Question about Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive
My WD MyBook 500GB drive is causing Windows XP to be self-retardant. (Slows)
It just started yesterday- Whenever I start up Windows XP with the ExternalHD plugged in, it won't get past the windows login (loading user settings bluescreen); it will freeze. Whenever I plug in the EHD past that point, it causes my computer to lag beyond the point of use. I would love to try the solutions listed in the other sections, but I have neither the money to afford data retrieval or another EHD. On top of that, If I wanted to change the Drive's letter (It's currently stuck on E:\), It'd have to be plugged in; and when it is, I can hardly access anything. I cannot defrag it for the same reason. This happens to be a major problem, as I have many school-related files on there, not to mention some 70+GB of music. ):
Any help will be dearly appreciated. Thanks!
  • 6 more comments
  • Roflsalad Jun 13, 2008
    Please note, this isn't the same problem as before- I can't use it at any point, period.
    I'd love if that solution worked, however, It doesn't help; whenever I plug it in at any later time, it simply causes my computer to lag to an unbelieveable point. I can't do anything.
  • Roflsalad Jun 16, 2008
    Thank you for trying, I'll see if that works.
    Okay, well, this is interesting.
    I've had it unplugged for a little over two days now. I plugged it back in just a moment ago, and two interesting things happened;
    One, It detected it was a disk (Had uninstalled earlier, and had been unable to re-install)
    Two, upon the restart, it did not cause Windows XP to hang- however, I cannot access it. Though it appears Windows does indeed detect it, in a way. Many of my desktop shortcuts go to that HD, and the icons have re-appeared now that it's re-installed. However, I cannot get to it, even through device management.
    How long would autoplay take to register around 200+GB of files?
    Because as it stands, every time I try to cancel, it continues scanning in the background, or something similar. So, what happens if I let it read?
  • Roflsalad Jun 17, 2008
    Woof. I'll check, considering a good chunk of those are pictures.
  • Roflsalad Jul 06, 2008
    Well, it's been almost a month, and still no progress, sadly. One (very) temporary solution I have found is to try and stop the EHD from 'Safely Remove Hardware'. While it tries to stop, it frees up my computer temporarily from the lag. I only have about 30 seconds though, as it pops up with a message saying 'The device 'Generic volume' cannot be stopped because a program is still accessing it.'
    Now, this leads me to believe one of two things.
    One, I've got some sort of virus or the like.
    Two, Autoplay is not allowing the EHD to come into use. (Or some other windows program.) If it's one of my programs, (mostly some games) I'm rather unsure of what that would be, considering they're all on it.
  • Roflsalad Jul 13, 2008
    Nothing virus-wise, so I'll assume it's just the EHD.
    Well, I'm going to give up at this point, get a replacement in a month or so.
    I'll keep this one though, just in case there's ever a solution to this posted.
    Thank you for all your help!
  • 2,794 Answers
Heres what you do.
Don't plug your external HD in while the computer is booting up. It's looking for Windows on your external hard drive. Hence the black screen.
Plug your USB or Firewire cable back in once Windows is finished booting up.
Mine does that sometime too.
Posted on Jun 13, 2008
  • 1 more comment
  • Tim Babcock
    Tim Babcock Jun 13, 2008
    Windows is scanning the drive for pictures and things. You could take if off auto play in the properties and see if that helps.
    Then you can defrag it.
  • Tim Babcock
    Tim Babcock Jun 16, 2008
    Once it gets done reading it, it will try loading up pictures. If you have a photo software asssociated with it, it will add the pictures to the album.
    Depends on how many of those types of files you have.
  • Tim Babcock
    Tim Babcock Jul 07, 2008
    Wouldn't hurt to scan it for viruses and spyware. If there was some in the computer that would bog things down.
I cannot format my external disk: WD My Book 1110 Essential Edition WCAV57909867 1TB. It looks protected for writing. The disk, tested with WinDig.exe, results good. Taken to the shop where I bought it,...
formatting looks possible??? with xp and vista
You will have to be the computer administrator to change any values on any hard drive
click start control panel user accounts you should see a box with the administrator and the guest account if you have made one click on the administrator this may vary depending on which operating system you have
click start click to open on my computer you should see your hard drive usually C: right click select properties there will be an array of options select the security tab option then advanced make sure you have full control in windows 7
hope this helps you
Aug 18, 2011 | Western Digital 500gb Mybook Essentials...
I got anew computer with windows 7 and I would like to use my wd mybook 500gb how do i get this to work my book is compatillite with windows vista/xp/2000
External Hard drives are not designed to an operating system version, they will work with any windows system. The only difference is between MAC and windows.
Remember windows 7 is designed for people who don't know anything about computers, so they can just use it without knowing anything.
So windows 7 will work with anything more then vista will.
Don't worry it will work fine with win 7.
Feb 14, 2010 | Western Digital 500GB My Book World...
Mac not Reconize my MyBook
load the driver for mac use, the external hard drive comes with cd, the mac driver should be inside, load it to your mac computer. if you donot have the cd go online to western digital and download it. just load the driver and u will be fine, make sure u connect the cable in right places.
Mar 09, 2009 | Western Digital My Book Essential Edition...
MyBook not recognized by Mac
I am having the same problem!!!! I have my time machine backups on there and I cannot access them! Class action lawsuit???
Mar 09, 2009 | Western Digital 500GB My Book World...
WD5000 My Book 500 GB -- I/O error cannot access
i had exactly the same problem with a WD 500gb External HD MyBook Edition USB , eventually opened up the case removed the 500gb Caviar disk put it in an external HD Case (AC Ryan's AluBox)
and still had I/O error !!! i had serious music projects and stuff i didnt want to lose , after lots of research and looking around this program SAVED MY LIFE AND ALL OF THE STUFF IN THE HARD DISK !!!!
Ontrack EasyRecovery Professional v6.20 retail first i run the simple in-depth diagnostics then i used the EasyRecovery DataRecovery option and after about an hour of scanning started copy-pasting all my files onto another disk ! this app saved my life a special thanks to its programmers ! im John from Greece , hope this helps bro!
Nov 28, 2008 | Western Digital Caviar SE16 (WD5000AAKS)...
WDC WD1600 netcenter with 1 TB external WD MyBOOK
just called western digital and the solution is: buy an 500Gb disk, that is the max this machine can take....
Nov 21, 2008 | Western Digital Essential NetCenter...
WD Hard Drive Not Detecting
Yes, this can be done via the user web interface, by typing in mybookworld or wdstorage into the web browser and the shared storage manager should come up. If you go to general setup there should be an option to update network settings.
Oct 31, 2008 | Western Digital 500GB My Book World...
I have two wd mybook, how me register them on my PC?
If windows 98SE, go WD website and download drive. If you have windows xp, just plug it in and it should auto detect.
Sep 18, 2008 | Western Digital My Book Premium ES...
Acces denied
If you have linux experience and are up for a bit of hacking, here is a solution to your problem:
http://mybookworld.wikidot.com/forum/t-55527/large-file-copy-problem-solved
I bought a 1Tb MyBook World Edition, and it was little better than a doorstop because of the "Access Denied" bug. However, now it runs like a dream.
More things you can do with a MyBook:
http://mybookworld.wikidot.com/start
Far far better than WD Technical Support.
May 18, 2008 | Western Digital 500GB My Book World...
Western Digital My Book Essential Edition (WDG1U5000N) 500 GB Hard Drive Logo
537 people viewed this question
Top Western Digital Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
