I have a router ASUS wl-520GC working fine since about 2 years.
I connect a laptop toshiba running vista without any issue since a long time.
I just reinstall vista after formatting my laptop. DHCP is enabled on therouter and network cards of my laptop are configured to obtain automatically an IP address.
When I try a wired connection, it's working and I get an IP 192.168.1.2.
But if i try a wireless connection, I see by typing ipconfig in a dos prompt something like:
autoconfiguration IP 169.254.X.X
So I don't retrieve an IP address from the DHCP server.
Does somebody can help me ? What's wrong ? Your help should be appreciate.
Best regards
JMC
1. Hardwired your computer to the router.2. Go to Command Prompt and type ipconfig. 3. Get the Ethernet adapter Local Area Network Default Gateway. 4. Open Internet Explorer and type the Default Gateway. Type admin for username and password. 5. Click Wireless Tab and change the wireless password.
1.Log into router 2. Verify wireless router name( on the computer) >>> ( on/off) 3.Note router name you are connecting to. 4.. Check the laptop do ipconfig /all to see current IP addresses. This is done at the command prompt. 5. Set the laptop up in the router by WEP KEY or MAC address. enter router by either 192.168.0.1 or 192.168.1.1 depending on the router instructions set. 6.Note router name you are connecting to. 7. Move the laptop about 20ft away and try to log on to the internet. This is for all routers to set up wirelessly.
-- who is your internet service provider -- what is the operating system of your computer? -- is this working fine before or is this a brand new router
you may try this and see if this help solve your problem. make sure that your computer is directly connected to the router
Step 1: Shutdown the computer. Step 2: reset the router while power on then Unplug the router’s power cable. Step 3: Unplug the Broadband modem’s power cable and wait for 30 seconds. Step 4: Plug in the Broadband modem’s power cable and wait for its lights to appear stable. Step 5: Plug in the router's power cable once the modem’s lights appear stable. Step 6: Power on the computer on and configure the router settings Step 7: test the Internet connection.
if this still didnot work, upgrade the firmware of your router
With this particular router you will need to treat the port range field as the port field. You will just have to forward single ports at a time. Which will be fine. In case you need more reference see the link below.
The default IP address is 192.168.1.1 The manual is here: http://support.asus.com/download/download.aspx?SLanguage=en-us&model=WL-520gC Have you used the setup CD?
