Question about Kenmore 92812 / 92814 Electric Kitchen Range
Hello, The other day our oven sounded off with preheaded beeper. The only problem was no one was around or using oven and the tempature dial for oven was still in the off posision. I can turn the oven to about 500 degrees and it will shut oven off. Any ideas for this problem?
My toaster oven started beeping and showed a flashing error message. Anyone have any clue what may be wrong?
I suspect that the Logic Control Board is shot. If the unit is 1 year old or less try:
In the U.S.A., warranty is offered by Sunbeam Products, Inc., located in Boca Raton,Florida 33431. 1.800.334.0759
In Canada, this warranty is offered by Sunbeam Corporation (Canada) Limited,located at 5975 Falbourne Street, Mississauga, Ontario L5R 3V8
To refresh, the beeper should sound once. The definition of the Beeper from the manual follows:
BEEPERFUNCTION
(1) When you plug the unit in, the beeper sounds once and " - - - "appears in the LCD.
(2) When you press one of the four menu buttons the beeper will sound one time.
(3) When you press the adjustable button, every time you press the button, the beeper
will sound once. If you press the button continually, the beeper only sounds one time.
(4) When you press the start button the beeper will sound once, and ":" will flash, that means
the unit is in operation. Once the unit has begun the cooking cycle, the menu selection,
time or temperature cannot be changed. The unit must be stopped and reset.
(5) When the unit is in operation, press the stop button, the beeper will sound once and the unit
will stop operation.
(6) At the end of pre-set time, the unit will sound a long beep to remind you the work is done.
Jan 03, 2015 | Oster 6239 Toaster Oven with Convection...
Alarm sounds with F2 flashing and won't clear
,Hello,
The F2 error code means that the over overheated by at least 100 degrees above the tempature that was set at the time. The usual reason the oven would over heat by so much is a defective oven tempature sensor and the sensor would need to be tested to see if is the problem to test the sensor it would need to disconnected from the wiring to it and measure the amount of ohms of resistiance AT ROOM TEMPATURE when the oven is off and cool. At room temp. the the meter used to check the sensor should display between 1060-1100 ohms,if the number is vastly different that 1060-1100 at room tempature the sensor is defiently bad and should be replaced. This is what the sensor looks like oldtech2332_129.jpg
it will be inside of the oven chamber and again to properly check it the wiring should be unplugged and the meter leads should be placed into the plug at the end of the sensor to measure the ohms
GENE
Oct 10, 2011 | Kitchen Ranges
Buzzing and f2 showing on display panel
GENE
Oct 10, 2011 | Amana AOCS3040 Electric Single Oven
All the functions works well, but after a few minutes the oven stops and display "F2". The screen is well, the temperature selector, timer, clock, all works well but the oven stops functioning
GENE
Oct 09, 2011 | Whirlpool RBS275PD Electric Single Oven
GR448LXPS ERROR CODE E2F3
The F3-E2 error code means that the heated well above the setting the tempature was set at. The usual reason the oven would over heat by so much is a defective oven tempature sensor and the sensor would need to be tested to see if is the problem to test the sensor it would need to disconnected from the wiring to it and measure the amount of ohms of resistiance AT ROOM TEMPATURE when the oven is off and cool. At room temp. the the meter used to check the sensor should display between 1060-1100 ohms,if the number is vastly different that 1060-1100 at room tempature the sensor is defiently bad and should be replaced. This is what the sensor looks like oldtech2332_129.jpg
it will be inside of the oven chamber and again to properly check it the wiring should be unplugged and the meter leads should be placed into the plug at the end of the sensor to measure the ohms.
If after checking the sensor if its within the range of 1060-1100 ohms at room tempature the problem is going to be the control board.
I hope i have been able to help ya fix your oven,
Oct 08, 2011 | Whirlpool Ovens
Stove beeps and has f2
GENE
Oct 08, 2011 | Kitchen Ranges
Spacemaker xl (1999)low volume beep
According to the owner's manual (available here), there is a beeper volume on some models in this series. If yours has one, press it and then press 0 to 3 to control the volume (0 mutes the beeper and 3 is loudest).
If your model doesn't have the beeper volume control it's just that the beeper is going bad. They sometimes do that, getting faint or quitting entirely. You can't get a replacement beeper from GE, only the entire control circuit board.
The beeper is a piezoelectric type. Radio Shack sells a variety of beepers. If you know someone who can replace electronic components, they may have one that could be used on the board. Changing the beeper for one not the same as the original would not affect the oven's operation or safety, so that's an option. I'd do that myself if I were repairing this for a friend. But you might not be able to get a professional service shop to do this because of liability concerns. They would most likely replace the entire board.
With luck, your oven just has the volume down. Hope this has helped, and thanks for using Fixya!
Feb 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My Maytag wall oven CWE9000ACB is giving me a fault code F2.
The F2 fault code is usually for a out of limit tempature reading due to a faulty temp probe or excessive temp during clean cycle with door unlocked. If you have disconnected the power for over 10 minutes and the error keeps coming back then you will need to test the tempature probe to see if it is defective. Test with a OHM meter and at room tempature most probes should read around 1100-1300 ohms. if the reading is way off or open then replace the tempature probe.
Jan 18, 2010 | Sears 61301 Gas Kitchen Range
Oven shuts down before reaching correct temperature
You will need to check the oven calibration using a thermocouple based thermometer(the one you stick in the oven is not reliable). Electric ovens should keep a near constant tempature so if you have it set to 350 the oven should stay around 350 once temp is reached. Now gas ovens are a little different. Most use a on/off thermostat and that means the temp can vary from 320 degrees to 370 degrees to keep an average tempature of 350. So if it is a gas oven you will need to let it warm-up for 10 minutes then start taking the lowest and highest 5 consectutive readings. Then add the 5 reads together and then divide the number by 5 and it should be within 10 degrees of the set tempature. If it is off by more than 50 degrees then you might not be able to get it back to proper calibration. The calibration methods are different for each range and depend on the type of thermostat you have digital(push button controls) or manual(knob). The owner's manual for your range might contain the instructions or consult the manufacture's website for the instructions.
Dec 21, 2009 | Whirlpool Ovens
The beeps have become inaudible.
The beeper sound level can be adjusted. Press the BEEPER VOLUME button, then choose 0–3 for mute, medium or loud.
If that doesn't work, unplug the oven a few minutes, plug it back in, then try again.
If you don't have your owner's manual you can find and download one here:
http://www.geappliances.com/service_and_support/literature/
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 22, 2008 | GE JVM1651 Microwave Oven
Kenmore 92812 / 92814 Electric Kitchen Range Logo
35 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Marvin
Marvin
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
