Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Lid switch it was the lid switch , it was broken. where can i get a replacement for it?
  • 246 Answers
Online from whirlpool.com or a local appliance parts store listed in your phone book.
Posted on Jun 15, 2008
Washer will not spin r drain model whirlpool la7680xmwo
Sounds most likely a broken/defective lid switch. The lid switch on a top-load washer is a safety switch that detects whether the top-load washer lid is closed. The lid must be closed when the basket spins; some top-load models require that the washer lid be closed before the washer drive motor runs (thus no draining). If the lid switch isn't properly detecting whether the lid is closed replace the switch.
Dec 24, 2016 | Whirlpool Washing Machines
Washer it will not change from wash to spin
If this is a top loading washer it is likely the lid switch.
If the tab has broken on the lid the switch will not actuate. The switch can be replaced by an experienced repairman. The power must be removed before attempting any repairs.
The washer will not drain or go into the spin cycle with the lid raised or defective switch.
Check that the tab is not broken!
Oct 03, 2016 | Washing Machines
711 Lid lock issues
see this causes:
t doesn't pump or spin
frozen puller, or broken belt, lid switch defective or open replace
It pumps, but doesn't spin
lid switch defective, motor coupler defective,belt broken, clutch worn,drive motor defective,transmission is not shifting properly, basket worn,
It spins only with the lid closed
for security reason, only spin with the lid closed
Jun 19, 2012 | Fisher and Paykel Fisher Paykel Intuitive...
Washer fills agitates but wont drain
The usual problem when that type washer does not drain/spin is a broken lid switch. The lid switch is mid center side of the rim of the lid opening when looking at the washer from the front.ina lot of case by looking in that area ya can see where its broken and hanging down,if ya can not see it phyisically broken ya can open the lid and close it slowly and listen for a click when the lid is mostly closed,do this a couple times,if ya do no thear a click when lid is almost closed the switch will be the problem
This youtube video will show ya how to replace the lid switch. http://www.youtube.com/watch?v=MFsvLiuTniU
GENE
Oct 15, 2011 | Kenmore 22422 Top Load Washer
Kenmore elite not spinning
This issue is caused by:
- Lid open. Be sure the lid is correctly closed
- Lid switch broken. It may need to be replaced.
- Motor broken. QUite expensive repair, the motor needs to be replaced.
- Timer broken.
Check the lid is correctly closed, perhaps the lid switch is having some failures.
Nov 05, 2009 | Kenmore Washing Machines
Lid switch isn't working
yes you do,yo can watcxh this video to show you how to remove the cabinet switch, maybye no t your switch but you cgain acess the same way/.
http://www.youtube.com/watch?v=6XIsK3W_Qcg
Mar 09, 2009 | Estate TAWX700JQ Top Load Washer
Broken disk lid
Not sure if you can find a replacement lid but you may be able to play DVD's if you manually depress the small switch that the lid would engage if it were closed. The switch is located where the lid hinges at the right side, you should see a small rectangular hole. The switch can be depressed through that hole. Of cousre, your DVD will be spinning with no lid to protect it but just don't touch it while the disc is playing. When done playing, you can just turn the unit off or remove whatever you used to engage the small lid switch.
Greg
Nov 06, 2008 | Spectroniq PDV-808
We need to replace the switch that allows the spin cycle to work with the lid down. The back is one solid piece we dont know how to get to the timer to plug in the new switch we bought
What you are talking about is called the "lid switch". The following link explains how to replace one on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Make sure you check to see if the switch is simply loose. There should be some mounting screws holding it in place. In addition, there is usually a small plastic piece mounted on the washer lid on most Kenmores that activate the switch when the lid is closed. This is called a "lid strike". If the mounting screws are loose, or if the lid strike is broken or missing, the washer will exhibit the same symptoms as having a broken lid switch. For replacement parts, refer to searspartdirect.com and type in your complete model number (located along the washer lid opening). The parts you need will be listed under the "Top and Cabinet" heading.
I hope you find this information helpful. Let me know if you require additional assistance.
Sep 11, 2008 | Kenmore Washing Machines
Washer estate brand ETW4300SQ Model
If the washer fills and stops at the rinse cycle, and then will not spin or drain, you more than likely have a defective lid switch. If you open and close the washer lid and do not hear a “clicking” sound, the switch has probably come loose, or has broken. There are two mounting screws that hold the switch in place along the washer rim. Also, inspect the lid to ensure the small plastic piece that pushes down on the switch when the lid is closed has not broken off. This is called the “lid strike”. If the lid strike is broken or missing, the lid switch will not activate. If you diagnose the problem and need to replace the switch, you can click on the following link for advice on how to replace it:
http://www.fixya.com/support/r397101-replacing_lid_switch
If you need further assistance, such as where to get replacements parts, please let me know. I hope this helps you.
NOTE: You do not need to drain the wash tub to replace the switch. Once the switch has been replaced, the washer should spin and drain, which will prevent you from needing to bail water.
May 23, 2008 | Estate TAWB600JQ Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
Dan Webster
Dan Webster
Sal De GO PATS
