Question about Samsung LN-S4692D 46 in. LCD HDTV
Samsung 4692 Issue
Can you please give me some more instructions for replacing the T-Con board. How do you access it and any precautions?
I Replaced mine and it did not fix the problem. Bt its located at the top center and has asilver cover over it. It was not hard to change it took me about 30 min.but like i said it did not work.
Posted on Jun 25, 2008
  • jwclawn Jun 28, 2008
    I got no help from this site whatsoever. I guess they only help if you pay!
I have a Samsung TV model UN50H6350AFXZA which has sound but no picture. Backlights work. Replaced t-con board with new one, but not fixed. What next?
Main board. T con board is only involved with video issues. Main board goes both ways and since you already replaced the T con board that is your only alternative. U got backlite so inverter board is good.
Nov 13, 2015 | Samsung Televison & Video
Samsung LN46B650T1FXZA has vertical lines. What part needs to be replaces? Thanks, Nina
This might be a bad T-Con Board. This is the board that is in the middle top side of your TV. It connects to your main board (with the hdmi inputs) to the LCD Screen. Your TV has a major issue with the T-Con Board going back. The T-Con for that TV is avaialble here 55 46T03 C11 Samsung Con Board for LN46B650T1FXZA
Jul 23, 2011 | Televison & Video
Do you know the part number for the t con board.. samsung 32'' model number-LN32A450C1DXZC VERSION-CN03 Is the t con board easy to replace?? Any soldering or desoldering??
It is easy to replace, no soldering require, just have to carefully remove the delicate ribbon cables between the LCD panel and the T-CON, T-con and the main board.
It is mounted under the metal shield.
Please make sure to maych the part number as printed on the board. I look at thsi pleace but the number you have given did not quite match.See;
http://www.shopjimmy.com/catalogsearch/result/?q=Samsung+LN32A450
What do you see on the screen anyway?
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com just make sure to use caps with low ESR, 105c rating such as PANASONIC FM or FC series.
Please post back what you find.
Dec 04, 2010 | Televison & Video
The screen is white.power is on, simply no picture, white screen
Hi:
This could be cause by one to two areas of the unit, first the T-CON board may be bad and second the main system board has failed. The t-con is used to produce the picture on the screen it gets its data from the digital board or system control board. The screen is white because the inverter board is working to light up the lamps.
Aug 17, 2010 | Samsung LN-S2651D 26 in. LCD Television
MY SAMSUNG LNT3242 PICTURE IS GIVING ME CRAZY COLOR AND LINES I CAN SEE THE TOP OF MY MOVIE OT TV CHAN NEL BUT THE REST IS CAZY
It can be the T-CON board, main board, or worst case the LCD panel itself, it will require in-depth troubleshooting and will require some board swapping to narrow down the problem, not much for DIY repair.
http://s807.photobucket.com/home/budm/allalbums
Aug 16, 2010 | Samsung LNT3242H Television
On my samsung , Whenever I turn it on all i see is random vertical lines and eventually (like 2 Hours) I get a picture. as soon as i turn it off starts up again, any hints? Kiedrow
Either the T-CON board or the main board itself, check the connection between the main and the T-con bord first.
Aug 06, 2010 | Samsung LNR238W 23 in. LCD Television
Samsung LNT4071 no picture after half hour of used
If you get just grey glowing screen (look at it in darkened room), then it can be the T-CON is not getting the 12v from logic board or the logic board is not sending the 4 pairs of the the LVDS (Low-Voltage differential Signal) to the T-CON board, you will need the scope to look at the LVDS. You can try coolin ght T-CON board with freeze spray used for electronics troubleshooting to see if the pictures will come back.
Jul 17, 2010 | Samsung Televison & Video
Samsung LN52A550 lcd tv has verticle colored lines on about 40% of right side of screen
I have a similar problem. I have vertical colored lines in the middle and right side of the screen is black. Here is the photo. Do you guys think it is the T-con board?_853.jpg
Jul 05, 2010 | Samsung LN52A550 LCD TV
Sound but no picture and not a samsung lol
Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.The Tuner board,the board that recieve the tv broscasting signal.
Jun 30, 2010 | Polaroid FLM-2632 Television
Samsung LNS 4692 lcd tv t-con board
The fuse is located just upper right to the connector that attaches to the main board. This is a SMD pico fuse that is rated for 3 A @ 32 V DC that protects the Vin bus. Replacing the fuse may not fix the problem as it has most probably opened because of failure of another component.
Jul 26, 2008 | Samsung LN-S4692D 46 in. LCD HDTV
Samsung LN-S4692D 46 in. LCD HDTV Logo
47 people viewed this question
Henry  Thomas
Henry Thomas
