Question about Echo CS600P Gas Chainsaw 20 Inch
BRAND NEW ECHO CS-600P HARD STARTING, HAVE TO PULL THE RECOIL LIKE 20 TIME BEFORE IT WILL START.
    Brigadier General:
  • 4,088 Answers
Are you pumping the primer bulb until fuel flows into the bulb, setting the choke, and the fast idle is being set? Set the choke at half position after the first 'pop' and don't touch the throttle until it starts running. If you are doing these things per the instructions, take the machine back for warranty adjustment. Hope this helps!
Posted on Nov 03, 2010
  • Bushwaskd Nov 14, 2010
    Yeah.. the Echo 600P has no primer bulb. Check your user manual, then take it to someone that can retune the carb they're set mighty lean from the factory.
Brand new Echo gt-225 trimmer wont start. What could be the issue?
brand new did you put gas oil mix in it?? did you follow the exact starting instructions on it? newer one seem to need to bne primed like 10 times and the throttle held open when pulling the starter rope. choke on??
Jun 25, 2017 | Echo Garden
Echo t330 chainsaw has compression lock cant pull start cord
remove your spark plug and try to pull over. if it still won't turn over then you will have to decarbon your head or you have vapor lock so then with plug removed pull recoil and if fuel sprays out of plug hole keep pulling over until there is no more spray from hole. clean plug off. reinstall and try starting
Oct 14, 2014 | Echo Garden
Chainsaw starter rope won't pull
Pull your spark plug to ensure it isn't a compression issue or even piston/rod damage. If it still doesn't move, pull off your starter assembly and try to rotate the fly wheel by hand. If it turns, then your issue is in your recoil spring kit. You can replace the unit, or try to disassemble and reassemble.
Jul 30, 2014 | Echo Chain Saw. 18 in. 40.2 cc Gas Chain...
I have a echo cs-341 only way it will start is if the muffler is off. any ideas? i did pull the screen still did not help. thanks
I guess the muffler is blocke inside with carbon, burn it out with a small gas torch, the carbon will burn and eventually fall out.
Jul 06, 2011 | Echo CS600P Gas Chainsaw 20 Inch
Pull start on my Toro snowthrower (snow master 20 - model #38020) it wont recoil itself. I removed the starter housing but can not figure out how to get the pulley and starter recoil spring out/off of the...
Its basically the same....best bet is to just buy the new pull start mechanism...they are pretty cheap, and they go bad on those units all the time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
Jan 12, 2010 | Toro Garden
Howdo I fit a new pull start cord on a ryobi 25cc
remove the plastic housing to gain access to the recoil. Pull the cord slowly all the way out,this will cause the spring to wind up.Clamp the recoil wheel so it will not return to its original position,be carefull the recoil has tension on it not remove the old pull rope and thread the new one in and thru the hole of the recoil tie knot.pull on the cord to take tension off and at the same time remove clamp. Slowly allow the recoil to wind the rope in and reinstall on unit.
Dec 15, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My echo pb2100 gas leaf blowers pull cord is loose and will not recoil
COULD BE THE SPRING INSIDE THE RECOIL NEEDS MAY NEED A NEW ONE
Sep 24, 2009 | ECHO, Inc. PB-251C Handheld Blower
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Echo CS600P Gas Chainsaw 20 Inch Logo
600 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Mike
Nick Olsen
Are you an Echo Garden Expert? Answer questions, earn points and help others
