Question about Dell OptiPlex GX260 PC Desktop
After formatting my computer.i cant adjust the screen resolution ,i think i need the driver to help me fix this problem,but i don't know which drivers i should get and where
    Sergeant:
  • 358 Answers
Here is the web for download your driver Techbelkin please rate me.
Posted on Nov 03, 2010
I HAVE A PROBLEM WITH MY SCREEN I RECENLTY FORMAT MY LAPTOP AND THE SCREEN IS NOT NICE SO I WANT TO KNOW WHERE I CAN DOWNLOAD SOMETHING TO FIX THE SCREEN CZ THE DISPLAY ADJUSTMENT ENDS ON 800 BY 600
Most likely the correct video driver is not installed since you have reformatted your hard drive.
You should Google the model and find out what type of video card is in the computer then find the driver and install it to gain access to higher resolutions. At least assuming you had them prior to your formatting the hard drive.
Dec 03, 2012 | Computers & Internet
Cant change screen size
If the computer will not let you adjust the screen resolution go to dell's website and search your computer model. Download and install the latest video/graphics driver for your computer. That should fix the issue.
Dec 03, 2012 | Dell Inspiron 640m Notebook
How to enlarge my laptop screen space
Check this site http://www.dell.com/support/drivers/us/en/19 it's all the drivers for your laptop. Make sure you have all the video drivers installed. That should help with the resolution issue. Also, make sure the rest of your drivers are up to date. Reinstalls almost always set you back a few years in drivers. Good luck!
Jul 17, 2012 | Dell Inspiron 5100 Laptop
Suddenly my screen resolution got huge. how do i go back?
Go: Start -- Control Panel -- Display -- Settings -- To the upper left it says Screen Resolution. Adjust this upward and click "Apply". You may have to toy with it a few times to figure out which one it is actually supposed to be on. But don't worry, there is nothing there where you could mess anything up - after all...its already messed up. :-)
Anyway, if memory serves, going up gives you finer resolution, which makes things smaller. If you get there and its already all the way up, over toward your right, then my memory is backwards.....so just take it the other way.
And look at this as a blessing. You'll know more about your computer than you did. And - its a useful thing to know because if you ever plug your computer into a larger screen (like your TV), you will need to make adjustments here at this screen.
If this is helpful to you, please take a sec to rate me. Thanks!
Don
Mar 24, 2012 | Acer Computers & Internet
I have pentium 4,model is old 6 years,and I have LG Flarton w 2230s monitor,and I cant see a full image on my display,borders are shorter for 4cm in both side,maybe my graphic card is old?
I think that you have the wrong resolution set on the computer.
1/ Right click on the background part of your screen, click on settings, look at the screen resolution, adjust the screen resolution for wider setting.
2/ Try downloading the latest drivers for you graphics card and installing them.
3/ If you have a cd with drivers for the monitor install them and that will be fixed.
Or you may need a later model graphics card.
Jun 27, 2011 | Computers & Internet
Display on AcerX223W now has side margins and does't fit screen
i think you need to format
i hope i can solve your problem
Aug 26, 2009 | Acer 22" X223w LCD Monitor
My screen resolution is stock at 640x480 and i cant adjust it.. how will i adjust my resolution to fit my monitor.. and when i open my cam its getting darker and all the pictures even in friendster or...
Install graphic driver .
If already installed then uninstall old driver then install again.
when you power up the computer pressF8 key then enter in enable vga mode then change screen resolution to 1024*768 then aply and ok
Jul 23, 2009 | Computers & Internet
Cant adjust video resolution onboard videocard failed installed jaton trident videocard cant adjust above 800 600 screen resolution
Try downloading the most recent drivers for your new video card from the manufacturers website, that should get your resolution problem fixed.
May 03, 2009 | Computers & Internet
Invalid format message when trying to use the RGB(PC) port
Honestly, that sounds like one of two things happened. Either the resolution of your computer video card changed or (I'm not sure with your specific TV) the TV's resolution changed.
If through the TV menus you can adjust PC resolution, I would try changing the resolutions. In the LG 47LB5DF TV, press Menu, then go to Picture, then go down to Screen. On the screen menu, you will see Resolution, Position, Size, Phase, and Reset. First try adjusting the Resolution to some of the options you see. If that doesn't work, try to reset the screen settings.
If adjusting those settings on your TV does not help, then you will have to change the resolution through the computer. Try connecting a monitor to the computer. If you get a picture through the monitor, on the desktop right click and select Properties. If using XP go to the setting tab, if using Vista/7, select Display Settings. Lower the resolution to something you think the TV will be able to handle, then connect the PC to the TV again. If you are using an HDMI connection to the TV, you may have to turn off the computer, connect the cable, then turn the computer back on with the TV on the correct input.
If the monitor doesn't show the picture or if you don't have another monitor, you can try adjusting the picture in safe mode, by pressing F8 after you press the power button, before you see the Windows loading screen. Press if multiple times if necessary. You should see a screen that gives you a few startup options. Select Safe Mode. After Windows boots up, you should still see the screen as the resolution would have been reduced. From there try changing your display settings.
Hopefully that info has helped. I noticed that you asked this question 2yrs ago, so I hope you have already figured out how to fix your problem. I simply wished to post this in case it would help you or anyone else had a similar problem. Good luck and take care.
Dec 15, 2008 | Philips Magnavox 42MF521D/37 Television
Adjusting Screen Resolution
closing this work
if you need more information, just let us know
Jul 29, 2008 | 3M Vikuiti eXtended Resolution Video...
Dell OptiPlex GX260 PC Desktop Logo
49 people viewed this question
Alun Cox
