Question about Durabrand STS92 System
Skaekers can i replace the end of the wire that plugs into the dvd player for another one???
  • 4,472 Answers
Do you mean the video out that goes to the TV? If so yes you can.
Good luck,
Posted on Jun 13, 2008
How to hook up my dvd player
if you want to hooked up your dvd player to a tv unit, you can use an rca connector. usually 3 wires for video and L/R audio. to connect with in the tv plug one end of the connector to the component input jack of the tv ( video/audio L/R ). and the other end of the connector just plug to the video/audio output jack of the dvd player.
Sep 17, 2012 | Televison & Video
DVD Player doesn't work???
It may be the yellow RCA plug ,which is the one that controls the picture is bad on either end. Try this. Unplug the red connector from the DVD player and the TV. Plug that red connector into the Yellow jack on the TV and DVD player.If that works it means the yellow wire is bad. Just go to Wal Mart or Radio Shack and buy a new 3way wire system. Check to see how long you want the wires to be as there are different lengths available.
Mar 12, 2010 | Samsung T260HD 26 in. LCD TV
Where can I buy a replacement ac adapter for my pvs 133 dvd player
Radio Shack sell universal AC adaptors. Just be sure that you select the correct voltage and that the polarity on the power plug is set correctly. Most AC adaptors will have the center of the plug as +, but not all. The Radio Shack universal unit allows you to switch the polarity of the plug by just changing how it's connected on the end of the wire. Incorrect settings could destroy your player.
Aug 18, 2009 | Venturer 3.6" Portable DVD Player
How do you install the frd03-dvd? mines came with no instructions.
Hello jeffery_armi,
The FRD03-DVD allows you to replace the factory head-unit and retain the audio and power to your OEM DVD player. With the FRD03-DVD, the audio from the OEM DVD player is connected to the auxiliary input of the aftermarket radio to allow the DVD audio to be heard over the vehicle's audio system.
The FRD03-DVD harness consists of a molex-plug, stereo RCA audio male connectors, and red and black wires ending in "pigtails".
1) Connect the molex plug into the OEM harness.
2) Connect the RCA audio connectors into the "AUX" inputs of your aftermarket head unit.
3) Tap the red "pigtail" wire into the "accessory" lead of the vehicle radio harness (also usually red).
4) Tap the black "pigtail" wire into the "ground" lead of the vehicle radio harness (also usually black). Alternatively, the black wire may be terminated with a ring terminal and secured to a metallic ground nearby.
Hope this helps.
May 13, 2009 | Pie Frd03 Aux/S
So, my 3 year old got a hold of my portable TruTech DVD player and now it doesn't work. There is a black ribbon thing when you open the DVD player, one end of it is hooked to something, but the other end...
The black ribbon thing is the wire harness to the optical laser of your DVD player. It normally has a connector that is plugged into a printed circuit board inside the player. It is best to have a technician plug it back in to test the unit. The laser of these units can be harmful to eyesight when operating a powered unit opened. The laser may also need to be "calibrated" or aligned. Hope this has been helpful.
Feb 27, 2009 | TruTech PVS12701 Portable DVD Player
Plug into Tv?
In your accessories kit that came with your DVD, you should find a cable with a red ,yellow and white RCA ends. at the other end is a 1/8 inch Tip /ring/sleeve plug. Insert the plug into the output of the DVD. Insert the yellow wire to the same color coded INPUT of your television, insert the red and white wires to the Audio input on you TV. Your DVD should be sending the signal directly to your TV. hope this helps . if it does , vote.
Dec 22, 2008 | Mintek MDP-1760 Portable DVD Player
Dvd hook up
Depending on what leads you have and what connections your equipment has depends on how you would wire it up for a basic setup you need a set of three male to male rca a leads consisting of a RED WHITE and Yellow plugs at each end. Now on the back of your dvd player there should be three female holes the same colou as your plugs and near those holes it should say input plug the leads colour to colour now the other ends of the lead plug into the section of your amp thats says dvd input with the same style holes as the dvd player. then you need to run another cable the same as you have just used to take the sound and picture to the tv you start of plugging one end into the amp where it says monitor or tv out and then at the other end of the lead will plug into the tv in A/V1 or A/V2 if the A/V1 is being used for a video player or camcorder Yellow is Picture Red is Right Sound Channel And White is Left Sound Channel so only plud the matching colours to each other or you will end up no better off hopefully this helped if you get stuck my email is
Mar 23, 2008 | Pioneer VSX-108
Dual xdvd700 want to permanently bypass e-brake
1. Ground the E-Brake wire.
2. Insert a DVD
Let it play until you hear sound
Press STOP twice on remote
Enter 26604
Oct 27, 2007 | Jensen VM9510 Car DVD Player
How do you connect a pioneer d2 navigation system to a 2006 ford expedition entertainment system
You need to identify the four wires that carry the DVD audio in the factory plug, and re-wire them to RCA plugs that can be used with the Auxiliary input RCA jacks on your Pioneer unit. The four wires should be: Left (+) light green Left (-) white Right (+) red Right (-) black The easiest way is to purchase some inexpensive RCA cables (or better yet, speaker wire with RCA ends). Cut the cables and wire the center pin conductor wires to the (+) audio wires in the stock plugs, and connect the outer shield conductors to the (-) wires. Then connect the RCA plugs to your head unit's auxiliary input jacks.
Aug 08, 2007 | Pioneer AVIC-D2 DVD Nav/6.5"...
Durabrand STS92 System Logo
23 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
