Hi: My washer will fill anywhere from 1 to about 10 second when I release the start button. I've cleaned screens and water flow seams to be ok. Bypassed pressure switch with no change. What else should I check for?
Should check if there is good pressure at the inlet faucet. If good, then you have to replace your inlet valve, which is easy to do. First check to see if the wires to the valve are connected well.
When the power washer does not turn on, it is either due to no water flow or no electricity going to the power washer. In other words, either a water or electrical problem.
check water flow issue like this
The high pressure hose, spray gun and lance must be connected to the power washer.
The garden hose must be connected to the power washer using the garden hose adapter.
Turn the water completely on at the water faucet.
The power cord should not be plugged in.
Squeeze the trigger on the spray gun.
If there is water flow through the spray gun and lance shooting 10 - 25 feet, this confirms water flow is NOT the problem for the power washer not turning on.
If there is no water flow, perform the following troubleshooting procedures:
a. Remove the lance, squeeze the trigger. If water flows, the lance is blocked. Use cleaning wire to clean the nozzle tip and try again.
b. If no water flows with lance removed, turn the water off. Remove the spray gun from the high pressure hose. Turn the water on, if water flows, the gun is the problem. Reattach the gun, turn the water on and squeeze the trigger. Sometimes this unblocks the gun. If not, replace the spray gun.
c. If no water flow with the gun removed, remove the high pressure hose, turn the water on to make sure there is no blockage in the hose. This is very unlikely but we need to make sure.
d. If no water flows out of the water outlet, the quick connect garden hose adapter is problem. See Garden Hose Adapter troubleshooting.
For electrical solution check
The power switch was not turned on. Find the power switch and make sure the "-"side of the rocker switch is pushed down. "O" = Off and "¾" = On.
Next, make sure the power cord is plugged directly into an outlet and NOT into an extension cord. The directions do say not to use an extension cord.
Each time the power cord is plugged in to an outlet, the Reset button on the GFCI module must be pressed down to connect to electricity.
Check to see if the Reset button has been pressed.
Next, confirm the small plastic window below the Reset button shows RED in the window. The RED color is not a light but a RED screen that slides into the window when the Reset button is pressed down. Because it is not a light, it can be hard to see in low light. If you are unsure, press the TEST button down. If the GFCI was set and RED was in the window, you will hear and feel a "click."
The RED color must stay in the window once the button is released. This confirms there is electricity going to the power washer.
If the RED color goes away when the Reset button is released, there is NO electricity going to the unit. Try another outlet until the RED stays in the window.
Now if the unit turns ON for a second or two with the Reset button pressed and the power switched on, it is working as it should. All that is left to do at this point is to squeeze the trigger on the spray gun and the power washer will turn on. When the trigger is released, the power washer will turn off. This is due to the Total Stop System (TSS) that only turns the unit on when water is flowing through the power washer. When the trigger is released, water flow stops which the TSS sensed and immediately shuts the unit off. a) So to review, if the Reset button has been pressed and is holding and the power switch is ON, the power washer is supposed to start up for a second or two and immediately shut off. At this point all you need to do is squeeze the trigger; the unit will turn on.
there's a flow meter in the washer that could cause this part number WPW10110225 if you go here you can see it https://www.repairclinic.com/PartDetail/Flowmeter/WPW10110225/1381535
also check the screens on the water valve,it's telling you the machine thinks it's not filling with water or it isn't filling,also this could be a bad pressure switch or the computer board but if you order parts from repair clinic you can return them and you have 365 days to do this,so first thing check the screens on the water valve,shut down the water and remove the fill hose from the washer and see if there's any junk in the screen,if so you can clean off the screen and see what happens or replace the water valve,if that looks ok the flow meter is probably gonna be it so this might be the part you want to change out,i can't remember how to test the flow meter,i carry one so if i see this error i pop it on and see what happens and out of the three times i've seen this it was the flow meter.hope this helps you can google how to check it the instructions on the tech sheet in your washer isn't that good but you can check it out.good luck with your washer
FH
error code means low water inflow. In this error washer is not filling when the
fill valve opens.
To clear the error please follow the bellow instructions:-
Press the "Stop" button twice with your finger. This cancels the
cycle and stops the washer. Unplug the power cord from the wall outlet.Turn the
water shut off valves clockwise to stop the water flow to the washer through
the supply hoses. Pull the washer away from the wall enough that you can access
the hose connections at the back of the washer.
Set
a bucket under the area of the hose connections. Unscrew the hose connections
from the back of the washer. If necessary, use a pair of slip joint pliers to
help start the connections turning until you can turn them by hand. Set the
ends of the hoses inside the bucket.Inspect the screens on the inlet ports on
the back of the washer where the hoses connect. Sediment and other debris can
block these screens, causing fill problems. Clean the screen with an old
toothbrush.
Thread
the hoses back onto the washer. Look for kinks in the hoses. Kinks cut off
water supply to the washer which causes the FH error code. Once you connect the
hoses, turn the water supply valves counter-clockwise to supply water to the
washer. Move the bucket away from the washer and push the washer back into its
working position.Plug the power cord back into the outlet and start the wash
cycle again. If the FH error code comes up again, call a service repairman. If
the hoses have no kinks and the inlet screens are clean, there is a problem
with either the pressure switch or the flow meter.
Please get back to us if
you have further query else please accept the suggestion.
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
Select any one button except Power, Stop, and Stop.
Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
Select Whitest Whites cycle.
Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
Press Start to turn off the valve.
Press Stop or Power button to exit diagnostic test mode.
I was doing a search for infor on how to clean my affinity front load washer, and came across this infor and this did not work for me either, but when I turned my dial to rinse and spin then hit clean the clean option appeared.
hi there......wow !! your using a lot of water...sounds like you have a failed inlet valve resulting in water flowing continually into the machine.....remedy relace the inlet water valve
ALL WASHERS COME WITH SCREENS AT THE
WATER CONNECTIONS.DISCONNECT THE HOSES AFTER TURNING OFF THE WATER.THEN,CHECK THE SCREENS FOR MINERAL BUILDUP.CLEAN THE SCREENS IF
NEEDED AND GO FROM THERE.
this code will set for two reasons if the washer doesent start filling after 30 seconds or fills to10.5 gallons in eight minutes and the pressure sensor hasnt triped so time it and post a reply to your message letting me know which condition exist make sure your drain hose isnt too deep in your drain pipe as this will siphon water out as it fills and mke the washer think the second condition exists consult your owners manual for proper drain hose instalation
