttons to scroll to the phonebook entry that you want to associate with the selected key.
17. Press the MENU button. SAVED displays. The selected key is now associated with the selected phonebook entry. Return to step 6.
To call one of the nine Speed Dial numbers:
1. Press and hold the desired Speed Dial key (1 through 9 on the dial pad). The selected key number displays. If the key is associated with a phonebook entry, the call begins within a few seconds. Otherwise the phone beeps twice.
2. Release the key. If the key was not associated with a phonebook entry, you can either press the BACK key to return the phone to standby, or you can press the CLEAR key and then press a different Speed Dial key..
To review the phonebook entries that are associated with the Speed Dial keys:
1. Press the PHONEBOOK button. The first entry in the phonebook displays.
2. Press the MENU button. The first two items (VIEW and ADD) of the seven-item PHONEBOOK menu display.
3. Press the UP/DOWN buttons to scroll to SPEED DIAL.
4. Press the MENU button. The first two items (KEY 1 and KEY 2) of the nine-item SPEED DIAL menu display.
5. Press the UP/DOWN buttons to scroll to the KEY number that you want to review; for example, KEY 4.
6. Press the MENU button. The associated phonebook entry appears.
7. Press the BACK button.
8. If you want to review more Speed Dial associations, return to step 5.
9. Press the BACK button until the HANDSET number displays.
Dec 27, 2009 | Clarity Lands Phones
TomTom GO 930 remote can't scroll entries in phonebook
I have (had!) the same problem as you and I found this thread:
http://www.tomtomforums.com/tomtom-go-920-920t-930-930t-940-950/19455-remote-control-arrow-buttons-dont-work.html
I downgraded to the 8.302 version and the problem is solved!
Jacques
Jul 30, 2009 | Tomtom GO 930 GPS Receiver
How to add calling card 800# and PIN to expedite LD calling.
When storing a calling card access number and your PIN in the
phonebook as one phonebook item, press {PAUSE} to add pauses after the number and PIN as necessary. Or, if stored as separate entries, during a call, press MENU, press 1 to select “Phonebook”, and scroll up or down to find the entry and press Call. Repeat to dial other numbers.
May 17, 2009 | Panasonic GigaRange KX-TG5432 Cordless...
Transferring phonebook from phone to sim card
The razr that i had could only store 4 numbers on the sim card, your phone book is stored on your phone's memory not your sim. I'm pretty sure that you cannot transfer your phone book over to your sim card.
Apr 23, 2007 | Motorola Mobility RAZR V3
Sony Ericsson K550i Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
