Question about Maytag M7Y12F2A Air Conditioner
Unit is switched on but no air
Hello, my unit is not exactly the same model number as mentioned above, the correct model is M7Y12F2C. The unit is switched on, the panel is lite but nothing is happening.
What can I do in order to get it working?
Please reply promptly.
Thank you in advance.
Nothing...Maytag SUCKS!! I have the same problem and Maytag says it could take months before they get new parts to fix the faulty control panel. My unit never shuts off. Only way to turn it off is by unplugging it out of my wall socket and it has already caused my living room electrical socket to blow out. I will never buy Maytag again.
Posted on Jun 26, 2008
Its is not cooling my room Help?
Hello Mary;
My name is peter. I am a retired field service refrigeration technician.
There are several reasons your unit may not be cooling:
1.) A bad thermostat (Thermister) - This is a small elongated bulb with a long wire that is mounted on the face of the cooling coil. It clips on the face and has a connector at the other end. This is relatively inexpensive and easily replaced.
2.) A bad starter relay on the compressor. Although the part is inexpensive it is a major job to disassemble the unit to access and replace.
3.) A bad compressor - This is a major repair.
4.) A bad temperature controller - This requires a sharp handyman or technician.
If you remove the front cover on your unit, on the left hand side your will see your model number. Take this model number and go into the following website. Put in your model number (Left hand side) model number. Then select parts. You will get diagrams and part numbers so you can refer to the components I have mentioned above.
In general, unless you have a service contract, you are looking at a service call of $220.00 +. We conditioners window air conditioners; "Throw-A-Ways".
You can purchase a new unit for less than what it will cost you to repair yours.
Water Filters Lawn Garden Appliance Parts
Jun 01, 2015 | Heating & Cooling
Need wiring diagram to include: Underfloor heating downstairs (wet system,polyplumb) combi boiler for the heating and hot water
could you provide the exact model number or the product you need the wiring diagram for
Thanks
Proton
Oct 30, 2008 | Honeywell Heating & Cooling
SERIAL # IK0487-01713
I googled: Intertherm Air Conditioners There are a number or articals that may help you find what you need. One referance to a youtube "review" Hope this helps. I was going mention "how do you know it's a bad blower motor? But depending on age and use anything is possible. Usually the motor has a model number on it. That would be the safest way to find an exact replacement.
May 12, 2015 | Intertherm Heating & Cooling
Need instruction manual
hello sir, Please provide the following information so that your issue may be diagnosed properly,what is it? brand name,complete model number The problem, What is happening with what? When it is happening? Are there times it does not happen? Did it just start happening? Did it ever work ? Did any seemingly unrelated event coincide with whatever it is not working? need the model number and brand name, if you need a manual i need the brand name and model number,if it is a riding mower the model number is under the seat.a snow blower the model number is on the rear of the machine, let me know,thank you. ``
Feb 05, 2012 | Black & Decker Garden
Took the nozzle apart on my hoover steam cleaner upholstery attachment because it was leaking, fell apart andf now I cannot get the switch in the correct place or for that matter cannot get it all back in...
whats the exact model number of your vacuum unit and exactly which switch fell apart, the switch on Handel or its any other switch.------- Where exactly this switch is located, so the exact fitting / installing procedure can be provided.------- Keep updated, thanks.Helpmech.
Aug 18, 2011 | Vacuums
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
Apparently they are locked to region 4 and I have bought region 1 DVDs so they won't play
In most models the unit cannot converted to multi-regions.So it will play only in the specified region in which it is applicable to.But in some unit models there is a procedure to turn the unit to multi region so it can play all region dvd.On all models the procedure to convert the unit to multi region is different.As you have not mentioned the exact model number of your unit.t will not be easy to give exact details.If in case there is a procedure to convert your unit to multi region.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Sep 14, 2010 | LG Audio Players & Recorders
Unit aill not turn on.new batterys in thr remote, (second set).Also can this unit be run manualy? My model # is TAS12VW/O
What is the manufacturer of your unit please?
the model # is coming back as invalid.
thanks!
Aug 06, 2010 | Turboair Heating & Cooling
The not ready has been blinking for 3 days and would like to know where to send to fix loove my coffee pot
These brewers (especially B77, usually from Costco) are defective & Keurig is replacing them with new units @ no cost. Just call the toll free # (866-901-2739) & they will ship out a replacement in 3 to 10 business days. I own (2) of these & they have both been replaced. Even if not the above mentioned model, call them anyway & see what they will do for you......
Feb 14, 2010 | Keurig B60 Coffee Maker
Asus P4SD-VL Motherboard manual wanted purchase a new computer tower and trying to fit my motherboard and want a motherboard diagram or manual could some one please help! The connectors for the power...
I didn't find your exact model number, but if you want a detailed manual of your mobo the this is the link:
http://support.asus.com/download/download.aspx?SLanguage=en-us
As I did not find your model number, please recheck the model number. If your numbers are correct you should be able to find the documentation you desire at the link above.
Aug 02, 2009 | ASUS Computers & Internet
Maytag M7Y12F2A Air Conditioner Logo
98 people viewed this question
Top Maytag Heating & Cooling Experts
gbob59
Bill Long
Are you a Maytag Heating and Cooling Expert? Answer questions, earn points and help others
