Question about KitchenAid Kitchen Ranges
I have a brand new Kitchen aid single oven. I can't figure out how to do a simple function like turning it up. Do you have to cancel what temp your on and start over? Let's say it's at 325 and want 350.....isn't there just a simple way to turn it up? or down?
  • 413 Answers
Just press the bake button and reset the temperature.
Posted on Jun 13, 2008
My husband put a plastic container on a hot stove rack, brand new stove, what is the best way to remove the baked on plastic
Take a single blade razor blade and slowly cut the plastic away, following the curve of the rack. This will take some time, but the plastic will come away. After the plastic is removed, use a scotch bright pad to clean the rack.
Mar 08, 2015 | Kitchen Ranges
Needd to change kitchen aid wall oven from celsius to fahrenheit
Press and hold the Broil Max Econo button for 5 seconds.
Only this button and without turning on oven.
Feb 17, 2013 | KitchenAid Kitchen Aid KEBS177SBL Single...
Error code F2 E3 r:02 E:03
Kitchen Aid Error Code F2-E3
Called kitchen aid, they said you need a new control board part #9782455.
Mar 16, 2010 | KitchenAid KEBC107 Electric Single Oven
I have a Kitchen Aid range model KGST307GBS0. The
The door light switch was broken (upper right face of oven). The door switch is automatically activated when the door is opened to turn on the oven light. When the door is closed the switch is depressed to turn off the light. It seems the switch position is detected by the oven and if it is in the open position it will not allow the oven to function properly (reach temperature or allow the cleaning cycle to run). I temporarily locked the broken switch in the closed position, which allows the oven to function. A new switch was ordered for replacement.
Jan 02, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchen aid dishwashers model kudi1o1ilbl6 won't function. Cancel light flashes 7 times pauses and flashes 7 times repeat for ever. killing the power did not reset. Advice?
open door, press in rapid sequence the following keys: hi temp scrub, energy saver dry, hi temp scrub, energy saver dry. Close the door until it latches, then open it and depress the cancel key. The lght should clear. It's a beautiful thing.
Aug 15, 2009 | KitchenAid 24 in. KUDS25 Built-in...
I cannot turn top oven off from bake. How do I make it work?
have the same problem with kitchen aid stove. Set the cook duration for one minute - then open and closed door. Oven turned off.
Jul 31, 2009 | Maytag MER6772 Gemini Electric Kitchen...
Finding replacement part # 4164235 for inner door glass
I am looking for a Kitchen Aid part # 4164235, a Window Pack for the inner door of my Kitchen Aid Oven door.
May 16, 2009 | Whirlpool RBS305PDS Electric Single Oven
Kitchen Aid superba (electric oven)
you will need electrical meter. Take unit out of hole remove back plate( unplug or turn breaker off first). Turn power back on set temp for bake check leads to element. If no voltage replace control
May 27, 2008 | GE JBP69 Electric Kitchen Range
Kitchen Aid KESH307BBL9 with a F2:E5 displayed code
clean the ribbion connector off with a pencel eraser a few times and reinsert into the control, if this does not solve the issue then you nedd tor replace the touch pad, which will come with a new ribbon
Apr 12, 2008 | Kitchen Ranges
Kitchen aid kebc278 dual ovens don't work
yes once of the door switches is broken you could jump out the switch
Oct 05, 2007 | Frigidaire FEB30S6D Electric Single Oven
Kitchen Ranges Logo
76 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
