Question about Bushnell 675x5 EQ Reflector Telescope
Telescope venture rx9 view blocked
I can view the moon but when i try to view a star i see the center of the object blacked out by a black disk with light around it
  • blythestar Jun 15, 2008
    yes, i can see the moon clearly. what i see when i try to view something else like a panet or star looks like a plate is in the center with light around it, there are also 3 spots where the light around it is blacked out @ 12:00, 4:00, 8:00
  • David Duffell
    David Duffell May 11, 2010
    When you see the moon, Is it clearly and well focused?
    Cheers Dave
I have this same issue. A star or planet is vlocked by a circle with 3 prongs - like the mirror holder in the tube.
Posted on Oct 19, 2009
Can't see anything we just set it the +venture Rx-Telescope
Posted on Mar 23, 2009
Seeing the stars
The stars will always be "points in the sky" no matter what telescope.
The stars should be sharp, focused points in the center of view (more blurry towards the edges because of the stock eyepieces and the fast telescope mirror) if not, the telescope may need collimation. (look at instructions and/or search online. Plenty of instructions on the net.)
  1. Get Stellarium or another fine astronomy program
  2. During the day, point the telescope at a part of the landscape about 100 yards away.
  3. Use the lowest power eyepiece (highest number) in the focal tube.
  4. Center the landscape object in the telescope.
  5. Align the finder scope so that it points exactly where the main telescope is.
  6. At night, leave the scope out to reach thermal equilibrium (about an hour for small reflectors and refractors)
  7. If the scope is on a EQ mount, polar align.
  8. Point the finder at the moon. The moon should be in the main scope also.
  9. Practice finding the moon before you start on the planets
  10. Once you are comfortable with the moon and planets, you can go for the deep sky objects
Dec 23, 2012 | Optics
Viewing
take it back where you got it for replacement
Nov 19, 2007 | Bushnell NorthStar Goto 100mm 788840...
Celestron astromaster 114eq see only pitch black
Dec 27, 2011 | Celestron AstroMaster 114EQ (100 x 114mm)...
Hi ive got a galaxsee tasco telescope but im having trouble seeing anything at night, i've took all the caps off lined up on a star but its just pitch black can you help thanks.
1. During the day, point the scope towards an object and align the finder scope to the telescope.
2. First object at night should be the moon. it will verify your finderscope alignment and you should have a clear view of the moon.
3. Use your lowest power eyepiece (largest number in mm) and point the finderscope to a star. The star should be in the center of the eyepiece.. If not, adjust the finder until it and the scope are centered.
4. You can use your higher power lens on the star nd it should still be in the FOV (field of view)
5. Scope may need to be aligned (collimated). Instructions on this should be included with the scope
Mar 10, 2011 | Tasco Galaxsee 46114375 (375 x 114mm)...
Hi, a few days back I purchased Nexstar 4SE. I set it up exactly how it says in the manual still I cannot see any magnifying views from the eye piece. While aligning the telescope I can find the moon from...
Stars will always appear as points. It is not possible to magnify them enough to see them as disks because they are all extremely far away. A telescope will however show you stars and other objects that are too dim to see with the naked eye.
You will be able to see the planets as disks, and even features on the planets, such as the bands on Jupiter, the rings of Saturn and the phases of Venus, and also moons around some planets. There are other objects that will show more detail when magnified, such as nebula. You will be able to see a lot of craters and other detail on the Moon.
Your problem is simply that you are not pointing the telescope at these objects. This seems to be one of those telescopes that "automatically" finds objects, but these so called "go to" scopes only do this when they are set up properly. I can't say what step(s) you have missed, but clearly even if the scope thinks it is pointed at the moon, if you can't see the moon, it is NOT pointed there. The Moon will fill the field of view even with the least powerful eyepiece. If you are seeing stars as points, then the eyepiece is focussed and working properly.
Jan 13, 2011 | Celestron NexStar 4 SE Telescope
All we see through the telescope is black
New telescope users are taken by surprise at the difficulty of just pointing the telescope in the right direction to see anything. The field of view is quite limited, especially if you are using a high power eyepiece. The higher the power of eyepiece on a telescope, the dimmer the image, the more difficult to aim it at any chosen object, and the more difficult to focus. When the scope is not focussed, even if there are stars in the field of view, they will only be faint blurs.
