Question about Gateway Computers & Internet
The power light does not come on when power button is press
  • HBUCKLEY Mar 18, 2009
    Gateway GT5242E PC Desktop
    POWER BUTTON TURNS ON ALL FANS INCLUDING POWER SUPPLY BUT THE BUILT IN LIGHT DOES NOT LIGHT.
    THE COMPUTER DOES NOT BOOT OR DRIVE SEEK.
    THE POWER SUPPLY PUTS OUT 12V(YELLOW) AND 5V(RED) TO DRIVES.
    THE YELLOW LIGHT BELOW THE GATEWAY LOGO FLASHES ON TURN ON & OFF.
    I HAVE RESET ALL PLUGS & MEMORY TO NO AVAIL.
    I PULLED ONLY CARD(56k MODEM) USING A SLOT STILL NO GOOD.
    THANKS IN ADVANCE FOR ANY HELP.
    hbuckley@suffolk.lib.ny.us
  • William Fyler May 11, 2010
    What model do you have. And I have it that the Power supply is working. Send model an we will take it from there something small or big.
    Problem Solver:
  • 10 Answers
Not having the spec's or model of your gateway
I would look for a wire lead inside your case that would be coming from the front most are blk/red and marked pwr/led this could have worked itself lose off the pins on the motherboard.
Being I don't have the model gateway I can not tell you where the right jumper is or setting would be for it if it did come off. The other could be power supply or motherboard itself.
Word of caution: When working inside the computer wear static free strap and touch metal to ground yourself. Not to cause static inside around motherboard or any of the components insides.
This is only a speculation without knowing much about the model
Posted on Jun 16, 2008
  • 749 Answers
Hello Jeff,
If your computer does the same problem after each cold start or every after sometime, that tells you that the power supply is working fine.
If so, well... check the CMOS Battery inside try replacing it must be 3V to maintain the BIOS settings of your computer. Also, clean the heat-sink of the processor if necessary to avoid overheating.
After that try to switch the computer ON. Post us back if there are problems, also don't forget to rate us so we could continue helping others.... good luck.
from Philippines.
Posted on Jun 13, 2008
  • 3,940 Answers
Without a specific system designated I can only give a General answer.
On desktop/Tower systems, if there is NO POWER indication when attempting to turn on the system, the most likely point of failure is the power supply.
ATX power supply is about $30 and most are a one size fits all, but there are some variations in case design for low and high end systems
Error Code no. E000067-0110
Resetting Ink-Waste Overflow Counter Canon Pixma iP3000, iP4000, iP5000 Printers
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. (DO NOT release the buttons. The LED light should be green to indicate that a function is selectable.).
  2. While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.).
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  4. When the LED light is green, press the Resume/Cancel button 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.).
  5. Press the Power button. The LED lights in green, and the reset is performed. (When the operation completes, the printer returns to the menu selection mode automatically.).
  6. Press the power button to exit service mode.
Note: if you accidentally press the Resume/Cancel button more than 4 times in step 4 then just press the Resume/Cancel button at least 10 times and the printer will be returned to step 4 automatically
If the issue still persist contact manufacturer
Jul 06, 2011 | Canon iRC3100 Printer
Canon pixma IX4000 printer orange led 5 times blinking.pls send how to solve this problem.
Jul 06, 2011 | Canon PIXMA iX4000 InkJet Photo Printer
Blinking ornge light
reset your printer if you try you can i will give you 6 tips
Here this manual way step by step to resetting waste ink counter on printer canon iP4000.
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold the Power button. Do not release the buttons. The LED light should be green to indicate that a function is selectable.
  2. While holding the Power button, release the Resume/Cancel button, do not release the Power button
  3. While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  4. When the LED light is green, press the Resume/Cancel button 4 times. Each time the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.
  5. Press the Power button. The LED lights in green, and the reset is performed. When the operation completes, the printer returns to the menu selection mode automatically
see you can where is blinking orange light
Sep 02, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How can I reset the waste ink counter in the printer Canon Pixma IP4200 ?
you can reset it following this procedure:
  1. With the printer plugged in and powered off, press and hold the Resume/Cancel button, then press and hold POWER button. Do not release the buttons. The LED light should be green to indicate that a function is selectable
Then you should do this http://erkinson.altervista.org/blog/2010/canon-ip4000-disassembling/
May 14, 2010 | Canon PIXMA iP4200 InkJet Photo Printer
Alarm lights keep blinking after I changed my printer ink.
E5 means cartridges error - to fix press the "stop\reset" button for 5-7 seconds and then release it.
You can also try this:
1) With the printer power turned off but connected to a power source, while pressing the Resume/Cancel button, press and hold the Power button.
(DO NOT release the buttons. The Power LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and
Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light
alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4) When the Power LED lights in green, press the Resume/Cancel button the specified number of time(s)according to the function listed in the table below. (Each time the Resume/Cancel button is pressed, the Alarm and
Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
4 times----Green (Power)------Waste ink counter resetting
Apr 07, 2010 | Canon PIXMA MP240 All-In-One InkJet...
Ausbau von ink-absorber - canon pixma 4200ip
Canon Pixma iP4200, iP5200, iP6000, iP8500 Reset Procedure
  1. Turn off the Printers.
  2. Hold Resume button click POWER.
  3. Hold button RESUME, release POWER
  4. Then press the button again twice RESUME.
  5. Release all the buttons.
  6. Indicator led in green and stay green.
  7. Click the button 4 times RESUME, if you want to make another transaction.
Feb 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Waste ink tank full, what do I do?
1) With the printer power turned off, while pressing the Resume/Cancel button, press and hold the Power button. (DO NOT release the buttons. The LED lights in
3) While holding the Power button, press the Resume/Cancel button 2 times, and then release both the Power and Resume/Cancel buttons. (Each time the
4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
5) After the function (menu) is selected, press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes,
Aug 02, 2009 | Canon PIXMA iP5000 InkJet Photo Printer
Canon ip 4200
4) When the Power LED lights in green, press the Resume/Cancel button 4 times, the green (power) led should be lit to reset ink absorbers.
(Each time the Resume/Cancel button is pressed, the Alarm and Power LEDs light alternately, Alarm in orange and Power in green, starting with Alarm LED.)
5)At the end of the service mode, press the Power button
Jan 10, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon ip4200 waste absorber is full
Jan 10, 2009 | Office Equipment & Supplies
Error number 1700 canon s9000 printer
knowing printer manufacturers I doubt they even have a sensor to detect that its full at all, they probably based on something crumby like print count. here are some instructions to reset the waste ink tank, the instructions vary so try them until one does the job :
Waste Ink Tank Reset
1: Power off printer
2: Hold Resume button then press and hold POWER, the beeper will sound once.
3: Hold POWER and release RESUME
4: Press RESUME twice, then release all buttons
5: When the indicator lights steady, press RESUME three or four times. The indicator should be orange.
6: Press Power to set data
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
1. power off Printer
2. Push and hold resume button and push power button
3. Hold Power button and release Resume button
4. Push Resume button twice ( 2x ), and now release resume button and power button
5. Green light will blinking and stop.
6. When green light on, push resume button 4 x
7. Push Power button and printer will off, if that isn't off, push power butto again until print off position.
Aug 20, 2008 | Office Equipment & Supplies
Computers & Internet Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
