Errore F-35-9 su Konica 7135 - Office Equipment & Supplies
5 Suggested Answers
Nitrotrike
  • 589 Answers
SOURCE: Konica 1112 Error code 35
The procedure is as follows:
1. Turn machine off.
2. Turn machine on while holding the 2 & 5 keys.
3. Enter 47 on the keypad.
4. Press the Stop/Clear.
5. Enter 0 on the keypad.
5. Press the START PRINT button.
Power the machine off and on to exit the service mode.
You're done!
Posted on Mar 27, 2008
fer_nan_14
  • 76 Answers
SOURCE: KONICA 7020 GIVES ERROR MESSAGE F-35-1O WHAT IS WRONG
hi
error f 35 is fixing error,try to reset on 25 mode
Posted on Jan 09, 2009
SOURCE: How do I reset the password in order to change the
there should be a option in the user tools to switch the password off
Posted on Feb 05, 2010
roytardio
  • 106 Answers
SOURCE: i have a problem of
off the machine ,hold 2and 5 simultenously then on the copier press software switch then go the # 16-0-0
16-1-0
16-2-0
16-3-0
16-4-0
16-5-0
16-6-0
16-7-0
Posted on Jun 13, 2011
How to remove minolta 7135 code E 56-1
replace the image control board, all check all connection to printed circuit board remove each connector seperately and check for a bent pin
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 11, 2016 | Konica Minolta Office Equipment & Supplies
How i can adjust the position of the Touch Panel display konica 7020
Go to Touch Panel adjustment you will see "+" to the 4 corner of the touch panel use pointed object point it MILD on the center of the 4 "+" . Off / On
Oct 06, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Copy of konica 7135 is unclear while running. at first is copy is clear, later the copy is not clear... blurred
try to make some copies from your pc if the results is ok that simply means something with your scanner unit, for exaple the pnnel needs to be lubricated and the ccd unit needs to be cleaned.
Mar 20, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error F-35-9 code
Power off the machine. Now hold down the 2 and the 5 and power on. Mode 25 screen appears. Touch the Soft switch tab in the first box on your left you will put a 3 in the middle box you will put a "1" the third box you will change the "1" to a "0". Close out to original screen and power off the machine. Wait 10 second power on should get your ready to copy, if the code does come back DO NOT RESET the machine again! It is indicating a problem the code you are resetting is the fuser and it can catch on fire! That will ruin a perfectly good day!!!
Mar 03, 2014 | Konica Minolta Konica 7020 7022 7025 7030...
Error code c3905 in konica minolta bizhub 950
When C-35**,C-38** or C-39**(fusing temperature related
abnormality) occurs, be sure to repair defective parts before
setting DIPSW3-1 to 0. Setting DIPSW3-1 to 0 with defective
parts not repaired results in a fire.
Dec 21, 2013 | Konica Minolta Konica 7020 7022 7025 7030...
CODE F51_2
F-51-2, This error code appears in following copier models.Konica Minolta 7222/7228/7235/7135/7145This error code means "Fixing unit motor speed abnormality"Fixing unit drive motor is Motor Number 11.M11.Open the back cover and remove the main board and there you will find this motor.
Jan 04, 2012 | Konica Minolta Office Equipment & Supplies
I have a problem of error on konica 7135 error code is:l detection - adjustment Is it possible that I entered the numbers manually? Otherwise it will suggest the way?tanks
16-1-0
16-2-0
16-3-0
16-4-0
16-5-0
16-6-0
16-7-0
Jun 11, 2011 | Office Equipment & Supplies
What are codes F-34 and F-35?
These are heat sensor abnormality error codes in Konica Minolta 7222/7145/7135/7235/7228 models.You did not mention the model.
Oct 04, 2010 | Konica Minolta Bizhub C300 All-In-One...
I have a minolta 7135 in my office at work and it show the code F-35-8,what's wrong?
Hello sir; The error code you display, it means fuser temperature too low, but it can be reset;
1, hold down 2 & 5 keys while you turn on power.
2, choice 1 for software switches.
3, use U/D arrow key to pick up dipswitch and bit number.
4, pick up dipswitch 3, bit 1 and change 1 to 0 by pressing "off"
Mar 31, 2009 | Konica Minolta Office Equipment & Supplies
hi
Jan 08, 2009 | Toshiba E-Studio 3511 Color Copier
246 people viewed this question
k24674
Marvin
Marvin
