Question about Toshiba 43H70 43" Rear Projection Television
Please help me
I have a tp43h60 tv an it's having some problems going on an off an the red light flashs is this someing i can do to fix the problem
    Genius:
  • Toshiba Master
  • 1,689 Answers
This may be that the power supply has failed, or there is a short somewhere. Many times, the problems occure in the scan amplifiers and in the power supply.
The set will require shop service to get it working again. Considering the type of set and age, I would be seriously considering a new LCD or Plasma set. Your set may be fairly expensvive to service, and with its age its reliability will be lower.
Jerry G.
Posted on Jun 13, 2008
I have a Mitsubishi WD-62525 TV the lamp red light started to to flash red so i replaced the lamp did not fix the problem so i replaced the lamp ballast light is still flashing red...can someone please...
please count the flashing led light on the front..
after you count click this link www.fixya.com/users/bugoy31
then choose any of my services to help you fix it..
Feb 03, 2012 | Mitsubishi Televison & Video
Orange flashing light on PS3, picture on show on tv, whoever i can hear some music
Please take a look at PS3 Red Light Fix Guide -
It show you many seneraio of PS3 red light flashing problems and provide solutions how to fix it. It's a step by step guide even you are a begineer to fix it.
Nov 25, 2011 | Sony Playstation 3 (PS3) Console
I have a TH42PA50A plasma panasonic, it was working fine last night but when I go to turn it on this morning all that happens is the red light flashes and nothing. Please help
Right now the TV is in " Protection Mode " and the blinking red light is a trouble code.
Try leaving the TV unpluggeds for 30 minutes, that way the TV can reset itself.
If that doesn't work, most likely the TV has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
But, I can't say it's 100% the problem because I can't actually look at the tv over the internet.
If by chance the TV is still under warranty, go that route.
If not under warranty and If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you red light blinking codes, circuit diagrams, test points, and part# lists. Usually, cost under $20. And most cases the new part cost less than $15.
I hope I shed some light on the subject for you.
Jul 05, 2009 | Panasonic Televison & Video
Toshiba TP43H60 Convergence Problem
This may sound odd but try moving the remote further from the set. I have seen similar issue with my 42H81.
Jun 01, 2009 | Toshiba TP43H60 43" Television
Toshiba big screen tv. tp43h60
Good Day;
I would suspect the convergence IC's, to confirm this unplug the convergence yoke, all three. If TV comes on IC's are bad. Also, check the little green pico fuses. Good Luck, big IRISH.
Nov 10, 2008 | Toshiba TP43H60 43" Television
what year was your set manufactured. The other site I work for as atech has a vast collection of toshiba service info
Mar 28, 2008 | Toshiba TP43H60 43" Television
No picture, No sound
If the set is a TP43H60 like the posting says it is I show it as a CRT based Projection. And this one does not have a lamp in it. So if you could verifiy the model number
Feb 20, 2008 | Toshiba TP43H60 43" Television
No picture, sound and flashing red power light...
Pull off the back pressboard. At the bottom left hand corner is the power cord that attaches to the power supply board. There is a white plug that attaches directly to the power cord. With the TV power off, pull this white plug up to disconnect. Then push it back in. Then plug your TV back in and press the power button on the front of the TV. I just did this and it is working fine.
Sep 16, 2007 | Toshiba TP43H60 43" Television
Toshiba TP43H60
I have the same issue with my toshiba 32" circa 2000. I am told that it is a burned out diode of some sort and it is a horrendous repair job.
Aug 27, 2007 | Toshiba TP43H60 43" Television
Toshiba tp43h60
You have a bad regulator IC or something in the seweep power supply is blow out. if you can read a schematic, i suggest you get one to troubleshoot the solid state circuits in this TV set. if you do not have any solid state repair experience or no electronic background, play it safe and call in a pro to assist you in the repair of this TV set. Good Luck.
Mar 17, 2007 | Toshiba TP43H60 43" Television
Toshiba 43H70 43" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
