Question about HP Color LaserJet 2600n Printer
Some of the ink colours are very poor even though the cartridges are full, what can I do to fix it?
  • HP Master
  • 1,719 Answers
I received a similar HP Laserjet Color Printer with same issue for repair/ maintenance a few months back.
Actually the problem is with the printer design not the magenta cartridge and it needs professional hands for servicing and cleaning. The mirrors which reflect laser beam get covered with dust and toner. hence the image is not produced properly. note that first magenta goes off, followed by yellow, then cyan and lastly black. this is because of the mirrors placement inside the printer.
Rest assure that the printer requires ONLY CLEANING OF THE MIRRORS, which are inside the printer.
Clean them yourself with dry n soft cloth (if you are familar with such tasks) or get it cleaned by any printer repair/ service professional. Please note that the mirrors, lenses and scanner assembly inside such printers is extremely complex and can get damaged very easily especially the mirrors.
Hope it would help. If you need any help in cleaning mirrors and lenses let me know
Posted on Nov 03, 2010
  • oalsrouji May 14, 2011
    I have the same problem. Actually, the printer is not using the red color at all! I never tried fixing or cleaning a printer before, can you give me instructions to clean the mirrors myself? I will be as careful as possible.
I have bought new genuine Epson ink cartridges, installed them correctly and although the settings are recognizing that there are 4 full, genuine cartridges it is not printing any black ink. I have done a...
I know it sounds stupid but do you have the old black cartridge, if you do put it back and see if it is printing even if the quality is poor and faded. If it is then possibly there is a contact bad, try swittching the black cartridge for one of the other colour ones, but put a colour in to the black space but don't put the black into one of the colour spaces. If the colour one is working in the black space then it's basically a dud cartridge and bring it back to where ever you got it from. Hope it works for you - Pat
May 16, 2011 | Office Equipment & Supplies
Epson SX600FW - this will not print black even-though the cartridge is genuine and full. It will print the document in any other colour than black
You might need a reset as the B&W cartidge has not been detected. So to reset remove your printer from the PC and uninstall the printer software. Now reinstall the printer software and then connect the Printer to be detected and installed. Check printer properties to see the ink levels.
Use head cleaning before a test is taken . It is possible that the head is not reacting to the need of the command , can be an issue with ink drying , can
also be poor ink cartridge contacts
Apr 06, 2011 | Epson Printer
I am out of yellow, magenta, and cyan. I only want to print black. Is it possible to still print even though im out of those three colors? Both Black cartridges are full. The screen tells me that im out of...
I think that the Canon printers require the colour cartridge to be full so as to print B&W. In Some makes like epson it is possible to continue printing in B&W even if the colour ink is down.
Open properties of the printer and check to see the tools provided, if there is any link to cut off the colour inks .
Just my tip
Aug 30, 2010 | Canon PIXMA MP620 All-In-One InkJet...
Black ink won't print even though the cartridge is
It could be you just have a bad cartridge, If it's new, take it back and get a new one to make sure it's not the cartridge. If you get the new one and it still doesn't print black, then you have a bad print head. Meaning it would need to go to a service dealer to replace or repair the print head.
Thanks Mark
May 14, 2010 | Brother DCP585cw AllInOne InkJet Printer
Hp c7820 printer 02 black catridge
Open the printer and remove the ink. Clean around the ink carriage and the under the ink with alcohol and a cotton swab. Pay special attention to areas with copper contacts. Keep in mind too that some printers will not print, even with full ink, if the exact type of ink it expected you to have installed is not right. Double check that the ink is correct against the manual or written instructions inside the printer using the number not the shape or color of the cartridge. Not every cartridge that fits the printer necessarily works.
Nov 13, 2009 | HP Photosmart C7180 All-In-One InkJet...
Coloured ink not registering
You can only refill those cartridges if you do it before the ink is empty. After that you need a new cartridge or a chip resetter to reset the chip on the cartridge so it will work again.
Oct 12, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Will not print color
Check to make sure that the nozel for your colour cartridge isn't dried up. A cartridge could be full of ink but inable to release any if it hasn't been used in awhile. Also be sure that your settings in the printer control panel aren't set to monochrome/black & white.
May 06, 2009 | Office Equipment & Supplies
My printer is not printing the colour yellow even though the cartidge is full and new
If you have run the nozzle cleaning utility, and you are not getting any yellow output, the cartridge is most likely defective. This also occurs if you are not using OEM ink cartridges.
Apr 25, 2009 | Brother DCP 115C All-In-One InkJet Printer
Ink Cartridges
If is an original brand? Some generic cartridges or refill ones gave that problem.
Jul 06, 2008 | HP DeskJet 5150 InkJet Printer
Immovable Cartridge & Printing problems
try to remove the front cover of the printer is 2 screews or 3 and a few clips and whit a clean cloth absorb the waste ink from the waste tank, and this is o quik fix that i use.
Oct 18, 2007 | Office Equipment & Supplies
HP Color LaserJet 2600n Printer Logo
1,830 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
