We have an Electrolux Eco Valve 6.5kg front loader and it is beeping and coming up with E20. What do we need to do?
  • 10 Answers
SOURCE: electrolux Front Loader 7 Kg Error
From the manual E20W Problem with water draining
Posted on Feb 08, 2010
  • 139 Answers
SOURCE: er20 comes up on my washer
Your on the right track .... To narrow it down all you have to do is disconect your waste pipe from under the sink or where ever it goes to and lower it ground level , if the water startss to flow out by means of gravity then you have no blockage and its the pump if water does not flow out then its a blockage....
Either to clear the blokage or change the pump turn the machine upside down as both are easily accessible from there hope this helps... any questions dont hesitate to ask...
Posted on Jan 22, 2008
SOURCE: Electrolux XL8KG Front Loader Washing Maching
I've found that a similar thing on my Zanussi appears when the filter on the output is clogged. Removing muck and hair from the filter usually solves the problem
Posted on Nov 20, 2008
SOURCE: Zanussi Electrolux ZWF 1430 W (E20 error)
I had the same problem too. It was an error code caused by blocked filter. First of all you have to stop your washing machine. After that and before removing the blocked filter you have to remove the water from inside by using the small flexible tube which located next to the filter at the right bottom of the machine. Then the only think it still remains was to unscrew and clear the filter.
Posted on Mar 02, 2009
SOURCE: drum wobbles front and back
Hi
Washing machines usualy have springs on the front and back which can sometimes snap or come loose. you can usualy see these by looking at it from beneath.
Also they have a ballast which is usualy a small piece of concrete attached to the bottom of the drum. This is to stop it from bouncing around as well. these also have a tendancy to either snap their fixings (Bolts) or split and fall off.
In either sutuation it should be fairly easy to repair. I have had both of these situations on a BEKO. got the parts from the NET.
Hope this helps.
Posted on Jun 06, 2009
How do i reset an electrolux 1080
E20 is an error code for a drain pump issue. The error will reset itself if the issue has been resolved. If it or another code continued to appear, then the unit has not been accurately fixed.
Jul 19, 2012 | Electrolux EIFLW55HIW Front Load Washer...
I have a kenmore eco cycle front loader...E20 comes up
Should be still under warranty dont hesitate to call service tech. If your already having problems then you see what you have to look forward to. I think if they have to come out so many times they replace the washer not sure about that but I would call them
Sep 01, 2009 | Maytag EPIC MFW9700S Front Load Washer
I am having problems with an electrolux 12680 W. PNC 914522501 2007 production yr. It was making a strange sound and not pumping out water. No problem, I removed the front plug and cleaned out around the...
the hose coming from tub to the pump has a filter in it.you need to pull filter out and empty it.E20 means that you have a slow drain,or clog.If the pump is noisier than ussual then you may need to replace pump.but check filter first.
Apr 20, 2009 | Electrolux EW1000i Front Load Washer
Electrolux Front Loader 7 Kg Error Message E20
Sep 14, 2008 | Electrolux Washing Machines
Er20 comes up on my washer
Dec 22, 2007 | Electrolux EW1200i Front Load Washer /...
Washing Machines Logo
156 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
