Question about HP Deskjet 6980 InkJet Photo Printer
How to change black ink cartridge of HP Deskjet 6980
HP Deskjet 6980
How to replace the black ink cartridge.
  • Anonymous Mar 12, 2014
    how to contenues HP Deskjet Ink advantage 2010
  • Anonymous Mar 31, 2014
    hp deskjet 3520 will not print in black ink
For the 6980 the carriage should be parked on the right side of the machine. I had something blocking the bottom of the cartridge from being pulled out of the slot. I turned off the machine waited a bit, plugged it back in and after it did it's reset it moved out of the way. I was then able to pull out the cartridge.
Posted on Aug 04, 2011
  • HP Master
  • 2,794 Answers
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Posted on Jun 13, 2008
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
I have an HP Deskjet 6980. After changing the black ink cartridge i tried to print. The printer takes the paper but doesnt print, just the Power and the resume lights are blinking. If I press the resume...
The printer might be working but the cartridge is not connected properly. Just open your printer, remove the cartridge and replace it back in its right position.
Mar 25, 2011 | HP Deskjet 6980 InkJet Printer
Black print is faded on my HP deskjet 6980 printer. Whenever I print a word document it will have sporadic fading. It will be fine in one place then all faded in another. I've cleaned the cartridges and...
Here are some steps you can check to resolve your issue.
Check if the ink cartridges are low, specially the color black since if the black is empty, you are using the colored cartridges to print black. If the cartridges are newly replaced check the cartridges by reseating it. Try to consider changing the print quality high but doing so will use more ink. If still the same try to clean your printer heads.
Here are the instruction for cleaning your printer.
Open the printer tool box. (open a word, then click on file then print, choose properties, then services)
click on clean the print cartridges, then clean. Do test printing as well to check if the color is correct. If still the same calibrate the color which can be found in the same menu.
For more information here is the link for step by step instruction with visuals.
Hope this will help you resolve the problem.
Thank you for choosing fixya
Mar 03, 2011 | HP Deskjet 6980 InkJet Photo Printer
Removed black ink catridge for a moment and when I replaced it the printer put out message "wrong cartridge installled
Check the no. of cartridge if correct.Your need to remove it again then re-insert it properly.Do it 3x or more.
Oct 03, 2010 | HP Deskjet 6980 InkJet Photo Printer
Orange cartridge keeps flashing after cartridge
Are you using a factory new HP ink cartridge?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Also take a moment and make sure that all of the protective tape coverings have been removed from the cartridge.
Don
Oct 22, 2009 | HP Deskjet 6980 InkJet Photo Printer
I need to change the cartridge on my HP deskjet 6980. I don't remember how.
Here is a step-by-step tutorial on how to change the cartridges:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00569593&lc=en&dlc=en&cc=us&lang=en&product=467982
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 14, 2009 | HP Deskjet 6980 InkJet Printer
HP Deskjet 6980
start with a fresh set of US based drivers, and follow those instructions. get em here
Mar 09, 2008 | HP Deskjet 6980 InkJet Photo Printer
HP Deskjet 6980 InkJet Photo Printer Logo
774 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
