Question about Acer Computers & Internet
HOW DO I INCREASE CONTRAST ON MY ACERAL1917WA DISPLAY? i CAN GET TO THE CONTRAST SETTINGS USING ONE OF THE FOUR BUTTONS ON THE DISPLAY, BUT I DONT KNOW HOW TO CHANGE THE VALUES. THANKS
    Novelist:
  • 119 Answers
Try to go to your display properties and under monitor folder you will get to see how to change the gamma settings to get your desired contrast or color settings
Posted on Jun 13, 2008
How can I decrease brightness and contrast?
To help you change the brightness and contrast settings from the LCD monitor, please follow the instructions mentioned below,
The control buttons are located at front panel of the monitor. The Brightness Button is used to select the Brightness/Contrast adjust functions. Press to switch functions or adjust settings.
To decrease the brightness or contrast press (-) button & to increase (+) as per your adjustment.
GuruAid.com
Mar 29, 2016 | Dell E173FP 17" LCD Monitor
Contrast Problem
You will need to adjust the contrast and brightness down to about 50%.
Apr 20, 2008 | HP L1706 17" LCD Monitor
HOW TO SET BRIGHTNESS OF THE SCREEN?
Dear User...
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.) For more information about calibrating your display color in Windows, see Calibrate your display.
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor. Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Thanks....
Feb 07, 2013 | Computers & Internet
How can i turn down contrast on my laptop
Acer Aspire one
Brightness is controlled by the Fn and arrow keys.
Contrast can be controlled from the software.
FN key, + left/right arrow key's
other Acers
Log on to your Acer laptop and click on the "Start" button. Choose "Control Panel" from the menu.
Double-click on the "Display" icon in "Control Panel" and select the "Settings" tab.
Check the "Color Quality" settings and make sure they are set to either medium or high.
The high setting will give you better color quality and contrast, but it will also use more system resources and shorten battery life.
If you are operating on battery power you may want to move the setting to medium.
Hold down the "Fn" key and press the right arrow at the same time.
This key combination will increase the brightness of your screen.
To decrease the brightness and contrast, hold the "Fn" key down and press the left arrow. Continue using these key combinations until you have found the optimal setting for your laptop display.
hope this helps
Oct 08, 2012 | Acer Aspire One D255E13438 Netbook
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
Brightness and contrast symbols
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
How to make the images darker
Push the 'OSD' ("On Screen Display") button on the bottom-edge of the monitor.
Use the LEFT/RIGHT buttons to select BRIGHTNESS or CONTRAST.
Use the OK button to choose that selection.
Use the LEFT/RIGHT buttons to decrease/increase the BRIGHTNESS.
Use the OK button to confirm the setting.
Use the LEFT/RIGHT buttons to select CONTRAST.
Use the LEFT/RIGHT buttons to decrease/increase the CONTRAST.
Push the 'OSD' button to exit from the OSD.
Jun 01, 2011 | Acer AL1916W 19" LCD Monitor
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
Screen is dark
adjust it with, with the buttons, to increase the contrast,
either go to display settings in control panel,, and adjust your screen resolution and, brightneess
May 16, 2010 | Dell Latitude D600 Notebook
How do I adjust the brightness? It's too much?
By following these steps u can adjust the brightness
Step 1
Press "Menu" on your LCD's display panel (usually below the screen). Various display options will be shown on the screen.
Step 2
Select brightness from the options. This is usually indicated by a sun. Use the "+" and "-" buttons on your display panel to increase or decrease brightness.
Step 3
Select contrast from the options. This is usually indicated by an oval half black and half white. Use the "+" and "-" buttons on your display panel to increase or decrease contrast.
Thank you
Mar 28, 2010 | Sceptre DCL 7A 17" Flat Panel LCD Monitor
More Brightness
on the front of the monitor there are key buttons naming menu, ok button and left & right arrow marks buttons first press menu button then go to brightness then by using arrow keys you can increase & decrease the brightness once you are finished decreasing r increasing press ok button.& there are many other settings you can change like contrast etc....
Feb 07, 2008 | LG Flatron 775FT 17" CRT Monitor
Computers & Internet Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
