Question about LG Prada KE850 Cellular Phone
Voicmail options how do i pull up the dialling pad and press a number when making a call to an automated service where i need to enter numbers to continue or select the correct service? I can pull up the dial pad but when I press "1" to listen to a voicemal, or any other number to make a selection, it won't go through.
  • 1 more comment
  • lienohsosexy Jun 13, 2008
    To acces to your voice mail you need to key your password, but it's true, the key pad does nothigh.
    To fix this, you have to go to the main menu, settings, call, send DTMF tones and select "on".
    Hope this help.
  • Anonymous Jun 17, 2008
    How do you use the key pad while on the phone
  • Jessabell198 Jun 18, 2008
    I'm really regretting buying this phone. Why won't the keypad come up when you're on a call? Surely the designers couldn't have missed this out, problem is I can't figure out how to do it. HELP!!
When you r on a call and you need a keypad come up. Just press the voice button on the left , the keypad will come up.
Posted on Jul 19, 2008
Go to main menu, settings, call, send DTMF tones and select on. I had the same problem as you all and this fixed the problem for me :)
Posted on Jul 10, 2008
How to setup Speed Dialling on Samsung Galaxy Fame Phone
hie Pat all you nid to do is go to ur dial pad and then press n hold the number u want to assign and an option will pop up diecting you to your contacts
Dec 28, 2013 | Office Equipment & Supplies
I bought a sharp 903sh online through YesAsia. On my pc it shows up a sx833. I can't make or receive calls but it will send and receive texts. System sounds eg text arriving,are fine but the voice...
Dear Amaxeen ,
Well It Seems the configuration problem ,you should have to configure your phone properly for that ,if you wanna to use its aal features you need to download proper drivers and manual ,so that you can use it smoothly.
You can download all stuff for your Sharp 903 , from this link:
http://www.sharp-phone.com/country/downloads/downloads.php?country=GB&lang=en&product=903
Cheerup and Be Happy Always
Mar 07, 2008 | Cell Phones
How can i get my dial pad on my lg vu plus back on while on a call so when prompted to press a certain number by my credit card companies i can do so? as soon as i make a call the screen goes blank like in...
You need to go into your settings, sounds, key tones, and change from short tone to long tone. I've had this problem before with certain phones, but not all. this should let the automated service recognize the corresponding key you have entered.
Nov 13, 2010 | LG Cell Phones
After many years have misplaced the instruction manual for our Vista 200. Need to know how to set up names and numbers for the automatic dialling feature. tdijimmy@hotmail.com
First, ensure the display is bright enough. If it is not, press successively on the "Brightness key" that is located on the top of the phone above the "Memory key". You have 8 brightness settings. Note that the "Brightness key" has no label.
You are now ready to start programming.
1. Press the "Memory key". It is labelled "Memory" and is located above the "Memory keys" numbered 1 to 10 on the right-hand side of the phone.
2. Press the "Memory key" you want to program. (1 to 10)
3. Enter the number you want to program using the "Dialling keys"
1, 2, 3,
4, 5, 6,
7, 8, 9,
*, 0, #
4. Once the phone number is entered, press the "Memory key" again.
5. Now enter the "Name" for the phone number you just entered. To do this, you press the "Dialling keys" as follows:
For A press the "2" key once,
For B press the "2" key 2 times,
For C press the "2" key 2 times,
For Q press the "7" key 2 times,
For Z press the "9" key 4 times.
Use the same for all letters.
To go to the next letter, press the "Right arrow key".
For a space, press the "Right arrow key".
6. Once the name is entered, press the "Memory key" one last time. You are done.
7. To test it, press the "Memory key" you just programmed.
Oct 19, 2009 | Bell BE-412CID Corded Phone
How to switch fixed dialling on nokia n73?
Press menu button and select Contacts > Options > SIM contacts > SIM directory to see the names and numbers stored on the SIM card. In the SIM directory you can add, edit, or copy numbers to contacts, and you can make calls. To view the list of fixed dialing numbers, select Options > SIM contacts > Fixed dialling contacts. This setting is only shown if supported by your SIM card.
