The system is set up to output sound through HDMI to the TV. You can change the setting so the sound is sent to the speakers. The process for changing the HDMI output setting is in page 41 of the manual. You want to choose the AMPsetting. I have included a link to the manual and copied the text below.
1. Press SHIFT+SETUP.
2. Use ?/? to select HDMI SET then press
ENTER.
3. Use ?/? to choose HDMI MODE then
press ENTER.
4. Use ?/? to choose the setting you want
then press ENTER.
• AMP - Output Audio sound of the DVD/CD
and USB function signal from this system
• TV - Output Audio sound of the DVD/CD
and USB function signal from a TV or flat
screen TV.
Did you remember to remove the shorting link on the MA BR5 speaker terminal ..When you biwire the speakers you should remember to loosen the speaker terminal nuts and remove the shorting link plate between the HF and the LF terminals or you will short the amplifiers two channels together through the link. And modern amplifiers will take a lot of abuse at low volumes but at high volumes the protection circuit will turn off the device.
On page 36 of the Pioneer users manual, it describes how to set your audio for HDMI interconnect. Follow the directions, and hopefully it will work. You can down load the manual from the Pioneer web site. Google "speaker system HTZ171 DVD". Click on the Pioneer site for your system and look for the download on the right side of page.
I hope this was helpful...
I have a Sony 46" LCD TV. I have a Direct TV HD converter box, a Sony Blu-Ray BDP-S360 Blu-Ray player, and a Pioneer DVD-Audio player connected to my Pioneer Elite Home Theater receiver. I have my Pioneer DVD-A player connected via Fiber-Optic cable. When i play a DVD or a DVD-A on my Pioneer DVD-A player, all of my speakers work fine, but when i play a dvd on my blu-ray player, all the speakers work except my subwoofer. How can I fix this problem?
If you have set the component output on the ps3 for high def,ie 720p or 1080i and do not get a picture it sounds like the component input is not high def enabled on your amp,change the setting on ps3 to standard 576 output,or put picture into tv then sound into amp if you want to run 720p or 1080i.
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
There are so many things to be consindered 1.does your tv sound comes out from the speaker without connecting the DVD
2.If the speakers from the tv ok,check the av line on the chassis of your tv set/check the av cables
