The DVD/CD unit has disappeared from "My PC" menu.
The problem was solved.
Thank you very much for your help!!!
Roberto Vera, from Chile
  • Anonymous Jun 19, 2008
    My dvd drive icon has disappeared and there is also a 'code 41' on my nec 6500a drive. Any suggestions please ? Ryan, England .
  • 3 Answers
Try this link, you will satify with the solution because my laptop used to have the same problem. Good Luck
http://www.fixya.com/support/r380953-missing_dvd_cd_rom_drive_letter
Posted on Jun 19, 2008
How to reset to factory conditions without a remote a panasonic SAHT74
While stopped and "DVD/CD" is the source, press and hold [STOP] on the main unit and [>10] on the remote control until "INITIALIZED" disappears from the TV. Turn the unit off and on again. All settings will return to the default values. (This does not work during program and random modes, or when setup menu or START menu is displayed.)
Oct 08, 2013 | Progressive DVHE210 210 DVD Player
Matshita DVD-RAM UJ8A2AS Fails to Read CDs/DVDs
You probably fubar'd the drive when you attempted to uninstall the bios. Only the hands of an experienced drive specialist can help you.
May 14, 2013 | Computers & Internet
Matshita BD-cmb uj-120 not present anywhere on my acer aspire 5920g yet its the default cd/dvd drive! help please.
Use HIREN CD. See if there the cdrom is working. If it's working, it's a problem with your windows. Reinstall and you will solve this. If Cdrom doesn't work even in Hiren - change the cdrom unit !
Apr 15, 2013 | Computers & Internet
CD menu is displayed ROOT Mode Normal Folder How can I watch the CD
Hold the stop button for 10-20 seconds and the unit will reset. This will solve the problem.
Sep 06, 2012 | Cyberhome CH-DVD 300 DVD Player
Hi, my DVD-RW keeps disappearing from "my
Hi, There is nothing wrong with your CD/DVD drive.
Your Registry is corrupt. Now you are missing the Upper or Lower filters(or both) on your CD/DVD drive.
Try System Restore and here's a Microsoft article on the subject.http://support.microsoft.com/kb/314060
regards, sathyamoorthy
Nov 14, 2010 | Acer Aspire 5100 Notebook
Cd drive is not opening
Uninstall the driver from Device Mgr, then go to registry editor, browse to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}
On the left hand side delete the Upper and Lower filter. Restart the PC and reinstall the driver. You may also create new user account if issue continues.
Regards,
Shrey
Oct 03, 2009 | HP (dc197x) CD-RW/DVD-ROM Combo Drive
Disappearing DVD driver
Use device manager to remove the dvd/cd unit, and then reboot the computer. Vista will locate the unit and install the driver.
It is possible that the dvd/cd unit has failed and requires repair or replacement
Jul 05, 2009 | HP Compaq Presario V6000T 15.4" Notebook...
Is there a way to unlock my panasonic scpt660 Five-DVD Home Theater System? please help.
The following is what "Panasonic" recommends:
While stopped and “DVD/CD” is the source, press and hold [∫] (Stop) on the main unit and [S10]
on the remote control until “INITIALIZED” disappears from the TV. Turn the unit off and on again.
displayed.)
You can access this PDF at www.static.tigerdirect.com/pdf/panaconic-SC-PT660-manual.pdf
Scribd.com suggests the following: Open the dvd drawer, press 9,8,1,7 on the remote. Press enter until it shows region 9 then press RETURN.
Hope this helped!
May 29, 2009 | Televison & Video
NEC DVD+-RW ND-6500A disappeared from
Log on to Windows by using an account that has administrator rights and permissions. Then, follow these steps. Step 1: Start Registry Editor loadTOCNode(3, 'resolution'); Click Start, click Run, type regedit, and then click OK. Registry Editor starts. Step 2: Delete the UpperFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click UpperFilters.
Note An UpperFilters.bak registry entry may also appear. To delete the UpperFilters registry entry, you must click UpperFilters and not UpperFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the UpperFilters registry entry: Are you sure you want to delete this value?The UpperFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey.
Note Do not exit Registry Editor. You must have this program for the next step. Step 3: Delete the LowerFilters registry entry loadTOCNode(3, 'resolution'); 1. In Registry Editor, expand My Computer, and then expand HKEY_LOCAL_MACHINE. 2. Expand SYSTEM, and then expand CurrentControlSet. 3. Expand Control, and then expand Class. 4. Under Class, click {4D36E965-E325-11CE-BFC1-08002BE10318}. 5. In the right pane (topic area), click LowerFilters.
Note An LowerFilters.bak registry entry may also appear. To delete the LowerFilters registry entry, you must click LowerFilters and not LowerFilters.bak. 6. On the Edit menu, click Delete. 7. When you receive the following message, click Yes to confirm the deletion of the LowerFilters registry entry: Are you sure you want to delete this value?The LowerFilters registry entry is removed from the {4D36E965-E325-11CE-BFC1-08002BE10318} registry subkey. 8. Exit Registry Editor. Step 4: Restart the computer this should solve your problem
Jun 07, 2008 | Computers & Internet
Start Menu, icons disappears except wallpaper & my DVD drive didn't work.
Trojan Horse virus still exist in partition files and you should format entire HDD with Disk-Manager-2000 or some thing like that. After format, reinstall Win XP.
I been faced such problem few months back and that was effected solution.
May 31, 2008 | Sony (1-796-293-13) Plug-In Module DVD...
Computers & Internet Logo
468 people viewed this question
David Payne
David Payne
