Computers & Internet Logo
Posted on Nov 03, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I want to buy Toshiba A4-S211 notebook PC from the Yahoo Auction. The internet seller used it for five years. Can anyone provide any suggestion or information to me?
Amado Petallana
Level 3:
  • Master 320 Answers
  • Posted on Nov 03, 2010
Amado Petallana
Master
Level 3:
Answers
320
Questions
Helped
75082
Points
1035
Here are some of the research i found out about the Toshiba A4-S211 notebook.
The good: Solid construction; good speakers; discrete graphics card; roomy keyboard; wide-screen display.
The bad: Merely average performance; a bit short on battery life; screen does not display text well.
The bottom line: The well-equipped thin-and-light Toshiba Tecra A4 is not a super performer, but it offers a great feature set at a reasonable price.
Usb boot bios
Go to this page on the Toshiba website and find what you need. There is also a little program you may need to help you with this issue, on that page.
1helpful
Ok i did a clean install of windows 7 ultimate on my toshiba satellite a75 s211 then when i do that i cant hear so i get the latest realtek driver from the toshiba website i install it and i still cant...
Issue with your Hard Disk Possibility of bad sector ..on the primary sector... So Download Partiion Magic and Re- Partionnate your Har drive and Re install you windows
2answers
My toshiba fans their a little noisy how bad do i need to replace
Two cans of compressed air can work wonders. I usually use both cans at the same time, just take the laptop outside and spray away. Make sure it's off, of course ;)
2answers
My Toshiba A75-S211 overheats and shuts off.
That is common with Toshiba. Check to see if your fans are running. Also, there may be a lot of dust, hair, etc inside the laptop causing it to heat up. I recommend buying a laptop cooler. I got mine for $10 and I never have over heating problems anymore. Hope that helps:)
1helpful
My Toshiba Satellite A75-S211 computer, will suddenly shut down.
Mine did this and I thought it was overheating and vacumed the back vents. This fixed the problem.
Toshiba A75-S211 memory
I'm showing a base memory on that unit of 256 so your max upgrade is 1gb to 1.2gb total.
1GB (1x1GB) Toshiba Notebook 2.5v PC2700 DDR333 SODIMM
Toshiba A75-S211
You can do either.
I suggest that if you want to double your memory capacity is to buy another memory module with the same specs and size as the existing one, preferrably from the same manufacturer.
Adding memory to Toshiba A75-S211
you buy the memory here for a great price or anywhere online instructions are on the page
it replaces the 512
http://cgi.ebay.com/1GB-DDR-333-for-Toshiba-Satellite-A75-S211-Memory-RAM_W0QQitemZ250353026446QQihZ015QQcategoryZ158897QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
  • Memory Card for Toshiba Satellite A75-S211 Memory RAM- Designed and Optimized
  • Toshiba Satellite A75-S211 Memory RAM Memory Upgrade -Easily installed
  • More Memory Equals - More Speed for your APPS
  • The Toshiba Satellite A75-S211 Memory RAM has a memory card slot or slots, that allows you to add more memory to your Toshiba Satellite A75-S211 Memory RAM, giving you enhanced performance and speed. You will see the Immediate speed increase in your computers performance.
    Stop waiting for programs, and functions to happen, STOP WAITING!!! Start enjoying technology as you should.
    We work directly with our memory card manufacturer to insure perfect compatibility with the Toshiba Satellite A75-S211 Memory RAM. Only using the highest quality memory chipsets for our memory cards, so you are assured compatibility and performance. All of our memory cards are Designed and Optimized for Toshiba Satellite A75-S211 Memory RAM . Technical specialists have personally verified our memory cards compatibility with the Toshiba Satellite A75-S211 Memory RAM.
    Worry Free Installation: Just Follow these Steps Desktop and Laptop instructions below.
    Desktops
    1. Unplug Power cable
    2. Remove Case
    3. Slide memory card in Open slots- the memory card will only fit in one way
    4. Snap the side clips in place
    5. Close Case and Power Up
    6. You are ready to go.
    Laptop
    1. unplug and remove Battery from laptop
    2. Open memory compartment on bottom using Philips screw driver
    3. inset memory in open slot, if no open slot remove current memory by pinching metal clasp on side of memory
    4. Close compartment and power up you are off and running.
    Trying to find website that I have seen befoe that has instructions on how to open up the A75-S211
    Problem solved. Lap top stripped apart and that little line of dust got cleared out and now the laptop works as if new. Thanks to the website I posted above that shows how to safely dismantle the A75-S211.
    2answers
    Laptop simply stops on starting
    take out the battery, plug in ac only, and try it again
    Top Toshiba Computers & Internet Experts
    ExpressFiX
    ExpressFiX
    k24674
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