Oct 17, 2009 | Nokia N73 Cellular Phone
Reset users pin
Settings for the Administrator Mode 1 Call the Utility Mode to the Display. ❍ Calling the Utility Mode to the Display (p.7-1) 2 Making sure that ?U--? appears on the Display, enter ?5? from the 10- Key Pad. 3 Press the [Start] key. Input Account Procedure (A-2) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?2? from the 10- Key Pad. 5 Press the [Start] key. 6 Enter the 3-digit account number from the 10-Key Pad. ? Do you know the restrictions on entering the account number? ➜ The account number must be in three digits ranging from 001 to 999. ➜ If an account number entered already exists, the entry will be rejected. Enter a different number. 7 Press the [Start] key. This stores the account number. ✎ Tip To program another account number successively, repeat steps 4 through 7. Using the Utility Mode 7 Di152/Di183 7-21 Delete Account Procedure (A-3) 1 Call the Administrator Mode to the Display. ❍ Settings for the Administrator Mode (p.7-16) 2 Making sure that ?Ad-? appears on the Display, enter ?1? from the 10- Key Pad. 3 Press the [Start] key. 4 Making sure that ?A--? appears on the Display, enter ?3? from the 10- Key Pad. 5 Press the [Start] key. 6 Press [ ] or [ ] key to select the account number to be deleted. 7 Press the [Start] key. The selected account number will be deleted. ? Do you know what to do to delete another account number? ➜ Repeat steps 4 through 7. 7 Using the Utility Mode You can go to the Konicaminolta US web site and down load a operators manual for youself
Apr 23, 2009 | Minolta Office Equipment & Supplies
Programing Speed dial on Walker W1000 Clarity Phones
I solved my problem by trial and error!
Steps to program speed dial on the Walker/Clarity Model W-1000 Touch Tone Sound Amplifier desk set phone w/large number pad.
1. Choose phone number to program including the (#1) digit for a long distance direct dial if
needed.
Write chosen number(s) on a scratch pad as a guide for numbers. Identify numbers with the
names or contact description (ie."Mom's Cell Phone.")
2. Remove hand set receiver from phone.
3. Press "memory set" button ONCE on the phone located uder the receiver on the desk set.
4. Enter phone number chosen,including area codes and long distance prefixes if needed!
5. Locate the speed dial position button you want for that number...(located adjacent to
tag/pad slot for name and/or phone number to be written after entering.
6. Press the speed dial position button (ONCE). Then replace receiver back in craddle.
7. Try out speed/dial program. Pick up receiver, push speed dial button(position) listen to see if
correct phone number is contacted. Once established as correct; program additional speed dial
numbers: ie family, business, as needed.
8. DO NOT TRY TO PROGRAM THE NATIONAL EMERGENCY 911 NUMBER! Keep this in your
own memory!
9. If you make a mistake while entering a phone number: Stop, Hang up phone and start all over
again in the procedure sequence.
10. Remove white "description pad with slots for names or numbers) from underneath clear
plastic cover.(use a paper clip end to lift up plastic cover). Write name/description for that number
on white pad(ie. "Mom's Cell") Use a PENCIL FOR DESCRIPTIONS!!
11. TO SAVE TIME AND INCONVENIENCE TO PERSONS/BUSINESSES OF HAVING TO
ANSWER YOUR CALLS; CHOOSE A AUTOMATED ANSWERING NUMBER (USUALLY A
BUSINESS ANSWERING AUTOMATED SERVICE (IE. LARGE INSTITUTIONAL PHONE
NUMBER THAT HAS A MENU PROMPT usually a AT&T 800 # will have a prompt menu
USE this procedure to see if you program correctly then once you know how; go back and re-
enter all the numbers that you actually want on your speed dial settings.
Nov 28, 2008 | Panasonic KX-T7730 Corded Phone
Cordless telephone sw/from pulse to tone
dear,
check this link and hope it will solve the problem
http://www.epinions.com/content_56960192132
regards,
Aug 15, 2008 | Uniden Cordless Phone
Speaker key and deleting voice mails
you hit the speaker button on the left side of the phone and the pad shows up...
Apr 22, 2008 | LG Prada KE850 Cellular Phone
Phone does not work for teleconference services that require a pin number
I've found dialing numbers to navigate automated answering systems through Skype to be unreliable in general. Sometimes it works, sometimes it doesn't. This holds true for using the numpad on the keyboard, my free-1 usb skype phone, AND now the new Philips VOIP8411B I got in the mail yesterday. I'm not surprised that the Philips doesn't work, since I've had the problem before, but still disappointed...
The only way I've been able to work around this problem is to make the call on the computer and dial numbers through the on-screen number pad (using my mouse) to get through automated systems that don't work with a handheld device. Yes, this defeats the puprose of buying and using all these cool gadgets like the Philips and the free-1, but only for these certain types of calls. And even when I use the on-screen number pad, it still doesn't work sometimes. That's when I start punching numbers frantically and hoping a real person will pick up the line... lol
@Pat56 - If you use teleconferencing so much, maybe it would be best just to do it through the computer with a USB headset instead of using the Philips VOIP8411B...? Just a thought.
Oct 27, 2007 | Philips VOIP8411B/37 IP Phone
LG Prada KE850 Cellular Phone Logo
67 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
