Question about Microsoft Computers & Internet
Windows 7. Would only open PDF in Photo SHop. Changed it to Microsoft Office Picure Manager to see if it gave better result & now it does not wowrk & I can't change back to P-SHop.
  • 1,719 Answers
PDF is Portable Document Format from Adobe Acrobat
It is better to use Acrobat Reader. However, if you want to use PS for pdf files right click any pdf file and choose 'open with' - If 'Open with' command is not there right click holding shift key - then choose photoshop and check "use this program as default"
Hope it helps..
Posted on Nov 03, 2010
Can Microsoft Picture Manager v. 11.0 that was working great in Windows XP sp3 be configured to work in Windows 7?
Get to Properties for Picture Manager (e.g. if you have a desktop icon you can right clck and Properties will be the last choice on list) and the third tab should be compatability.
Click on the top most box to Run ... and it will enable prior Windows versioning. Pick XP SP3 (sixth choice). The pick OK or Apply.
There is a Help Me dialog that you can pick that will assist with settings if the above basic fix is not sufficient.
Oct 20, 2014 | Microsoft office professional plus 2013
Need to fix office 2007 from compatability
Windows 7 Office 2007 Minimum Requirements b> Microsoft Office 2007 isn't the latest version of the Office suite, but it is still useful for a variety of tasks. The software package includes programs for editing spreadsheets, working with documents, creating presentations and more. Office 2007 also includes a redesigned user interface that is more intuitive than previous versions. Chances are good your computer can run Office 2007 if you already have Windows 7 installed, but you should check the system requirements anyway to ensure a trouble-free installation.
Processor and Memory Your computer needs a 500MHz or faster processor plus at the very least 256MB RAM. You may need more memory if you wish to run multiple Office applications simultaneously. The Business Contact Manager in some versions of Office requires a 1GHz processor and 512MB RAM. Turning on the grammar checker in Word requires 1 GB of RAM. Hard Drive and Optical Drive b> Make sure you have at least 1.5GB of available space on your hard disk to install Office 2007 standard and 2GB for other versions. You also need a CD-ROM or DVD-ROM drive for installation. Monitor b> Your display should have a 1024x768 resolution or higher. Older 800x600-resolution monitors are not compatible with Office 2007. 64-bit Compatibility and Windows Updates b> Note that you may run the 32-bit version of Office 2007 on 64-bit versions of Windows 7, but you cannot run Office 2007 64-bit on 32-bit editions of Windows 7. Make sure your copy of Windows 7 is up-to-date for best results. Microsoft releases fixes and other updates periodically that address stability issues and other known bugs. You can use Windows Update, on your "Start" menu, to check for updates.
Compatibility center http://www.microsoft.com/windows/compatibility/windows-7/en-us/Details.aspx?type=Software&p=Microsoft%20Office%202007%20Professional%20Plus&v=Microsoft&uid=12&pf=0&pi=0&s=office&os=32-bit b> 2007 Microsoft Office System Requirements http://www.microsoft.com/officebusiness/products/technical-requirements.aspx
Feb 26, 2013 | Microsoft Office Professional 2007 Full...
How do i make microsoft office picture manager my default photo viewer on windows 7 starter?
if you right click on one of the photos select properties you will see what it opens with select change place a tick in the box always use this program to open these files a browse option might open if the photo viewer is not there
hope this helps
Jun 23, 2012 | Microsoft Computers & Internet
Can you give me an updated product key for windows 7 - MS Office Home/Student 2007. These posts are over a year old and these posted do not work. Help please.
I have/had this same problem while using MS Office 2007 in my lap top running an MS Vista system. I have the disc but for some reason the product key that came with it ceased to be recognized by the system. I contacted MS & they sent me a new PK which I entered & it took care of my problem. Now I tried to use either one of the PK's & they were not accepted. Contacted MS Tech Support
who helped me thru the free MSO 2010 download & all is OK. Hope you can achieve the same results
Dec 23, 2011 | Microsoft Office Professional 2007 Full...
I have Windows 7 Microsoft Word/Office etc. but cannot get Microsoft Office Publisher to enable me to make greetings cards.Before I changed to Windows 7 I used Microsoft Greetings.
Yo! i will direct you to a web site where you can download the latest Microsoft office for your system with all the office packages. please visit www.download.com for free download for your system thanks.
Jul 22, 2011 | Microsoft Windows 7 Ultimate for PC
Reduce photo file size
Open your photo using Microsoft Office Picture Manager.
Click on Edit Picture.
and Select Resize option and reduce your resolution and save the Photo.
It will reduce the photo size.
May 06, 2011 | Microsoft Windows XP Professional SP3 Full...
Microsoft office word 2003 on vista takes ages to open and close but seems to work ok once opened. Any ideas?
Vista is notoriously slow due to built in error checking during file access. Consider upgrading to Windows 7
Mar 04, 2011 | Microsoft Office Word 2003
I am unable to scan documents to pdf format. I used to be able to do with my old comuter with windows XP. Now I have a new computer with Windows 7. All I get is a photo format, but no Word, or pdf formats.
Advanced Word To PDF is a fast, affordable way to batch convert Microsoft Word documents into professional-quality documents in the popular PDF file format. Its easy-to-use interface allows you to batch create PDF files which can be viewed on any computer with a PDF viewer.
all the original text font, images, graphics, hyperlinks, layout and formatting are kept intact after conversion. it's available to add properties to the output PDF file,like the author, user password, owner password, allowed actions, etc.
http://www.advancedpdfconverter.com/products/wordtopdf.html
Oct 25, 2010 | HP Photosmart C6280 Printer
How can i resize images
Open the file with Microsoft Office Picture Manager that comes inbuilt with vista and 7. You can resize your image there.
Jun 29, 2010 | Microsoft Windows Vista Ultimate Edition
Open Questions:
HOW TO INSTALL OR UNINSTALL AOL DESKTOP GOLD IN WINDOWS OR MAC SYSTEM? AOL desktop gold is premium version software of AOL desktop where you get online streaming of video or music, send an email and watch a movie. All these you get it just in one place. A user can easily download and install AOL desktop gold in windows 10,7 or 8 but before download, it should fulfill minimum system requirement. At first, the system contains 512 MB free space in their hard drive. Other system requirements: • 1 GB RAM • Internet connection • Internet Explorer 7+ • 266 MHz or faster computer processor • 1024 x 768 or higher screen resolution recommended. To download AOL desktop gold just follow the steps : 1. Sign in to your My Account page. 2. Click My Services ' Subscriptions. 3. Click Get Started under 'AOL Desktop Gold'. 4. Follow the installation steps to install in their Pc. If a user wants to remove or uninstall AOL desktop gold from their pc. Just follow the steps as I suggest you below: Select startsettingsapps Choose the program and select option uninstall option. To remove an app you got from Microsoft Store, find it on the Start menu, press and hold or right-click on the app, then select Uninstall. We have suggested some ways above to install and uninstall AOL desktop gold in their window or mac pc. If you still find any trouble just talk with our AOL support toll-free number +1************ or just visit our webpage on http://mail-supportnumber.com/aol-desktop-gold.html
Jan 14, 2019 | Microsoft Computers & Internet
Computers & Internet Logo
32 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
