Question about KitchenAid Dishwashers
The dishwasher is not cleanining properly. Cannot lift off the 4-way hydro sweep (with jet spray) (it seems stuck) to clean the removable filter. Kitchenaid Model KUDB220T. I have done this before - but this time cannot remove the 4 - way hydro sweep. found a half ring of metal in bottom of dishwasher - please help
  • jdok Nov 04, 2010
    the whirlpool dishwasher is similar to our kitchenaid but we never had to remove a bolt to remove the
    4-way hydro sweep wash arm - it always lifted right out. what bolt are you referring to? there are no bolts to remove on the sweep wash arm - it is not exactly like the whirlpool model - there are no names of parts on the diagram. we have the use and care guide for our kitchenaid KUDB220T - there is no 0 on the end of it. it says the sweep arm just lifts out - which we have done in the past - but now it seems stuck and won't come out - all parts the coarse strainer, the sweep wash arm and the
    removable filter came off with out using any tools as per the manual - the sweep wash arm is stuck!
    please help. thank you.
  • KitchenAid Master
  • 3,247 Answers
I would suggest you look at diagrams 4 and 5 in the attached assembly drawings. You will have to remove bolt holding the 4 way spray arm but hold the base of the circulating pump at the same time. The metal ring would be one of the washers in the pump assembly.
Hope this helps.
Posted on Nov 03, 2010
  • Sam Nov 04, 2010
    The kitchenaid and whirlpool should be same model.
    If the wash arm look like this then it is stuck in the filter assembly which I presume will look like this.
    Maybe there is a different way to sort this out. Have you used the Finish dishwasher cleaning kit before? I would suggest you run the dishwasher in hot cycle using the Finish dishwasher cleaning kit from the supermarket. FOllow instructions on the bottle. This should loosen up the filter and help you take the wash arm out.
    Please post a comment to confirm what happens.
Dishwasher will not drain. Can hear it making a sound but water will not empty. Tried some liquid plumer but that does not seem to be working. When we try to drain there is a funny sound.
Hi
This draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Also, check for any food pieces stuck near the pump impeller & clean the chopper assembly. Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Aug 13, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
I have a 3 year old Maytag dishwasher and over the last couple of months it is getting very loud. I hums and then you can hear the jets spin. It keeps doing this in cycles. I am not sure if the pump is...
Hello, Thank You for using FixYa. I will be helping you today.There is a chopper blade under the filter that can cause this if something got under there. If you remove the lower spray arm there are three screws you will see remove those and lift the cover out. Then there are screws holding the center down i think six of them remove them and lift out Under that are two more screws remove and lift filter out,Under that is where things get stuck and stop motor or cause loud noise.
Thank You and please rate my answer if it was helpful..
Jun 21, 2011 | Dishwashers
The washer fills and runs through the cycle but leaves a grit on the dishes
If detergent is left in the compartment:
? Be careful not to load items so close to the dispenser
that the cover will not open to release the detergent.
? The dispenser is not supposed to open when you
use the Rinse program.
? Your dishwasher detergent should be fresh and
stored tightly closed in a cool, dry place. Old or caked
detergent should be thrown away because it will not
dissolve properly and will leave a gritty residue on
the dishware.
? Wait until you are ready to start the dishwasher to
add the detergent.
? If you are using the Delay program, make sure the
dispenser is dry before adding the detergent.
? The detergent compartment only opens in the main
wash programs, not the Rinse program.
YOU MAY NEED TO CLEAN THE FILTERS MORE OFTEN
IF YOUR AREA HAS HARD WATER
This can cause low water pressure.
In hard water areas, it may be necessary to clean chemical buildup from the filters every 12 to 18 months. To do this, remove the coarse filter by squeezing the
tabs and lifting it out. Next, unscrew the fine filter and lift it and the main filter out. Wash all three filters gently in hot, soapy water and rinse them thoroughly.
Your spray arms may be clogging causing low pressure too.
