Question about GE JVM1640 Microwave Oven
Dead unit The entire microwave is totally non responsive. If this was caused by an over enthusiastic cleaning, is there a solution?
    President:
  • 267 Answers
First WAIT sometimes the control board gets wet , it may dry out in a few days and will work again . but while you wait un plug it . a live board thats wet might not last long if powered up ...... if still no good see if the light works . if it does the board is bad if the lights dead too , then theres a fuse inside that may have blown
Posted on Jan 15, 2009
DEAD! No lights nothing.
Appliance is totally dead. No response to any key or lights ...
https://www.ifixit.com/.../Appliance+is+totally+dead.+No+response...
iFixitSep 19, 2013 - Replaced oven cavity thermal cutout - No joy. What could cause total loss of power?? - GE Microwave Oven Monogram Advantium 120.
Notes on the Troubleshooting and Repair of Microwave Ovens
repairfaq.cis.upenn.edu/sam/micfaq.htm
Feb 24, 2015 - On-line microwave oven repair database; The simplest problems; Repair ... Totally dead oven after repair; Dead controller; No response to any ...
Oct 15, 2015 | Microwave Ovens
Blinking electronic display on microwave
see the cause and proceed according. God bless you
but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.If your keypad and control is the same unit, replace that unit. Another note, unlike stove/oven keypads and controls, most microwaves do not have error codes or tests to distinguish whether it is truely the keypad or control. Most of the time, it is the keypad that needs replacing, but a small percentage of the time it can be the control. Check the tech sheet if they can point you to the right part.
Oct 17, 2012 | Sharp Half Pint Microwave Oven
Daewoo KOR-6LOB microwave oven the keypad is frozen andthe display reads 0, then will change to AC1 and a couple minutes later AC2 what can I do to fix it
proceed with common sense tech. God bless you
Oct 17, 2012 | Microwave Ovens
Tappan 5030 microwave oven fuse is ok but no lights on keypad come on
see the causes and fix it. God bless you
Oct 10, 2012 | Tappan TMS062E1 Microwave Oven
Keypad don't light up
see this causes and fix it. God bless you
Lights come on, but can not program unit, Touchpad dead If you have a stuck key or non-responsive key, most of the time you will have to replace the keypad for this microwave oven repair. If your keypad is connected to your control board by a flat ribbon wire, try disconnecting it and clean the silver contacts with an ordinary pencil eraser. After cleaning, plug it back in and try it. If it doesn't fix it, replace the keypad unit. Some units actually have keypad tests to confirm your diagnosis of a bad key.
Sep 25, 2012 | Maytag MMV4205 Microwave Oven
My LG Microwave is not working. The STOP/CLEAR button does not work
see the next steps: USE THE commons sense . God bless you
Aug 01, 2012 | Microwave Ovens
Ge advantium 120 microwave oven completely dead
You have a bad cavity switch. I would guess it is the one behind the vent cover, toward the left side of unit. You would need to remove unit from wall. Remove outer housing to expose cavity switch. You can see it from vent cover, I would test all cavity switches before removing from wall. You should have a diagram of unit folded up behind vent cover towards right side of unit. This tells all workings of unit. Will also tell where all cavity switches are.
Dec 30, 2009 | GE Advantium 120 Convection/Microwave Oven
Micro 6654438991 power surge from pole, light works, panel dead
Sounds like you should get estimates and turn in on homeowners insurance. Power surges are very destructive and you have lost the control board at least and maybe some switches. Eric
Aug 08, 2009 | Whirlpool GH7145XF Microwave Oven
Microwave won't turn on. Seems like it is not getting power. I checked breaker. I am looking for a fuse. You know where one is? It is a GE Spacemaker(2 yrs old) model # JVM1440WH04
  • Make sure that the microwave is plugged into a grounded outlet. It must be a 3-prong outlet.
  • Make sure the clock is set.
  • Check to see if a programming sequence was entered. Sometimes improper programming or a program sequence such as delay start can cause the touch panel to be non-responsive. Unplug microwave or turn off house circuit breaker for 30 seconds. Plug back in, or reset circuit breaker, and try reprogramming unit.
  • Check the house circuit breaker or fuse box. If the microwave is DEAD and there is no display and nothing works- the problem could be a blown fuse or tripped breaker.
Jul 29, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1640 Microwave Oven Logo
149 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
