5-1/2 inch floppy diskette reader
I have a large collection of inherited 5-1/2 inch IBM floppy diskettes that were readable on the old 386 PCs. Where can I find a device that will allow me to read their contents into a current Mac (G4 type) computer, preferably via USB port?
  • 35 Answers
Good luck reading them at all ...
due to the media the data will go away after time specialy if they have been packed in boxes against one another.
that is just fact.
but you can find drives at flea markets ebay an df computer shows.
Posted on Jun 13, 2008
DO YOU HAVE ANY USB FLOPPY DISKETT GRIVE ??
this is fixya,we are not an order store,contact an ibm company
Apr 08, 2015 | IBM USB Portable Diskette Drive (05K9276)...
Reader for a square format 5.25 IBM formatted disk?
You can purchase an old 5.25 disk drive that will fit into any PC that has an open bay or swap out the smaller one for the 5.25 one.
Almost all computer shops have lots of them still around.
Mar 27, 2014 | Verbatim 30 Datalife Plus Md2-d Ds/dd...
I have a usb portable diskette drive that says compatabible upto windows 98 I have windows 7 can I download drivers for it?
If it won't plug and play then your basically out of luck. That is a very old device. If you still need to access floppy's i would purchase a newer device or have an internal floppy installed.
thank you,
Lee
Jul 26, 2011 | IBM USB Portable Diskette Drive (05K9276)...
The IBM portable diskette drive...will it work with any PC based laptop or only the ThinkPad?
yes it is. it a universal device that you can plug and play to any pc. as long as there is no conflict.
Jun 06, 2011 | IBM USB Portable Diskette Drive (05K9276)...
Need for IBM USB Portable Diskette Driver for windows 7
Any "plug-and-play" device with a USB interface should be supported by Windows XP/Vista/7/8. Try it!
Nov 12, 2010 | IBM USB Portable Diskette Drive (05K9276)...
Have bought a second hand IBM USB Portable Diskette Drive. It worked just fine at the sellers place. Now that I try and use my own PC I load a 1.44 Mb diskette and it tells me to load disk ??? What to do...
Hi Graham,
Your Portable USB 3.5 diskette drive uses a pretty old technology that would come with software or drivers needed to run it. You would need to check on your device manager on control panel. But I would advise you upgrade yourself to better storage devices like the flash drive or the CD/DVD USB portable drives. They are a bit more expensive, but the technology is newer and have less issues. Let's face it, the 3.5 diskettes are getting pretty outdated. Don't you think so?
Cheers & Kind Regards
Sep 24, 2009 | IBM USB Portable Diskette Drive (05K9276)...
Metal sleeve
3.5" FLOPPY DISKETTE
Below we have represented a picture of the now commonly used 3.5" floppy diskettes. The below representation is what the back of a floppy diskette looks like. As you can see there are four main visible parts:
floppyd.gif First, the top left of the back of the floppy there is a small tab. This tab enables the floppy disk to be switched from write protected and un-write protected. Move the tab to the top position, creating a hole, makes the disk write protected. This means that nothing can be written, erased or deleted from the diskette. Moving the tab to the bottom position allows the disk to be un-write protected, which means the diskette can be written too, erased, and or have information deleted from the diskette. Some diskettes, which are generally cheaper diskettes, will be missing this tab. To write information to the diskette you will have to place a piece of scotch tape over the hole.
Second, the top right hand of the back of the floppy you will notice a small hole. This tells the computer if the diskette within the computer is a High Density diskette.
Third, you will notice the circular metal disk in the middle of the floppy diskette. This is used to rotate the magnetic medium within the floppy disk casing.
Fourth, you will see a metal door which can be moved left and then will snap back to its original position. This door is used to allow the read/write head within the floppy drive to have the capability of accessing the magnetic medium within the casing. Once the diskette is removed, this door will snap back into position, helping to prevent anything from getting on the magnetic medium and destroying it.
5 1/4" FLOPPY DISKETTE
Below is a representation of a 5 1/4" floppy commonly used in 1980's and is generally no longer used today. The 5 1/4" floppy diskette was really floppy (flimsy) when compared to the 3.5" floppy diskette.
floppyd3.gif As you can notice in the above illustration, the 5 1/4" floppy does not have many involved components. First, you will notice the Write protection tab which would be present if the diskette allowed information to be written to it. Placing a piece of tape over the hole or if the hole was not present would make the diskette write protected.
Second, you should notice the large hole in the center of the floppy diskette. This hole allowed the platter within the floppy to be rotated allowing the information to be read from the write access hole.
Third, you should notice the Index hole, this hole was the computer's way of knowing where the starting point of the sector was on the diskette by physically having a hole punched in the film disc within the plastic casing.
Finally, you should notice the write access hole. This is the location which information would be read from as the disc within would rotate. However, because there was no protection like that found on the 3.5" floppy diskette, the 5 1/4" floppy diskette was generally protected by placing it within a protective sleeve.
Hope this helps ya/Let us know ,ok Thank you for using fixya.com.Please dont for get to Vote.
Jul 20, 2008 | Dell Inspiron 6400 Notebook
IBM 3.5 Diskette/1.44 MB Capacity/IBM Formatted. Won't open.
replace the floppy drive it sounds as if the drive motor is bad the hum is a inactive drive motor when a floppy is good it will usualy click as it comes on along with a green indicator llight
Dec 09, 2007 | Maxell MAX556437 3.5" Diskettes, IBM...
Televison & Video Logo
336 people viewed this question
Top Televison & Video Experts
