Question about Krups XP4030 Espresso Machine
The coffee oozes out the top of the ground coffee holder as pressure builds up and does not run out through the coffee. Please advise Lara
  • 421 Answers
Lara,
You need to check the brew head, its above the filter holder. I would imagine that it is blocked with scale, when did you last descale it?
Posted on Nov 03, 2010
Why does my Keurig smoke when brewing coffee, and the water doesn't go through until I take out the cup?
You probably have a clogged nozzle/needle. Take a straightened paperclip and run it thru the hollow needles that puncture the top and bottom of the k-cup. Make sure they are clear then try to brew a cup. Never reuse a k-cup. That's what usually clogs the needles.
Sep 19, 2014 | Keurig Coffee Makers & Espresso Machines
Why does ground flow from the top of brewer instead of coming through the dispenser?
Buy a new K-cup holder from amazon.com. Its the black cone shaped holder.
Jan 11, 2013 | Keurig B70 Coffee Maker
When I put a k-cup in and it brews the coffee, it leaves coffe grounds all over the top of the k-cup and in the holder area and I get some in my coffee, it looks like the top needle is making too big of...
Sorry to read about your problem, I hope this helps you out.
I would follow the cleaning list below, I an addition you may have a bad batch of k-cups
plus just run some hot water, with out a kcup in the holder.
  1. Remove the K-Cup assembly
    To remove the assembly from the brewer, open the cover by lifting the handle. Grasp the top of the K-Cup Holder with one hand while pushing up on the bottom of the assembly from underneath with the other until it releases. The K-Cup Holder is dishwasher safe.
  2. Clean the Funnel
    The Funnel can be removed from the K-Cup Holder by pulling on it until it snaps off. The Funnel is dishwasher safe. To replace it just snap it back onto the K-Cup Holder.
  3. Clean the exit needle
    The exit needle is located on the inside bottom of the K-Cup Holder. If coffee grounds or cocoa mix gets clogged in the exit needle, it can be cleaned using a paper clip or similar tool. Remove the Funnel from the K-Cup Holder, insert the paper clip into the tube and move it around to loosen the clog and remove any debris. Please note, you cannot poke all the way through the needle as the opening of the needle is located on the side and not the top.
  4. Install the K-Cup assembly into the brewer
    After cleaning, align the K-Cup Holder tabs with the opening placing the two front tabs on the bottom and the single tab on top and snap it into place by pushing down on the top rim.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
2 Thumbs - Somewhat Helpful
Dec 29, 2010 | Vacuums
Top will not unlock
It seems to be caused by pressure build up (not a vacuum) when the outlet of the pod holder gets blocked. There are three plastic bolts that slide into place to lock the lid as the lever is operated. Pressure forces the lid up and increases the friction on the bolts to the point where they won't operate. Solutions 1 and 2: First disconnect Senseo from the electric supply. Solution 1 is to press down on the lid to overcome the pressure and then operate the lever to unlock. Didn't work for me. Solution 2 is to get a table knife, not sharp, no serrations but with a rounded end, not pointed. Insert under lid just to right of pod holder handle, at an upwards angle of about 20 degrees to the horizontal. Then aim for the opposite 11 o'clock position on the closed lid. With a few tries the knife blade should slide between the top of the pod holder and the rubber sealing gasket releasing the pressure. Beware hot steam/water as pressure is released - wear gloves. Open lid, unblock pod holder hole with a pin, fill and heat resevoir and then flush through without a coffee pod in place.
May 21, 2010 | Philips Senseo HD-7810 Coffee Maker
Coffee grounds in the cup
since you said usually... I suspect the rubber seal that surrounds the top needle is not seating well...
you can verify this by making a beverage with a k-cup and, just before the water starts, add a little hand pressure to the K-cup arm pushing down a little bit... not hard...
If it consistently makes a good beverage, then we focus our attention to that piece of the brewer...
when the consistency of the water changes, it tells me to look for leaks or unusual percolation of water...
you can verify the K-cup holder is ok... but another way to simulate the hand pressure is to put a shim of some sorts under the lip of the k-cup... like the thickness of a couple sheets of paper under the rim... not the actual k-cup... but the k-cup holder... raising it up a smidge is the same as the slight hand pressure...
I would look to see if the rubber seal has come loose around the top needle....
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
May 04, 2010 | Keurig Platinum B70 Coffee Maker
Coffee ground are coming out of the k-cup area
Make sure the needle in the bottom of the K cup holder is not missing, broken or bent. Also, look at your used K cup when it comes out. Is there a hole in the top and the bottom? It sounds like the pressure is building up within the K cup due to a backup at the bottom of it. This could also occur if the bottom needle hole is obstructed. Be careful...the needles are sharp!
May 20, 2009 | Keurig B60 Coffee Maker
Cuisinart DGB coffee maker
there is two little plastic pieces sticking out of the bean holder and on the coffee maker where the bean holder goes there is 2 holes, take the bean holder and put one piece of plastic in the coffee maker holes at a time and it should fit just fine...
Sep 13, 2008 | Cuisinart DGB-600 Coffee Maker
B-50
the needle in your k-cup holder is broken and over presure built up in the k-cup, and create security stop. Change our k-kup holder. if the needle is still in place the k-cup must be puncture on both side on top and bottom. if is right our needle can be block. clean with a little rod of stainless steel.
Nov 03, 2007 | Keurig B50 Coffee Maker
Krups XP4030 Espresso Machine Logo
266 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
Ray Murphy
Marvin
Marvin
Steve Allison
Steve Allison
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
