Question about IBM Lenovo ThinkPad R52 Motherboard - 39T0439
Hello, My 5yr old IBM R52 laptop will not power on.when i press the power button, nothing happen... it wont start/on.. also when i plug the adapter WITH battery,then battery going into charging mode,but when pressing on button then nothing happen and battery charging sign also off...
SOURCE:
SOURCE: I TURNED MY COMPUTER OFF AND IT WONT TURN BACK ON
sometimes you have to remove the memory, unplugged and without the battery in remove it then hold the power button for 10 seconds to clear any power in the pc.
Posted on Nov 01, 2007
SOURCE: IBM R52 laptop shift key deactivated - pls help
you might have accidently disabled 'stick keys' it is a short cut that is activated is you press shift 5 times
Posted on Mar 23, 2008
SOURCE: Access IBM button not working
you need to download the driver available at the website for this software.
http://www-307.ibm.com/pc/support/site.wss/MIGR-55125.html go to this link.
the driver is available there.
The first application file is 1with41us.exe .....this is the file that you have to download.
The second 1with41us.txt(just below the first one ) is a guideline.
you can follow those to get your Access IBM button work.
I hope it helps...if any query contact me at vishalyuvraj@yahoo.com
Bye...
Posted on Nov 25, 2008
  • 4 Answers
SOURCE: green battery charging light flashing and computer won't start
Have you tried removing the battery and replacing it again?
Posted on Mar 02, 2009
  • 125 Answers
SOURCE: ACCESS IBM
you are missing the hot-key diver. For the thinkpad R50e, you can download it here
http://www-307.ibm.com/pc/support/site.wss/MIGR-55042.html#utility
Posted on May 06, 2009
My IBM T40 boots to a black screen with the "z"(light at top to right of power.
Try these steps:
1. Remove battery and unplug AC adapter
2. Press power on button for 30 seconds or so (one min is also too)
3. Attach battery and plug into wall
4. Power "ON" as normal
If you are still getting the "Z" and a black screen then I would have the video card or hard drive looked at and replaced. Start with the video card and then look at the hard drive
thinkpad-t42-wont-boot.html">http://www.techsupportforum.com/hardware-support/laptop-support/234433-ibm-thinkpad-t42-wont-boot.html
Feb 17, 2010 | IBM ThinkPad T40 2373 Notebook
Dell Precision M60 won't start up
Without battery connected it wont work. Better buy a new batterry connect it and plug it for charging for 8Hrs conitnuosly without switching on the laptop.
Apr 20, 2009 | Dell Precision M60 Notebook
I recently replace the fan in my IBM Thinkpad R52. Ever since, when using the power cord it suddenly shuts down after booting for about 10 seconds. But if I use the battery it boots fine.
I would open the case back up to make sure nothing else got moved around when you installed the new fan. If it was close to where power plugs into the laptop, you might have knocked something loose that could be either stopping the fan and causing heat to shut you down, or causing a short when the fan varies its speed.
Mar 16, 2009 | IBM ThinkPad R52 Notebook
Nothing happens when I open the think pad
i believed there is a switch for power on and off on the side of the laptop with symbol (I/0)..make sure your laptop is plug in to your power source with the power brick(maybe there's no more juice in the battery)
Mar 13, 2009 | IBM ThinkPad 600E 2645 Notebook
MY IBM Thinkpad R52 laptop is not entering in BIOS setup
OK< this is main fix I start with when working with a Thinkpad...Unplug from the AC adapter...remove the battery, and the cmos battery. That is the one about the size of a quarter. Leave them out for about 20 minutes. re assemble and try again...hope this helps...
Jan 25, 2009 | IBM ThinkPad R52 Notebook
Where is the wireless adaptor button on the IBM thinkpad R52?
press Fn & F5 same time, for 5 sec. this will activate the wirelesskey on your laptop.
Dec 03, 2008 | IBM ThinkPad R52 Notebook
IBM Thnink Pad R52 Shuts Down unexpectedly
it might be the battery, try plugging it in while doing that.
Jul 09, 2008 | IBM ThinkPad R52 Notebook
R52 laptop screen stays blank
Try removing the battery and starting up just on power supply. May be a bad battery. If that doesn't work let me know.
Jun 06, 2008 | IBM ThinkPad R52 Notebook
Shift key not working - deactivated
Start -> Settings -> Control Panel -> Accessibility Options. The default panel that comes up will in fact be for the keyboard options. There you can turn off whatever happened to have been turned on. While you're there for each of the three options, press Settings, and uncheck Use Shortcut. Now Windows will no longer misinterpret your random keystrokes.
Mar 19, 2008 | IBM ThinkPad R52 Notebook
IBM Lenovo ThinkPad R52 Motherboard - 39T0439 Logo
61 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Steve Allison
Steve Allison
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
