Question about GE (PSS26MSRSS) Side by Side Refrigerator
I recently cleaned behind my side by side ge refrigerator and I now hear a constant loud humming noise. It can be heard when you are in another room
  • 593 Answers
Pull it out again and with it running (making noise) look at the fan to see if the fan blade is hitting the bracket.
Posted on Nov 03, 2010
  • GE Master
  • 2,699 Answers
Take off the bottom back panel of the fridge,there's a condenser fan in there,something could have jammed into it when you cleaned and the fan motor is humming because it can't spin,check this right away,this is what cools down the compressor if it's the problem
  • Sal De Aug 30, 2014
    if the fan motor is bad you can leave the bottom panel off and put a regular window fan behind the fridge and blow it onto the compressor,it will keep it cool,you won't loose any food and keep it like that until you get the new motor to replace the damaged fan motor
My Hotpoint makes a high pitched humming noise all the time.
This noise is most likely coming from the evaporator fan motor that is located behind the panel just below the ice maker. There is an air duct that the fan blows through to cool the ice maker that is why the sound is heard in the ice maker area more.
The noise does not hurt anything but the motor can be replaced if it gets too annoying, it is a fairly common complaint. The part number for the motor is WR60X10185 and runs about $60.00. It is a bit challenging to get to but can be done with a bit of patience by removing everything in the freezer and taking the back panel off the inside of the freezer.
Apr 18, 2010 | Hotpoint HSS25GFP Side by Side...
Our GE side by side makes a terrible humming noise. We've cleaned out the ice maker and cleaned out behind & under the fridge.
the fan in the freezer porbebly tuching something (ice..) or the fan next to the compressor tuch something ... check it out ...
Jan 02, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator is making a rather loud humming noise. It is still working fine, just noisey.Is this a problem? By the way, its only two years old. It is a GE model #GSH25JJTA SS
pull the unit away from the wall and see if the motor is gummed up with dust. motor is behind unit on the bottom. if it is, clean it off with a tolit brush. if its clean and still humming thats your motor making the noise. call a repair man.
Jan 02, 2010 | GE Refrigerators
Loud humming noise
Stick you hand in the freezer, touch the back wall of freezer, see if you feel a strong or lite vibration equal to the hum you are hearing. If so, the you have a bad evap fan, if not then pull unit out from wall and see if hum is load toward the bottom rear portion of the frig, if so contact a repair tech.
Oct 01, 2009 | GE GSS25JEMWW Side by Side
A side by side GE refrigerator with a loud hum
Hello Kchoffman73,
It sems we developed the same problem.
The hum seems to be coming from the bottom rear of the
fridge.
we have a GE side-by-side model TFX25JR.
The fridge is about 12 years old.
Whats the status of your fridge ? Did it ever stop
humming ? Did you replace or repair it ?
Does it still work ?
Thanks
Sep 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Loud buzzing/Humming noise.
I have a Amana ASD2622HRW Lately there is a loud buzz that comes and goes. We cleaned everything and blew it out under and behind the fridge. And it still is happening. Any suggestions? It still cools fine. But this Buzz is so loud that you can hear it through the house. Please help!
Apr 24, 2009 | Amana ASD2622HR Side by Side Refrigerator
Loud humming noise as fridge is running
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
LOUD HUMMING NOISE
Here's my thoughts:
Make sure it is level.
Could be some things inside the fridge vibrating against each other.
Geno
Feb 09, 2008 | GE GSS25SGSSS Stainless Steel Side by Side...
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
GE profile side by side refrigerator
In this Video Im Replacing Evaporator Fan Motor.
Sep 03, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
274 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
