Question about Intel D845GVSR Motherboard
Instruction Manual SharDeMo@aol.com how to connect hardware + connection cable to system board + install bios + device drivers + new OS : XP.PRO disk
  • 1 more comment
  • Anonymous Jun 19, 2008
    need help for some installation
  • Anonymous Jul 16, 2008
    recently a friend gave to me a MDB SY P4IS2 but not the installation manual or drivers and I don't know how to connect to switches in front panel.
    can you help me?
    tnks a lot
    Peter Adams. from Chile.
    (peterkeltic@gmail.com)
  • peterkeltic Jul 16, 2008
    hello there !!
    recently a friend gave to me a mbd SYP4IS2 but not the installation guide or drivers.
    my problem is to find home for a dozen of red and black cables from the front panel, on/off, reset, usb, status leds etc.
    power plugs are ok.
    thanks a lot .
    Peter Keltic.
  • 36 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
78
Posted on Mar 13, 2009
  • 84 Answers
It looks like your building up a new PC, but you have to very careful, you can refer to the system board manual for the installation of hardware,now once u finished that, you may now proceed to installation of your device software, you can do that first by installing the OS - XP by setting up the CD rom drive as first boot in the CMOS/BIOS then you follow what the screen tells you, you can check this link for guidelines http://www.michaelstevenstech.com/cleanxpinstall.html
hope this help you out. :)
Posted on Jun 13, 2008
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
XP not recognizing 5th SATA drive in new motherboard
Since you are a experienced PC user, I will cut down to the chase as I might have a idea what your problem might be. I tried to find more into on your issue but couldn't source anthing of importance:
It might be that your last SATA port that you have connected your hard drive is different from all the remaining 5 - Meaning it is set up differently BY DEFAULT in the BIOS. FOr example it might be set up to be on a certain "RAID" setting or mode that might prevent it from being seen within Windows XP.
What I am trying to get at is that maybe that last drive "mirrors" another drive by default.
Please try also to download the latest BIOS for you mainboard, and make sure all hard drives in the BIOS have the same setting on them individually. Spefically, check your RAID and AHCI settings, boot up lineup and other settings that might influence this.
Also check if your new hard drive isn't faulty, since it picks up in BIOS but not in device manager - The drive might have a plate fault or a read/write head issue. This might explain why it is visible in both the BIOS AND the device manager under "Hardware devices" but not in the "Disk Manager/Management".
As you know how to format and partition a drive, i do not need to query if the drive as been initialized, since you already have set up the other 4 hard drives without a problem.
May 24, 2010 | Microsoft Windows XP Professional
Trying to install Windows XP SP1 onto HD with this Motherboard. System will not boot from HD to start install.
Make sure your IDE hard disk drive is connected to IDE1 port and that the data cable is fully connected. Also check the jumper on the IDE drive. If you are using only one IDE hard disk drive set the jumper on the drive as a Master without a slave. If you are running two IDE hard disk drives set the primary drive's jumper as a Master with a slave. Set your second IDE disk drive's jumper as a slave. The master drive should be connected at the end of the data cable and the slave drive should be connected to the next data connector. Than check your bios settings. Power on the system and press the Delete key every 2 seconds until the bios menu loads. See page 3-1 in your manual. If you need the manual for the NF8-V MB click on the link provided below and download it;
http://www.abit.com.tw/page/en/motherboard/motherboard_detail.php?pMODEL_NAME=NF8-V&fMTYPE=Socket+754
You'll also need the program Adobe reader to view the manual. Adobe reader is a free download; http://www.adobe.com/products/reader/
Once you’re in the bios go to page 3-4, Standard CMOS Features.
Follow the instruction listed for IDE HDD Auto-Detection. Your HDD should be listed here. Than see page 3-7 in the manual. Open Advanced BIOS Features. A normal boot menu for the Abit would read;
First boot device Floppy disk drive (If one is connected). 2nd boot device should be (CD-ROM/DVD-ROM). Third boot device should list your primary hard disk drive's (Model number). Load your windows CD into your CD-ROM drive.
Once the settings above are set, press the F10 key to save your changes and exit the bios. Your system will auto restart. Windows should begin to load.
Cheers!
Mike
Nov 18, 2009 | Abit NF8-V Motherboard
WITH SERVICE PACK 3 (WIN XP) MY 795 IS "DISCONNECTED" NO MATTER WHAT! PLEASE HELP!!
The iFP-795 is a player that has connection type UMS
(also called MSC): seeing the player as a removable disk:
Go to next site to see the connection type:
http://www.iriver.com/flash/index.asp?code=0300
and click on connection. Scroll down to see the iFP-700 series listed in the connection type UMS.