It is best when you are starting out with a telescope to try it with the least powerful eyepiece (the one with the highest number) to begin with, until you become more familiar with how it works. Do NOT use the Barlow lens if one came with the scope.
The finder scope is meant to help you get the main scope lined up on the object you want to view, but it won't be any use in pointing the telescope until you adjust it to precisely line up with the main scope. Telescope manuals recommend that you do this in daylight, by pointing the scope at an object on the horizon and adjusting the finder to match (never point a telescope toward the Sun!). Once you have a tree or mountain peak in the center of the main scope's image, you can then adjust the screws around the finder scope to get the crosshairs (or red dot) centered on the same object. It is very difficult to do this job in the dark, especially as objects in the sky are constantly on the move.
You will find that there is a very wide range of movement in the focus mechanism, because different eyepieces focus at different points, but the actual focus range for any eyepiece will be a small part of the overall range afforded by the focusing mount. It is much easier to familiarise yourself with this in daylight.
At this point you will learn that astronomical telescopes usually show an upside down image. There is a good reason for this- erecting the image needs more bits of glass in the light path, which reduces the amount of light and increases aberrations. Even if this is only slight, astronomers prefer to avoid it, and they don't really care which way up the Moon or Jupiter appear. It is possible to fit an erecting prism or eyepiece to most astronomical telescopes, and some of them come with one, but one wouldn't bother to do this with the small finder scope.
Once you have done the above, you can try the scope at night, on an easy to find bright object like the Moon. Looking at random stars will probably be disappointing, as they don't look different under magnification. You will have to find planets, star clusters or nebula to see anything interesting. You will also find the the object you are looking at swims out of the viewing field, and you must continually move the scope to follow it. This will be more pronounced at higher magnifications. Again, use the least powerful eyepiece. Small scopes are often advertised as having unrealistic powers (300, 500) which can never be practically achieved. You just get dim blurs.
There is an excellent website for beginner telescope users at THIS LINK
Jan 08, 2011 | Tasco Novice 30060402 (402 x 60mm)...
I have a Meade EXT90. A black dot appears in the middle of every object I view (Jupiter, Mars, etc) with the exception of the moon. Any ideas on waht that might be? Thank you.
The black dot means you are way out of focus.
In an ETX90 Mars will always be a TINY disk, except under extreme magnification.
Jupiter is also a small disk but a little bit bigger.
Next time you try for Jupiter focus on the MOONS until they are tiny points of light like little stars.
Also certain eyepieces have this as an unwanted trait. Try another eyepiece -- start with the one with the largest number written on it which will be your LOWEST magnification.
Sep 08, 2010 | Meade ETX-90EC (325 x 90mm) Telescope
When viewing venus or other stars there a black spot in the center of the object. It appears to be the 2nd mirror refleting to the main miror. what have I done incorrect?
You are NOT in focus. Turn the focus knob a little until you see a perfect "disk" for the planet. Stars are always POINTS of light, with a telescope or without a telescope.
Aug 28, 2010 | Celestron NexStar 114GT (269 x 114mm)...
I see images in the daytime but at night complete blackness
Your scope must be pointed directly at the objects in the sky. They are very tiny, and no bigger than the tip of your finger held at arms length. Try for the moon first, and buy a good star chart like, "Sky & Telescope Pocket Star Atlas" available on amazon.com.
All telescopes have very small fields of view, 1 degree or less usually.
Also read my TIPS on my profile page.
Apr 04, 2010 | Celestron PowerSeeker 114 EQ Telescope
When i view a star or small object through my reflecting telescope i can see the reflecting mirror in front of the image. this does not happen when viewing the moon.
You may need to realign the mirrors and the view piece. You can look at the mirror from the front and your eyeball should ne centered.
Aug 28, 2009 | Optics
Bushnell 675x5 EQ Reflector Telescope Logo
1,804 people viewed this question
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
isaac johny
isaac johny
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
