Question about Hitachi 53UWX10B 53" Rear Projection Television
Convergence I have a 53uwx10b # v11013361 and when i turn the tv on everything is fine for about 1 or 2 minutes then the whole screen goes out of focus. If u go to the tv and hit it hard in the front like my 2year old daughter does it comes back to focus for about 2 to 5 minutes the it losses focus. What can i do to fix it??
  • 927 Answers
Good Day;
It sounds like you have bad connection on the convergence IC's. They are, from back,on the right side, they are mounted on a large heat sink, silver/gray in color. Re solder the pins of those IC's. Be careful the pins are really close together. Fix it now or the parts will fail and will have to be replaced.
Good Luck.
Posted on Jun 13, 2008
    Problem Solver:
  • 8 Answers
Hi there, this seems to be a classic case of bad or broken connections in the convergence circuit. there are a couple [2] convergence output ics on large heatsinks near the center of the main chassis, usually soldering the connections fixes this, but due to the nature of the make-and-break of the connections the ics may have been damaged so i usually replace them to avoid a call-back, generic numbers are usually STK391-110 for standard definition and STK391-570 for high definition. The actual part numbers and locations may vary from model to model and year to year, but these are the most common. good luck and be safe.
I just turned on my tv and there are shadows around everything on the screen. Purple ones on the left of the object and green on the right. I was just watching it last night and now it's doing this. ...
Very common problems with the DLP projection tvs.The tv have a problems known as a convergence problems,it dead.Tv colors lines R,G,B mis alignments,have colors pictures shadows or 3D pictures.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u $300-350 for parts and labors.
Oct 12, 2010 | Hitachi 53UWX10B 53" Rear Projection...
My screen slopes from one side to the other on bottom!
Convergence on ur tv are dead.Must know how to do soldering?Must replaced 2 STK convergence ICS,and some or all it resistors.Tries websites Tv repair World.com,Tvrepairkits.com to buy a convergence kit to fix it urself.The shop will cost u $300 for parts and labors.
Mar 25, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Turned on TV this morning and the colors were out of alignment. TV works just looks funny. Tried the magic focus and got most of the screen lined up....except the upper left hand corner where the colors...
There is a convergence output kit for this set. There are probably resistors in the convergence circuit that are starting to loose there values. If you are going to have the set worked on have them install the whole kit which includes the convergence outputs and resistors. Thanks
Oct 27, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Convergence settings on hitachi 53uwx10b
Yes - You will need to either remove the circuit board or lift up the tray. If you are not sure how to do it yourself read the link below.
  • This is a very common failure on Projection TV sets.
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
You can see some example photos and find a solution here...
http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Sep 10, 2009 | Hitachi 53UWX10B 53" Rear Projection...
53UWX10B Red giving problems
Good Day,
Welcome to the world of having a convergence circuit problem. There two things you can do; get it repaired by a Factory Authorized Service Center or repair it your self. Purchase KIT 10 from B&D Enterprises, 1-800-458-6053. The kit has everything you will need except soldering equipment and experience. Good Luck, big IRISH.
Sep 19, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B
Good Day, Armenian;
You may have CRT Coolant on one the boards. LOOK very closely for shiny spot on any of the boards. WHY? Because you are saying the TV is having multiple problems. Let me know.
Aug 30, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Convergence cutting in and out
Good Day, Armenian;
You have poor connections on the convergence IC's , re solder and your TV should be back to normal.
Aug 04, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Any assistance appreciated
Check your soldering make sure you don't have any bad solder joints.
the red ghost on the left side sounds like you could have adjusted that out with the menu convergence.
Jan 31, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 53UWX10B Projection TV colors not lining up...
This is a convergence issue..both chips need replacement.
Dec 14, 2007 | Hitachi 53UWX10B 53" Rear Projection...
TV PROBLEM
This could be the start of convergence problems. Anytime you are dealing with color lines then is the convergence. No first you could check for loose connection and then change in value return resistor in the convergence area. Hope this helps!
Sep 07, 2007 | Hitachi 53UWX10B 53" Rear Projection...
Open Questions:
See all Hitachi 53UWX10B 53" Rear Projection Television Questions
Hitachi 53UWX10B 53" Rear Projection Television Logo
46 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