UMS = Universal Mass Storage
MSC = Mass Storage Class
With XP sp3 the computer Operating System has setup USB connections with new drivers, that support both UMS (= MSC) and MTP connections.
MTP = Media Transfer Protocol
When you experience next making connection:
Connecting the device to the computer Wizard found new hardware pops up.
Only this time the Windows update searching for software will not work on automatic routine: ending up with "Cannot Install this Hardware".
Manual performing the wizard, setting the device to USB connection type:
1. Can Windows connect to Windows Update to search for software ?
Select "No, not this time".
[Next]
2. If your hardware came with an installation CD, or floppy disk, insert it now.
Select "Install from a list or specific location(Advanced)."
[Next]
3. Please use your search and installations options.
Select "Don't search I will choose the driver to install."
[Next]
4. Select the device driver you want to install for this hardware.
Select "USB Mass Storage Device."
[Finish]
Just post a comment if you need more help.
Sep 24, 2009 | iRiver iFP-795 MP3 Player
Can't connect to internet, modem not found
right click on m computer- properties- hardware-device manager- check and see if you have anything with a yellow ! or ? or if you have anything listed under Modems. sounds liek you need the drivers installed-
http://support.dell.com/support/downloads/driverslist.aspx?c=us&l=en&s=gen&ServiceTag=&SystemID=PLX_PNT_P4_GX260&os=WW1&osl=en&catid=&impid=
click the + by communications and download the 3 listed and install on your home pc
Jun 03, 2009 | Dell Optiplex GX260 Refurbished Intel...
Will not boot,bios does not show a hard drive,only two CD drives
The peripheral devices as Hard disk and cdrom is not connected with the IDE cable or has loose contace. Even power cable of devices is not properly done or left out. So you need to check the IO IDE cable connetions and the power cable connections of the devices being connected to the mother board.
Mar 30, 2009 | Intel D865GBF Motherboard
On board sound do not work
Look into device manager for your OS.
For XP - Start - ControlPanel - System - Hardware - Device Manager
Under Sound make sure drivers are loaded correctly.
If not download latest and reinstall.
Regards B
Mar 20, 2009 | Computers & Internet
Can't boot my Acer Aspire One
"Booting" is the process of starting up the computer's operating system (Windows). Settings in the mainboard memory (the BIOS) give the order in which devices are searched for the operating system. The usual order is hard drive first, then the CD drive, and finally over a network.
That clear-as-mud message means the mainboard tried to boot over a network connection and it didn't work. It's telling you to check your network cable or to put in a CD it can boot from.
There are two reasons this is happening. Either the system's BIOS settings have "network" as the first boot device, or (more likely) the operating system wasn't found on the hard drive and the BIOS went looking for a network connection. If the computer used to boot normally and you didn't change the BIOS settings, then something has happened to the hard drive to make it unbootable.
You can check the BIOS settings by pressing the "DELETE" key when you turn the computer on and the Acer logo screen appears. This starts the BIOS setup mode. If the boot order is correct with network boot as the last choice, there is a hardware cause. You might have picked up a virus or worm which has corrupted the disk. The hard drive or the mainboard may have gone bad.
If you have a recovery CD or DVD set, you can try restoring your system. You say it's brand-new, so you might try taking the computer back to the retailer to see if their technical support people can help. Or you can contact Acer to set up service for the computer.
Hope this helps you understand what's happening and that you get the trouble straightened out quickly!
Feb 07, 2009 | Acer Aspire One Netbook 8.9" Notebook
Hard drive
You connected the usb had drive , and if it had an external power source it was on ???
ok right click on mycomputer
choose hardware
choose device manager
right click anything on the tree view and click scan for hardware changes.. Windows Xp should automatically detect and install it..
If you got vista, Right click computer and choose device manager,, right click anything on the tree view and click scan for hardware changes,, windows vista should install it automatically
IF THAT FAILS
verify your usb cable is good
check if your device requires an external power source and verify that it is connected..
connect it to another computer to see if it working
IF ALL THE ABOVE FAILS THE UNIT IS NO GOOD..,, you could try changing the harddrive inside it but i would have been wanting my money back or insurance since it could have been damaged while shipping..
I THINK I MAY HAVE COVERED IT ALL BUT IF I MISSED ANYTHING PLEASE POST IT AND I WILL TRY TO ASSIST
Jan 18, 2008 | Computers & Internet
Trying to install my web cam
I have windows XP professional OS and i have connected Veo Stingray web cam after installed driver its do's work,
I want sollutions if anybody can help me.
Please help me out.
Thanx
Oct 11, 2007 | Veo Connect Webcam
Intel D845GVSR Motherboard Logo
404 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
