How many people in the earth - Computers & Internet
    President:
  • 1,216 Answers
Click here
Posted on Nov 03, 2010
How many earths does 200ise opel kadett 20seh engine have
depending on year, there is one main earth on old models, new models there is a earth for every wire going to a electrical part. if you have earthing problems you can put an earthing strip in place. but check earthing wires to the shell from the battery clean them and put back on.
Jun 20, 2017 | Opel Cars & Trucks
Tip
Ducati Fault Codes
Engine Fault Codes - Ducati 749/999
To see the fault codes, with the ignition off hold both dash buttons down and turn ignition on.
1.1 TPS Disconnected
1.2 TPS short circuit to earth
2.1 Pressure Sensor short circuit to power supply
2.2 Pressure Sensor shorted to earth
3.1 Water Temp Sensor shorted to power supply
3.2 Water Temp Sensor shorted to earth
4.1 Air Temp Sensor shorted to power supply
4.2 Air Temp Sensor Shorted to earth
5.1 Battery Hi
5.2 Battery Low
10.1 Hor. Coil shorted to power supply
10.2 Hor. Coil shorted to earth
11.1 Ver. Coil shorted to power supply
11.2 Ver. Coil shorted to earth
12.1 Inj1 shorted to power supply
12.2 Inj1 shorted to earth
13.1 Inj2 shorted to power supply
13.2 Inj2 shorted to earth
14.1 Inj3 shorted to power supply
14.2 Inj3 shorted to earth
15.1 Inj4 shorted to power supply
15.2 Inj4 shorted to earth
16.0 Pump Relay
17.1 LH Fan shorted to power supply
17.2 LH Fan shorted to earth
18.1 RH Fan shorted to power supply
18.2 RH Fan shorted to earth
19.1 Starter Solenoid shorted to power supply
19.2 Starter Solenoid shorted to earth
30.0 ROM/Eprom error
34.0 Signal Panel Sensor
36.0 Speed sensor
37.0 Immobiliser (transponder)
37.1 Immobiliser (antenna)
37.2 Immobiliser (instrument panel serial driver)
37.3 Immobiliser (serial cable disconnected)
37.4 Immobiliser (ccm serial drive)
37.5 Immobiliser (key not recognised)
37.6 Immobiliser (ccm program)
38.0 Can Line error
Source http://moto-files.weebly.com/ducati-fault-codes.html
on Dec 20, 2016 | Motorcycles
I need wire colors for CB microphone its a TRC
ALTAI PWR MIC - black/braid= earth, red=RX, white=TX, Yellow=MODASTATIC - blue/braid=earth, black=RX, red=TX, white=MOD, Yellow=Spare
SIRTEL ECHO MIC CBE 2002 - black/braid=earth, blue=TX, white=RX, red=MOD007 POWER MIC - brown/braid=earth, green=RX, white=TX, blue=MODSADELTA EC 980 - braid=earth, green=RX, brn=TX, white=MOD
or braid=earth, black=RX, blue=TX, white=MOD
Oct 30, 2016 | Radio Communications
Where does my fuses go and to what?
basic electrical circuit , Battery earth and power, to fuse's and relays power and earth, to user's ie switch's ,motors etc , called earth return as earth of components does not have to got to the battery as the battery is earthed to the vehicle chassis, so the earth of components (user's) can be put to the chassis as well hence earth return, does this help in any way ?
Oct 18, 2014 | 1994 Cadillac Eldorado
999 injection relay tick continuously when turn to on
found on the net
Listed below are the Ducati error codes for the 999/749 series which are very handy to know...
If your stead decides to create an error and then flashes her yellow warning strobe (the EOBD light) then follow these steps....
1) Turn the ignition to 'OFF' (Whilst stationary that is.... )
2) Depress and hold the left hand instrument panel button
3) Turn the ignition to 'ON' whilst still depressing the left hand button
4) You should then see the error codes displayed
5) Make a mental note of the codes and cross reference with the following list.........
ERROR CODES
1.1 = Throttle Position Sensor (TPS) Disconnected
1.2 = Throttle Position Sensor (TPS) short circuit to earth
2.1 = Pressure Sensor short circuit to power supply
2.2 = Pressure Sensor shorted to earth
3.1 = Water Temp Sensor shorted to power supply
3.2 = Water Temp Sensor shorted to earth
4.1 = Air Temp Sensor shorted to power supply
4.2 = Air Temp Sensor Shorted to earth
5.1 = Battery Hi
5.2 = Battery Lo
10.1 = Horizontal Coil shorted to power supply
10.2 = Horizontal Coil shorted to earth
11.1 = Vertical Coil shorted to power supply
11.2 = Vertical Coil shorted to earth
12.1 = Inj1 shorted to power supply
12.2 = Inj1 shorted to earth
13.1 = Inj2 shorted to power supply
13.2 = Inj2 shorted to earth
14.1 = Inj3 shorted to to power supply
14.2 = Inj3 shorted to earth
15.1 = Inj4 shorted to powersupply
15.2 = Inj4 shorted to earth
16.0 = Pump Relay
17.1 = L/H Fan shorted to power supply
17.2 = L/H Fan shorted to earth
18.1 = R/H Fan shorted to power supply
18.2 = R/H Fan shorted to earth
19.1 = Starter Solenoid shorted to power supply
19.2 = Starter Solenoid shorted to earth
30.0 = ROM/Eprom error
34.0 = Signal Panel Sensor
36.0 = Speed sensor
37.0 = Immobiliser (transponder)
37.1 = Immobiliser (antenna)
37.2 = Immobiliser (instrument panel serial driver)
37.3 = Immobiliser (serial cable disconnected)
37.4 = Immobiliser (ccm serial drive)
37.5 = Immobiliser (key not recognised)
37.6 = Can Line error
__________________
May 17, 2014 | 2003 Ducati 999
Why is earth the only planet with life?
We don't know that the Earth is the only planet with life. It's the only planet we know of with life, but that doesn't mean that there aren't any others. There are many, many other planets out there in the universe. Some of them almost certain do have life.
Nov 08, 2013 | Brunello Cucinelli Leather Beaded Strap...
Earthing
Earthing a turntable.
There are 2 common ways of earthing turntables that have an earth wire as a standard fitting.
If the amp has dedicated phono input there will also be an earth terminal post nearby.
For amps without an earth terminal simply slip the earth wire into the side of one of the turntables rca output connections as you plug into the amp.
Cheers John.
May 07, 2013 | Technics Audio Players & Recorders
Where is the boot light earthed
riught up behind the panneling its easire to renew the earth and leave the existing earth wire connected as well so anything else using the same earth will work as well through the new earth.
Jan 14, 2013 | 2004 Rover 25 1.4
Apart from the main supply to the cooker terminals
So long as the earth is connected to the earth terminal, then there is no prob for you to worry about.
The normal twin and earth cable is adequate.
Please rate my comments.
Thankyou..
Mar 05, 2009 | Neff U1661 Double circotherm super...
Computers & Internet Logo
24 people viewed this question
Alun Cox
David Payne
David Payne
