Question about Nintendo DS Lite Console
Shaking sound All of a sudden I hear a shaking sound how do i fix it.
  • Ed Perez
    Ed Perez May 11, 2010
    Is your DS working after that shaking noise?
    The piece making noise can be a circuit board part so recover it in case you need to reinstall.
  • 114 Answers
If it does it when you move the DS around, then it has been dropped and there is little itty bits of plastic crawling around when it's moved. So what you can do is take it apart like a laptop, unscrew the bottom first. If you can get a crack open, you do not have to continue any more. Just keep it open a crack and remove the plastic. Put the screws back, and the shaking noise is gone.
Posted on Jun 13, 2008
92 Thundebird 3.8...starts hard....really rough idle in any gear...sounds loud. Almost feels as if the engine is shaking
run fault codes and look for position sensors --MAP/MAF/VAF sensor problems and fuel /injector faults.
Jan 06, 2014 | 1992 Ford Thunderbird
05 dodge grand carsvan cam sensor and crank sensor came on i fixed them but still shakes when i hit the gas at 50mphs or so help any in f will help
your shaking could be a bunch of stuff. the procedure is to verify whether you are looking at a motor shake or a transmission shake, then inspect the plugs,wires, cap,rotor, do a compression test and a vacuum test to eliminate the basics like rings and valves. If you know that all those things are good, then you plug into the computer and look at sensor readings. "my car shakes" is a very vague statement. I had a service writer once who loved to write that the vehicle makes a strange sound; then I would test drive the car and I would hear ten strange sounds; so which one am I supposed to be fixing? Is your shaking definitely coming from the motor?
Mar 05, 2013 | 2005 Dodge Grand Caravan
I have a 2002 pontiac sunfire 4door, many problems. heater not blowing hot air, replace thermostat still not working. temp rate keeps going up like's it's gona over heat. when i drive over 60 front end...
You may want to check the water pump if it's overheating, have the motor mounts checked if the vehicle is shaking and the alignment and tire pressure are fine, first check the fuses for the interior lights. As for the clicking sound in front tires - please provide further explanation as to the sound, speed of vehicle when it happens, and mileage on the vehicle - could be the CV's but not enough information to assess.
Jan 05, 2011 | 2000 Pontiac Sunfire
My mobile is nokia 3110classic.suddenly i got a sound problem.i cn't hear sounds outside.but am ble hear them through ear phones.i.e am unable hear songs as wells am not able to hear my ring tone...
The problem is with your "Ringer" (the bigger speaker). If you can hear the sound through your ear piece, then replacing the Ringer/Speaker will definitely fix your problem. I would suggest to get it done from a service center or from a mobile repairing shop.
Good luck.
Thanks for using FixYa.
Jun 25, 2010 | Nokia 3110 Cellular Phone
Car shakes at 55 and up
My first inclination would be to have tires balanced, unless it started suddenly, or you feel or hear something different in steering.
Feb 04, 2009 | 2001 Saturn L-Series
1988 olds delta 88 royal brougham 3.8 engine shakes and shimies.
Your brake booster may be leaking or the check valve on the vacuum hose going to the booster may be bad. Do you hear a hissing sound coming from the booster when you push the petal? Check these first before tearing down your engine. Good luck. Please rate me so I know how I'm doing. Thanks.
Dec 30, 2008 | 1988 Oldsmobile Delta 88
Steering problem
when turning you hear the sound? yes it may be a tie rod, cv shaft and or alignment issue. and as for the shaking... check your tire balance.
Dec 13, 2008 | 1997 Pontiac Grand Prix
No sound
Check the volume settings, try to fix or replace the headphones, or send it somewhere to get it fixed.
Mar 12, 2008 | GPX MW3836 MP3 Player
Kx-tg5632
Time for warranty replacement??
Sep 28, 2007 | Panasonic KX-TG5632 Phone
Nintendo DS Lite Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
