Question about Amana ARB1905C Bottom Freezer Refrigerator
BB20 model. My freezer has ice building up in it. Do I need to have the freezer door resealed......or what?
4 Suggested Answers
TheMobilian
  • 8220 Answers
SOURCE: freezer does not defrost, builds up alot of ice to
It is probably going to be a bad defrost heater or defrost jeater terminator thermostat.b816000.jpgba32cc5.jpgfbddf1c.jpgof course it might be the defrost control11e7f93.jpg
AMANA BOTTOM MOUNT MANUAL
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Sep 02, 2010
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
EllaWatson25
  • 725 Answers
SOURCE: Ice dispenser frost build up - Amana refrigirator
This sounds like your ice may be melting and freezing around the chute. You may need to replace that rubber gasket on the chute. Otherwise, if you use a lot of crushed ice, that will build up badly on the chute and you can manually clean that off. I hope this helps you!
Posted on Aug 14, 2009
Why does my freezer build up with ice in the bottom
is it a frost free model? if it is the defrost timer may be out or the defrost element may be bad. but if this is not a frost free model the door seals may be bad and need replaced
Aug 24, 2014 | Amana ABB1922FEB (185 cu ft) Bottom...
Loud "clattering" noise from freezer area when refrigerator runs
There is a fan in the back of the freezer that runs when the compressor is running. It sounds like you have ice build up around the fan.
You could have one of these problems: (Sorted by most likely to least likely)
1) Auto Defrost timer, defrost bi-metal or defrost heater is defective - the unit will go into auto defrost about twice a day, if this fails you will have lots of ice built up around the cooling fins and sometimes on the fan. Pull the back off the inside of the freezer and check for ice build up around the cooling fins, there should be none or very little if its running normal.
2) Bad door gasket - if the freezer door is leaking warm moist air inside the freezer it could be condensing around the fan causing ice (you will also see ice build up on things inside your freezer too).
3) Plugged drain - the drain leads from the freezer down to the drain pain under the fridge. If this is plugged ice will build up on the bottom of the freezer and potentially around the fan.
Apr 01, 2013 | Kenmore Refrigerators
I have an Amana Temp Assure refrigerator (model# on panel BB20 or BRF20) The fridge is not cooling. The freezer appears to be working but here is extra frost in the freezer - mostly on the right side. If I...
I would check the evaporator fan and make sure that is is turning to blow the cold air from the freezer section to the refrigerator section. With bottom mount freezer, that fan is very important since cold air drops.
If the fan is operational then you need to check out the defrost circuit (defrost heater, defrost thermostant, defrost timer) and make sure that is operating. If you take off the back panel (interior) of the freezer, and see a lot of ice build up then you will need to defrost the unit (a hair dryer will speed up the process) and then troubleshoot the defrost circuit and order the parts you will need to fix it. Once defrosted, the unit should work for a several days to a couple of weeks before the ice buildup affects the unit again, which will give you time to receive the parts you need.
NOTE: When you defrost the unit make sure you are ready to deal with all the water. Either spongs and a bucket or a wet/dry vacuum.
Jul 14, 2011 | Refrigerators
Door jam icing up
door has to seal tight. also, there are door frame heaters called, "Anti Sweat Heaters." It is to prevent condensation and ice build up around the doors. Have that checked out.
May 24, 2010 | True 72 cu. ft. / 2039 liter Commercial...
Ice build up on bottom freezer
Ice build up on the freezer floor alone, with no ice on shelves or food above the floor, usually indicates a clogged defrost drain problem. when your unit goes into defrost, the melt water is intended to go down a drain tube from the freezer to a pan on the outside bottom of the unit, usually near the compressor. Sometimes these drains are clogged with food debris, other times some of the melt water does not completely drain, and freezes - this build up of ice can then clog the drain. You can unplug the fridge, with both doors open and a fan blowing for 24 hours to temporarily remove the ice and water, but it will return most likely, in which case you would need to have the drain cleared out and / or have a drain heater installed by a qualified refrigerator repair service.
Apr 07, 2010 | Maytag MFI2568AES Stainless Steel Bottom...
Loud humming noise coming from freezer
I believe what is happening, is your Evap fan has some build-up of ice on it. The reason it stops when you open the door, is the Evap fan cuts off. The Evap fan starts back up when the door is closed. What you'll need to do, is open the freezer door, and remove the back panel of the freezer. This takes some 1/4 inch screws and a couple Phillips I believe. Once you get the panel off you'll be able to see if there is any ice build-up on the Evap fan. If need, be take a hair-dryer on medium or low, and melt the ice off of it. This should solve your problem.
Mar 28, 2010 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
Top coil in upright freezer icing up
its a manual defrost freezer, it is normal to ice up, if it is unusually more than you have noticed over the past 40 years, see if the door liner is cracked around the screws under the gasket, if so put some washers there to reseal the door liner
Nov 01, 2009 | Freezers
Freezer compartment ice build-up
too defrost just open the doors for a day with the unit unplugged. as far as why it is frosting up check door seals make sure they are all good and seal it up well and that should take care of it.
Jun 26, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice accumilation next to fan in freezer compartment
u have a defrost problem need to replace heater and tstat
Mar 18, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Ice build-up on the inside top of of freezer door
This is a problem that the factory has released a bulletin on.They have released new hinges, and insulation for inside the door. So far I've only seen the bulletin for Kenmore upright freezers made by Frigidaire. Since it is a Kenmore the bulletin is a Sears Service Flash but the units are identical. For sears its SF46-517. They may extend the service to Frigidaire units but you'll have to contact Frigidaire about that.
Nov 04, 2008 | Zanussi Z57 / 3 Bottom Freezer...
Amana ARB1905C Bottom Freezer Refrigerator Logo
124 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Sal De
Steve
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
