Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mits 52525 blinking green light
Replaced four caps on DM board and a few others for good measure. No luck. 30yr old Sears CRT working great.
  • ctonef15 Jun 13, 2008
    There are only the 4 caps on this board. Symptoms b4 and after exactly the same...boot-up blinking green...never stops.
    Problem Solver:
  • 16 Answers
There are also 4 caps on the formatter board that will cause this symptom . they are the same value as the dm board. while your at it check the 2) 3300 mf/10v caps on the power supply board.
Posted on Jun 18, 2008
  • 927 Answers
Good Day;
If you only changed 4 caps,1000 ucfd 35v, it should be 5, if you did not remove the little plug in board, e prom, you may have damaged that. B-4/after changing caps what is the indicator light, green, doing?
Does light stop? Please rtn with more info.
Posted on Jun 13, 2008
Green timer light justs blinks and the tv will not come on
I have a Mits rear proj screen ws-55613 replced the 4 caps on the DM and still have th fast blinking green LED any Ideas?
Jan 03, 2011 | Mitsubishi WD-52525 52" Rear Projection...
I have one of thos green blinking light and NO
The lamp light would be solid red if the lamp were out. The steady blinking green led is usually caused by failed capacitors on the DM board. You can get the V26 dm repair kit from www.tvrepairworld.com which should repair that issue. The kit contains the capacitors and the CD with detailed instructions.
Jan 12, 2010 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Solid Green Light, no picture
Your DM Boaard has gone out. You need to replace it. Discount Merchant has them for 69 bucks
May 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mits 525 started blinkng green standby light today makes a muffled sound as it beeps. wont turn on just beeps.just under 4 yrs old. have replaced bulb 3 times. reading some of these posts seems like...
The first generation mitsubishi V26 chassis which is what your model is has a bad habit of failing capacitors. The steady blinking green power light is related to the DM not completeing the boot up sequence. You can get the V26 DM repair kit at the following link which contains the replacemnent caps that are prone to fail and has the CD with step by step instructions on how to duisassemble the cjassis and replace the caps. Its very inexspensive and will usually repair that issue. Its listed under the repair kit category.
http://servicemanuals.vstore.ca/
Mar 15, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light
check ur dm board it could have caps as well
Dec 09, 2008 | Mitsubishi WD-52525 52" Rear Projection...
MITSUBISHI 65 INCH HDTV, GREEN LIGHT BLINKING, WILL NOT POWER UP
There are four (4) caps on the 'DM' board that need to replaced. Parts: 680ufd 16 volts, orig are rated at 1,000 ufd.
Nov 01, 2008 | Mitsubishi WS-65809 65" Rear Projection...
Blinking green light
The DM has caps on it that are easily changed if you can solder, a google search should lead to many forums with the proper instructions
Aug 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mit 52525 from blinking green light to still green light.
bad capacitors 1000uf on the PWB, FMT and DM boards will cause those symptoms. All capacitors 9 in all need to be replaced
May 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Blinking Green Light on Mitsubishi DLP 52525
the dlp will most likely need a qualified mits repair center to take over for you. repairing that set is pretty involved. and the parts you would need are not available to the public.
on your 48" CRT projection check the DM module for 4 vented 1000mf 16v capacitors. replacement should get you tv working great
Feb 20, 2008 | Mitsubishi WS-48513 48" Rear Projection...
WD-52725 Timer light is blinking and will not stop.
This part will cost you about 650 to 800 bucks my friend. if you have any soldering skills, and can follow directions, I posted a DM board fix. it may just be four small capacitors. Now this set that was used in the fix is not exactly like all the other Mitsubishi TV sets that still have a DM board, but if you can locate the DM board, follow the rest of the repair. if you do not know how to solder, do not take a chance, as this part is way too expensive to be experimenting around with. Get the Capcitors(there is a link there too for the capacitors)and take the DM board to a service shop, as this should not cost you a lot to have a pro do this for you. The DM board fix is located here: http://www.fixya.com/howto/h154057-mitsubishi_dm_board_repair Good luck
May 27, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
