Question about Gateway 400SD4 Notebook
Gateway 400SD4 Poweron password
Gateway set up is ****... how do I bypass my poweron password that no one knows and they want to charge 175$ to fix?
    Genius:
  • 2,028 Answers
Here's a link to show you how to get around the password. It gives you an idea of why it costs $175.
http://support.gateway.com/s/MOTHERBD/tyan/m00056/m0005613.shtml
Posted on Jun 17, 2008
What is the poweron password for cross mobile pd8
Did you set that password? if you forgot, consider the phone bricked. Time to get a new device or avoid setting encryption passwords you cannot remember...And again, use a password safe on a separate device, like a PC.
Jun 27, 2014 | Cell Phones
How to fix a gts- 5300
First of all, when you tray to unlock it with gmail, you must be near to WiFi network that you used before (you must have connection to the internet).
Second, if your WiFi connection is turned off from before, you can't unlock it with your google account.
Next step is to try wipe data / factory reset from android recovery menu. Press and hold VolUp+PowerON or, VolDn+PowerOn, or any combination like this with PowerOn button. But you will lost all your data.
Regards.
Feb 05, 2014 | Samsung Cell Phones
How do I uninstall poweron password?
Not sure I understand your poweron password issue. Is this within BIOS, or a program you installed in Windows?
If BIOS, then I have found that BIOS/CMOS Password Recovery Tool can be effective.:
Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords biospasswordrecovery. com
Nov 05, 2013 | Computers & Internet
How to change hdo password on gateway 400sd4
To change the password:
Enter password and then go into security settings. Enter your password again and then you can change it to anything you like. Password settings can be found in Control Panel.
Hope that helps.
Nov 22, 2010 | Gateway 400SD4 Notebook
Toshiba satellite laptop lockout
is it a windows password or poweron password? you must be wondering what are they?
windows password is when you have to enter the password to get into windows and before that you get to see the windows loading screen.
poweron password is hard to crack, it will ask a password on a black screen saying Enter a Password, and the background will be completely black in color.
if its a windows password, press the "Alt+Ctrl+Del" twice, you'll get a screen which will ask you a username and password. in the username and password type in, "Administrator" and password will be blank. hit enter. if it works, then for the rest of the steps, mail me at L2support.hp@gmail.com
Apr 29, 2010 | Toshiba Satellite Pro L300-EZ1501 Notebook
My laptop poweron password forget
login password or startup password? Startup password can be bypassed by removing the CMOS battery on the motherboard, shorting the memory pins and replacing the battery and restarting.
If it is the login password, if you are on a domain the domain admin should be able to reset it; if not, did you create a password recovery disk? Is there more than one username on the laptop, and can one of those other users log in and reset your password?
Mar 30, 2010 | Toshiba Satellite A100-S8111TD Notebook
I tried turning my phone off and it didnt work and i have no idea what happened to it...
Take out the battery. Then insert the battery again and see if the phone restarts. if it does then your poweron switch is stuck in pressed position. Or it is faulty. get it repaired. if it does not poweron then the switch may be alright. Poweron the phone. It should. Then try to poweroff the phone. should work.
Aug 23, 2009 | Cell Phones
Password on boot up
This usually works with a bunch of motherboards,
1. Open the CPU.
2. Unplug it from the power.
3. Remove the BIOS Battery.
4. Press Power without pluging it in a power supply.
5. (IF you can) Try and find a pin usually 3 of them with a jumper connecting 2 of them (middle and 1side) remove it and connect the middle and the opposite side and press power on again without plugging it.
(IF you can't find it) Just push the power button for about 30 seconds without pluging it.
Vote if it helps thanks
Apr 02, 2009 | Computers & Internet
Acer laptop problem
Is the charging light on when connected to ac, is the battery old or new? The power supply connector might be faulty either at the cable side or inside the laptop.
Jan 12, 2008 | Computers & Internet
Gateway 400SD4 Notebook Logo
146 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