Spray-arm jets and bearings may sometimes become clogged with hard water chemicals. To remove the spray arms, screw off the nut and take off the washer on top of the spray arm and lift off the arm. Wash the spray arms in warm, soapy water. Use a soft brush to clean the jets. Rinse thoroughly and replace.
Try cleaning the drain pump so it gives you more water pressure.On occasion something may get through the filters and into the drain pump. The drain pumps on ASKO dishwashers are designed to automatically reverse if anything should get caught in the propellers, thus ejecting the item back into the sump area or down the
drain. Should you need to remove an obstacle from the drain, first turn the power off then remove the filters . Next, lift out the small black insert
from the sump area. (You might want to remove any standing water first.) You can then look into the sump area for the item causing the obstruction. Should you
find something, simply scoop it out. Be sure to replace the black insert before you put the filters back in.
You could also try to clean the dishwasher with ' Dishwasher Magic '. This would work like charm :-
http://www.dishwashermagic.com/
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 26, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Hydro arm hits bottom rack
Your best bet would be to get a wash arm rebuild kit from an appliance parts dealer
Jul 01, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Not cleaning
Check spray arm jet holes. Clean the clogging with blower or soft bristles.
Apr 12, 2010 | KitchenAid 24 in. KUDI02IR Built-in...
My Whirlpool quiet partner dishwasher seems to run
try a large cresent wrenck,or channel lock plier.ps.might place towel over plastic nut,to protect from wrench damage.
Oct 10, 2009 | Dishwashers
Jets do not spray properly
If the jets are not spraying correctly, it is essential that every hole on the top and bottom rotors be cleaned properly.(very important smoth momentum.).They can be removed to do the cleaning.
Sep 23, 2009 | Dishwashers
Dishes don't get clean!
The problem is probably that the chopper/cutter filter is pluged. It needs to be cleaned
1. Remove bottom basket. Remove top basket (Pop off 'keepers' at the ends of the slidding shelf supports.
2. Remove bottom washing arm. Unscrew (Gently but firmly) the centre post. Lift arm assembly out.
3. Remove overhead conduit. One screw at back and one at the top (Philips #2 bit). Rotate the whole assembly 45 deg to right (Clockwise) and lift off of the centre post. It can then be taken apart and cleaned.
4, Remove centre post (pull straight up). Remove 4 screws (Star T-20 bit). Lift whole assembly out. Pop off the screen (Flat blade screwdriver around the edge) and clean.
5. Remove cap over cutter/chopper. There is a single screw at front left (Under assembly remover in 4. Remove screw (Star T-15 bit) and cap (Needs some wiggling to free it up). Remove cutter & filter. It is on a spring loaded pin. Pull the cutter blade foreward and lift the filter disc straight up. Clean thoroughly. I then ran a 'quick rinse' cycle with everything out.
Reassemble.
Dec 29, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Top spray nozel not moving water on my kenmore dishwasher
pump is more than likely clogged
in the dishwasher you will see you lower spray arm. take it off. now going up the back is the supply tube. you need to pop it off of thed top then the back and turn it clockwise to get it off the motor. after you do that you will see 4 torx screws. take all 4 out and you will be able to remove the fine filter. thats the normally grey piece with all the slots. after you remove the filter you will see two more torx screws. remove them they are for 2 seperate pieces one is the foreigh food seperator and the other is the chopper cover. remove both of them and clean the whole thing out. as yiou are puytting it back together. let me know if you get stuck
Nov 25, 2008 | Kenmore 24 in. 17012 Built-in Dishwasher
The top wash arm does not move on my Kenmore Dishwasher model #66515894100. How can I fix this??
Not familiar with this specific model, but I had a similar problem where the water jet slots in the dishwasher's top spray arm were blocked by food debris. The filters were nylon and had started to disintegrate, and when water was recirculated debris was pumped round & blocked the jets. Suggest check your filters are ok/seating properly & then check the jets are not clogged. My spray arm came off easily to enable me to clean it out.
Aug 24, 2008 | Dishwashers
Dishwashers Logo
82 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
