Question about NAD C320 2-Channel Amplifier
Hello, I am looking for a NAD C-520 CD mechanic (mine is faulty). The CD lens looks good but gears are locking the cd often and preventing the lens to go up, lock and read the CD. If someone has a NoS mechanism, I would be glad to buy it.
    Genius:
  • 1,175 Answers
I've worked on those before. Have you tried changing the draw belt? Works for me
Posted on Nov 03, 2010
Testimonial: "Thanks, i will try the belt, if I can fnd one ;) Nonrtheless, it seems the gears are too old to lock the laser tray up. Thanks "
Cd player won't eject or play cd's in my jaguar xk8
The Cd loader mechanism is faulty. Replace it.
Jun 06, 2012 | NAD L40 CD Player
My cd rom does not read dvds
you might as well check your Toshiba PC Laptop if your CD-ROM can read DVD's .. Look at this figure... ryanpajaro20_6.jpg
There will be a hint for you to check the Optical drive if it has the DVD label. Otherwise , consult Toshiba for it...
Mar 18, 2011 | Toshiba Computers & Internet
I get a no disc message even though there is a disc in the machine.
Hello
there are two option of such fault
1. lens is dusty, clean the lens using moist cloth/cotton 2. lens got bad need replacement
third option is CD is faulty/scratch
hope it helps. do rate if so
Dec 12, 2010 | NAD C542 CD Player
The problem of my camera is about the lens,cause It doesn't go out properly, and now its really not coming out and it has a sign that says lens error appears on screen, and now my question is how to fix...
If otherwise the camera is taking pictures and working OK, then we can assume that the lens mecchanism has jammed in and needs a mechanical reset. Use good tools to remove carefully. Keep the entire ecrew and remove , make notes of the screw, position if needed. get access to the front hood and look for faulty mountings or alignment issues.Look at the motor on the lens mechanism remove and use a tool to roll the gear to see if the lens moves in/out. if not check for locked dirt or misalignment. Set accordingly. It may require a lot of patience to sit with a proper lighting and look into this issue. Hope you get this right, good luck.
Aug 16, 2010 | Nikon Coolpix 3700 Digital Camera
My NAD C 541 cd player will not play any discs. I open it put the disc in and it tries to scan and then rejects the disc and opens on its' own. There is the word 'over' in red below the track number...
It could be the belt for the tray mechanism. Tray closes then motor is pushed up to CD. If belt slips or physical mechanism is sticky CD will not spin and tray will reopen.
Nov 09, 2009 | NAD C542 CD Player
I have a shaker 500 car stereo with a 6 cd disk changer in a 2005 mustang that we recently purchased. At first it played fine, but a few weeks later it got to the point of which it could'nt read the cd's....
dosent sound like a laser issue , more mechanical . anyone put an object in the slot? see with mimni mag llite , somethings hanging up the eject mechanism
Oct 23, 2009 | Car Audio & Video
NAD C521 CD Player It will not play my CDs. The CD drawer closes normally with CD in place but after a pause, the drawer opens again. There is no 'no disk' warning. The 'no disk' warning does appear...
The tray belt raises the laser to proper focal length at the end of closing the drawer. This demands more grip from the belt. If the belt is sloppy, it will slip at this point, even though the drawer is shut. Took two years of repeatedly cleaning lasers to notice this.
Sep 07, 2009 | NAD C521 CD Player
CD player does not rotate
Hi there.
There could be a couple of reasons. I doubt very much that it is due to the lens. First thought is that it is probably the locking mechanism. If you look at the cd loading mechanism, there is a small plate with a locking tab that moves into place to hold the carousel still when the unit is loading a cd. This plate slides along the bottom of the unit between the cd loader and the carousel.
Secondly, it could be that the carousel is jammed on the rotating platter that it moves on. A couple of screws and it should come out - be carefull not to bend anything!
Thirdly, check the stepper motor that turns it - but I doubt this is the problem either as you said you couldn't turn it by hand either. You will need to remove the carousel to do this.
Good Luck !
Feb 10, 2009 | Sony CDP-CX235 200-Disc CD Changer
NAD C520
The transport may have been forced out of alignment if jamming mechanically may require removal and reinsertion while in the open position if , but if it appears to not have the "grunt" to drive the drawer from slipping belts, you will need to change the load belts. Belts slipping are preventing the mechanism from operating correctly. Can be a tricky job if you dont do much of this sort of thing, but is within the range of most handyppl.
They are in Aussie, but you can get drive belts for any peice of gear from WES Components by mail order.
http://www.wagner.net.au/catalogue/index.htm
Jan 27, 2008 | NAD C521 CD Player
Laser unit NAD 5100 Monitor Series
Hey, I think you can bye new laser here http://www.pltv.org.uk/laser.htm I have a nad 5300 monitor series, same laser as 5100, you can buy the hole cd player from http://www.miguelovitch.dk Laser work, but problems with cd transport. When i 'help' the cd transport, cd play as expected. And i agree, it is a nice cd player, also i have heard lot of nad cds on quad 405, sounds realy good. Try to visit my site, i also have a lot of free schematic for nad, denon, quad and mora. Also repair notes for amplifiers, tech videos, diy schematics and more.. Also at this moment i am working on a new 'nad cd service movie) including cleaning, maintenance, repair and more on nad 522, 501, 502 c521 and more see you best regards michael miguelovitch http://www.miguelovitch.dk
Aug 14, 2007 | NAD C521 CD Player
NAD C320 2-Channel Amplifier Logo
110 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
